Projects Just another lakes modified roadster...
Discussion in 'Traditional Hot Rods' started by T__N__A, Apr 22, 2021.
  1. T__N__A
    T__N__A
    17" buffalow wire wheels
    Chrysler front axle
    221" flathead
    Started out as a 26 touring
    IMG_20210222_230553_793.jpeg 20210307_210949.jpeg IMG_20210301_232440_898.jpeg Screenshot_20210422-162829_Instagram.jpeg
    Sent from my SM-G965U using The H.A.M.B. mobile app
    FORDY 6, hfh, unforgiven and 41 others like this.
  2. Stovebolt
    Stovebolt
    The proportions of this build a perfect, I'll be following this build
  3. rusty rocket
    rusty rocket
    SSSWWWEEETTTTTT! I’m sort of partial to 26 T modified’s
  4. speedster t
    speedster t
    This is my next project. Very nice build What the plan for the front breaks and is that a BSA in the background
    loudbang, Stogy and T__N__A like this.
  5. fabricator john
    fabricator john
    from venice fl.
    Nyce ,,,,, whippet shell
    fabricator john
    miss you dad
  6. T__N__A
    T__N__A
    No front brakes. Just rear hydraulics. Its a a 1958 royal Enfield/Indian
  7. Yes. Yes. Yes. (Meg Ryan voice)
    Keep a posting pics
  8. T__N__A
    T__N__A
    Lots of time standing back, drinking beers to get it right haha
    Nailhead A-V8, loudbang and slim38 like this.
  9. Stovebolt
    Stovebolt
    @T_N_A are you going to run the blower when it's done, or is it just there as a mock-up?
    It seems as though it's from a later period as compared to the era of this bitchin' build.
    The37Kid and loudbang like this.
  10. Tim
    Tim
    from KCMO
    Looks fun!
  11. Stogy
    Stogy
    Fantastic Inspiration to the Good Ole Days indeed...You know when there are Buffaloes and Whippets the Dry Lakes aren't far away...
  12. earlymopar
    earlymopar
    What Chrysler model and year axle is that? I expected to see a "double-hump" axle then saw your front view picture.....
    Stogy and loudbang like this.
  13. T__N__A
    T__N__A
    I think its a 27 or so. Not that familiar with the chrysler stuff
    Nailhead A-V8, Stogy and loudbang like this.
  14. T__N__A
    T__N__A
    Ya definitely superchargering it.
    Its a late 30s/40's build. 3-71's came out in the late 30's. Barney Navarro put one on his car in 47...doesn't seem to far out of place
  15. rotten ron
    rotten ron
    Perfect proportions
    T__N__A, Stogy and loudbang like this.
  16. T__N__A
    T__N__A
  17. Stovebolt
    Stovebolt
    Will you be running a chain drive? They are as cool as ever on the early setups.
    There's a blown V860 powered modified that runs a single belt drove for everything - that's a hot setup for this period too.
    loudbang and Stogy like this.
  18. The37Kid
    The37Kid
    Buffalo's make the car. Bob
    270ci, loudbang, Carter and 2 others like this.
  19. A Boner
    A Boner
    Perfect...EXCEPT the no front brakes part of the plan!
    loudbang and T__N__A like this.
  20. T__N__A
    T__N__A
    Its a Model T....whens that last time you saw front brakes on a T??
    Tman, Austin kays, Hitchhiker and 2 others like this.
  21. exterminator
    exterminator
  22. Nailhead A-V8
    Nailhead A-V8
    subscribed! looks great man.... tell us more about your front end which is basically what I have planned for my T...like did you sleeve the axle to put the wishbones on? did you mill that area on the axle or the bones? what year are your bones? do those spring mounts that wrap around the axle come off if cut here and there or is it a grind off procedure? I see the areas where they were but can't tell what you did... I've been eyeing mine up wondering how to do it:D.....do you know if bearings/seals etc. are still available?....sorry about the 20 questions lol I'm just really stoked to see the set up i've been planning (flipped crossmember too) the only differences are I was going to use the stock 6 bolt wood spoke hubs with adaptors(speedway) for wide 5 rims and '47 bones unsplit under the rails to add caster (and also because I have heard that tube axles and split bones don't play well together...) otherwise identical
    loudbang and kidcampbell71 like this.
  23. Okie Pete
    Okie Pete
    Very nice . Looks like fun on roids
  24. That thing is cool!
  25. T__N__A
    T__N__A
    Drilled and welded new bosses in for the radius rods perch bolts. Had to open up the radius rods. The new boss are about 2.5" wide. The spindles where machined to fit the T/buffalow hubs. So bearings are easy to find IMG_20210220_193447_549.jpeg IMG_20210220_213029_905.jpeg IMG_20210220_213029_910.jpeg
  26. sloppy jalopies
    sloppy jalopies
    they will be just a scratching their chins when you take that baby out for a putt...
    The37Kid and T__N__A like this.
  27. T__N__A
    T__N__A
    Ya definitely for sure!!
    loudbang and 48fordnut like this.
  28. T__N__A
    T__N__A
    Her are some pictures of the rear suspension. 1934 axle, 1934 split wishbones, T spring, custom rear hangers I built. IMG_20210210_232017_014.jpeg IMG_20210210_232016_976.jpeg IMG_20210124_205744_842.jpeg IMG_20210301_232440_894.jpeg
    itsmee, OFT, bymanr and 14 others like this.
  29. Nice work!
    T__N__A and loudbang like this.
  30. rotten ron
    rotten ron
    Love this build.
    T__N__A likes this.
