Technical ANYONE STILL USE PUSH BUTTON START?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Apr 26, 2021.
  1. 51pontiac
    51pontiac
    from Alberta
    Yup...works great.
    HOTRODPRIMER likes this.
  2. denis4x4
    denis4x4
    from Colorado
    No keys! I'm using a SoCal pull switch to start the motor and the switch returns to the run position and just have to push the switch knob end to turn off the motor. Knob on the right is the starter. Left knob is there to balance things out.
    barrnone50, Driver50x, cfmvw and 4 others like this.
  3. Budget36
    Budget36
    My 42 Ford PU had a “modern” ignition switch it it that kept turning as well, so I looked the pile and put a TF Chevy on/off switch in it and push button. Never. Problem after that.
  4. jaracer
    jaracer
    My 64 Chevy C20 has a hidden push button installed by the previous owner. I think he was afraid someone would steal it. I really don't have that fear. chevy02.jpg
    MO54Frank and HOTRODPRIMER like this.
  6. AldeanFan
    AldeanFan
    When I built my last hotrod in 2008, all the cool cars of the time had red start buttons, so my car got one.
    A few years ago I bought a new Toyota and it has a start button, so if start buttons come in new Toyota SUV’s then it’s not cool anymore so I removed it from my hotrod.
    Driver50x and HOTRODPRIMER like this.
  7. It's ironic how the new cars are starting to mimic the past, starter buttons have made a comeback, what's next? Window cranks. HRP
    High test 63, Deuces and cfmvw like this.
  8. cfmvw
    cfmvw
    Maybe they will come up with hatches and doors that have to be closed manually!
  9. mgtstumpy
    mgtstumpy
    I will still have the dash button in my 46 Olds. I've a new ignition switch and will have it wired in as per OEM.
  10. rockable
    rockable
    My 49 Tin Woody has push button start.
  11. Stan Back
    Stan Back
    Starter button? Well, I know the Merc has one, hidden under the dash rail, left side if you're wondering.
    The 54 Plymouth? I drove it a few miles yesterday. I was the one who did all the wiring. Starter button? I'd have to go look. (I know where it is when I sit in it awhile.)
    Brings back an interesting story. At Bonneville a couple of years ago, I was wearing whites (as I was "semi-official") driving along in my 2002 Chevy pickup (3/4-ton, 6-liter, 5-speed) when a young (16-25?) man hailed me down for some info. I answered his procedure questions and he thanked me and asked "What's that big lever coming out of the floor?"
  12. My 40 Ford Coupe & 34 Ford Pick-up both still have starter buttons because I like them & I
    chose to keep Orignal looking steering columns. My 33 Willys Coupe (Under Construction )
    will have a starter button also. My 32 5 Window sadly does not. Jerry
  13. rusty valley
    rusty valley
    My 34 coupe has one hidden under the dash. I dont mind the foot pedal start in my A's, but the model 40 foot pedal is in a bad place I think, hard to reach. Then, I like to have the solenoid with the push button on it also, you can turn it over from under the hood...preferably in neutral !
  14. Mike Colemire
    Mike Colemire
    After 3 of those china ignition switches that everybody sells went bad, I put a push button in mine and it's made in the USA.
    32SEDAN, cfmvw and HOTRODPRIMER like this.
  15. PhilA
    PhilA
    1. Hydro Tech
    Pushbutton start on my '51 Pontiac.
    Fitted the valet option ignition switch, so most people get in, twist the key on then back to off on the fully clockwise position!
    Still got it wired through the safety inhibitor switch, it'll only crank over in Neutral. It's handy to be able to spin the starter without the ignition on, good to get a bit of oil around before starting up after a few days sitting up.
    I did get distracted from the routine (key in, window down, quarterlight open, key on, tap gas pedal, push starter) and cranked the thing over a couple times in the grocery store lot before I realized I didn't have the ignition on...
    Phil
  16. j hansen
    j hansen
    Foot starter on my 1941 De Soto.
    Push button on my 1948 Dodge. Skärmavbild 2021-04-26 kl. 19.14.12.png Skärmavbild 2021-04-27 kl. 00.47.37.png
  17. 210superair
    210superair
    from Michigan
    Push button transmissions too! My aunt used to have a convertible with that, tho I can't recall what, I was too young. I remember her bragging that up though, lol... It was a new thing back then.
    32SEDAN and HOTRODPRIMER like this.
  18. cs39ford
    cs39ford
    Button still in service on my old 39 DC7335D7-C6B9-4AF9-BDD1-528641E65E5D.jpeg
    32SEDAN, 210superair and HOTRODPRIMER like this.
  19. Carlmac 369
    Carlmac 369
    The height of them. Very few low roofline cars anymore, all SUV looking type things like '30's sedans but a lot uglier.
  20. Still using the push-button to start the Cadillac in my '40!
    HOTRODPRIMER and 210superair like this.
  21. HealeyRick
    HealeyRick
    from Mass.
    The SBF in my Austin-Healey 3000 is activated by the car's original push button. Its little brother, a Bugeye Sprite, on the other hand is started with "pull-to-start" cable attached to the solenoid.
    210superair likes this.
  22. 32fenderless
    32fenderless
    Built an AD truck a year ago and used the factory ignition switch and used a tractor foot starter button and wired it through the neutral safety on the Lokar shifter. Works great.
  23. My '29 Model A has the original push button floor starter still in use.:) If it works why fix it.;)
  24. Beepx22
    Beepx22
    48 Chrysler is key and button. And 3 of my OT cars are push button
  25. HOTRODPRIMER likes this.
  26. adam401
    adam401
    This jalopy has a 2 position keyed ignition and starter button from an f100.
  27. AldeanFan
    AldeanFan
    They brought back cartridge oil filters.
    HOTRODPRIMER and MO54Frank like this.
  28. MO54Frank
    MO54Frank
    Studebakers and maybe some Mopars in the 40s - 50s had the floor mounted starter button under the clutch pedal.
  29. rusty rocket
    rusty rocket
    Yep have one on my T modified and have a mechanical stomp starter modified to be pushed with my hand on my single seater.
  30. poco
    poco
    from oklahoma
    39 2 door ford has push button
