Technical Flathead engine resistance
Discussion in 'Traditional Hot Rods' started by Jellowe, Feb 10, 2021.
  1. Jellowe
    Jellowe
    Here’s a question I can’t find in a book or online. What is the normal or acceptable turning resistance on a newly built, never ran 1953 flathead Ford motor on the bench with plugs removed? I realize valve springs and piston ring friction are the major contributors also lubricants. My cylinders are fairly dry, it takes about 500in/lbs to get image.jpg her turning and 400in/lbs to keep her rotating , turning by hand with my torque wrench on the crankshaft center bolt. What is normal?
  2. Budget36
    Budget36
    Seems about right for an SBC. I’d think a FH would be about the same.
    Jellowe likes this.
  3. Bandit Billy
    Bandit Billy
    Resistance is futile. Flatheads forever!
  4. Ziggster
    Ziggster
    Seems about right. I just tried my C59A. Plugs and heads installed, but head bolts just hand tightened. I can hear the compressed air escaping on the compression strokes. Took about 40 ft-lbs.
  5. Hnstray
    Hnstray
    from Quincy, IL
    I think 40 ft lbs would 480 inch lbs ..... very close to the 500/400 the OP posted....is it not?
    Ray
    alanp561 likes this.
  6. Ziggster
    Ziggster
  7. Budget36
    Budget36
    400/12. Roughly 33 ft/lbs. seems about right to me
    Desoto291Hemi likes this.
  8. TCATTC
    TCATTC
    Those rope seals make resistance.
    alanp561, 34 GAZ and Desoto291Hemi like this.
  9. A5A3B975-66DE-45DB-B1D2-3B2523B98825.jpeg Pull plugs spin till oil pressure show on gauge—-replace plugs fire engine run till 180-190s fast idle 2000 rpm—-cool down —-cool down till not hot to touch —retorque heads——repeat procedure—-it gets easier every new cycle. May use an extra external fan in addition to stock fan on engine for additional cooling When breaking in a new engine.Flatheads Forever!!!
  10. Hnstray
    Hnstray
    from Quincy, IL
    40 lbs ft would be multiplied by 12 for inch pounds, not divided. 40 x 12 = 480
    Ray
  11. Budget36
    Budget36
    He said inch pounds. If it were 12 in/lb it would be 1 ft/lb, right? So 400 inch/lb / 12 would be ft/lbs, or 33.33 ft/lbs.
    Edit: I see what you’re getting at.
  12. Hnstray
    Hnstray
    from Quincy, IL
    My response was in reference to @Ziggster , converting his ft lb measure to in lb , to confirm it’s equivalency to the OP’s numbers.
    Ray
    ottoman, Ziggster and Budget36 like this.
  13. Jellowe
    Jellowe
    Thanks for checking your motor, seems the consensus is, I'm in ok range.
    dirty old man and Ziggster like this.
  14. fiftiescat
    fiftiescat
    from NY
    Fresh engines, no matter what make, are always going to be a bit on the tight side. Remember, everything is new. if the starter can turn it over, you'll be fine.
    Pist-n-Broke likes this.
  15. In my entire work career I can say I have never checked one. If it turned with my flywheel tool smoothly it was just fine. Final test was building oil pressure with the starter and plugs out. Never had and issue.
