Art & Inspiration brush/spray can paint jobs
Discussion in 'The Hokey Ass Message Board' started by rusty1, Apr 13, 2021.
  1. Blues4U
    Blues4U
    from So Cal
    That looks great. I'm curious what you used to retain the hood onto the body?
    GordonC likes this.
  2. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    The art of brush painting with enamel is having a really good quality natural bristle brush and knowing how to use it.
    The trick to getting a nice brush job is to learn how to "tip it off" as they say in the trade. I've brush painted several cars and gotten very good results with no other work. But then I'm not picky. In the mid '60s my buddy and I got kicked out of Washington Park in Denver for painting my '46 Buick in the park. A 3.00 gallon of surplus Air Force Blue paint and a couple of cheap brushes did the trick. A case of beer helped, too.
    AHotRod, cfmvw, Blues4U and 1 other person like this.
  3. blowby
    blowby
    from Nicasio Ca
    Ha, many years ago when I was young and my Corvette was black primer..
    Friday night, my buddy and I were getting ready to cruise for chicks in the Vette. I bought two rattle cans of black primer to freshen it up. So right around dusk we pulled in behind a bakery on the main drag, he started down one side and I went down the other. There were some houses on the hill behind the bakery, I guess that's what happened, because halfway through the cops showed up rather excitedly. Fortunately my paperwork was in order and we were allowed to finish up and move on.
  4. chessterd5
    chessterd5
    from u.s.a.
    Bandit Billy likes this.
  5. GordonC
    GordonC
    Blues4U - The hood is kept on by a center pin that I welded on the hood which inserts where the normal A hinge would go on the cowl. I then used some standard hood hold downs on the two sides of the radiator. Seems to work ok so far. Here's a pic.
  6. KandN Kustoms
    KandN Kustoms
    Spay bombed the roof of my Rambler a couple weeks ago, if that counts? 20210404_130620.jpeg 20210404_130632.jpeg 20210405_172458.jpeg 20210405_172520.jpeg
    Sent from my SM-G960U using The H.A.M.B. mobile app
  7. chessterd5
    chessterd5
    from u.s.a.
  8. Mr48chev
    Older Waco Texas rodders will tell About Laddie Segrest painting his 32 Coupe with Gibsons true black spray cans. He used several cases of paint and color sanded between coats just as you would a high end spray job.
    If a guy is good with International farm tractor red the International Harvestor brand spray bomb paint is some seriously good paint. I painted the front of a tractor with it and the farm workers on the dairy washed it just about every day with a pressure washer and they didn't damage the paint work.
    My 48 had green paint over brushed on primer when I bought it in 1973. The car wash spray wand took a lot of the green paint off but didn't touch the brushed on primer and I block sanded a lot of that smooth and then primered over it again.
    Boat paint is pretty spendy but a lot of high end boats are painted by what is called rolling and tipping. Roll and area on with a roller and follow with a tipping brush to flow it out. That is on multi million dollar boats.
    Blues4U likes this.
  9. Flathead Dave
    Flathead Dave
    from So. Cal.
  10. Mike
    Mike
  11. Blues4U
    Blues4U
    from So Cal
    Ah, clever! Thanks for the info. One of these days I'm going to add a hood like that. BTW, that paint is just gorgeous, that came out really well.
    GordonC likes this.
  12. Blues4U
    Blues4U
    from So Cal
    I've used a lot of it over the years, I probably still have a few cans in the paint cupboard. They have a few other colors besides red, but not much. I used a lot of the flat black and the gloss black over the years. Like you said, good stuff.
  13. donsz
    donsz
    You might want to Google: "50 dollar rustoleum paint job" Many of the articles describe using a roller, some of them look pretty good (in the pictures at least).
  14. Casey Riley
    Casey Riley
    from Minnesota
    I'm learning a lot in this thread. I'm enjoying it. Thank you
    GordonC likes this.
  15. adam401
    adam401
    My car is brush painted. As I do the metal repairs I sand an area, fix it then brush it again. It'll get sanded back to metal again for a proper paint job eventually.
  16. Greaseballs
    Greaseballs
    I used this technique to paint the hull on my vintage Chris Craft Constellation when I owned it.....painted all 50 foot of her every season. I got so good at the technique that people thought it was a high-dollar spray job. Sanding prep work was key along with proper outdoor air temperatures and humidity levels and properly thinned epoxy paints. I've never thought of applying this technique to a hot rod.....until now!
    Blues4U likes this.
  17. 4woody
    4woody
    I'm going to brush/roller paint my truck in the driveway, but I live in a tightly-packed suburbia, so overspray on the neighbors cars would be a problem. I tried to get Tekaloid coach paint from the UK, but nobody would ship it to the U.S., so I settled on doing it with marine paint (EZ Poxy, which is not epoxy at all).
    I'm almost ready to paint the bumpers (The first parts to get a finish coat), and will post pics soon.
    warhorseracing, AHotRod and Blues4U like this.
  18. This works great in Rustoleum…...
  19. Here is a great video about Coach Painting as I mentioned. Not some backyard hack home depot paintjob.
    safetythird likes this.
  20. 280655_10150249369651687_2337233_o.jpg this is rolled-on Rustoleum. Been on there over ten years.
  21. Rusty Heaps
    Rusty Heaps
    8DEB3919-2602-46A2-B987-3D0982C52061.jpeg 6B975B0F-72A8-46F0-9D4E-DFA3557E1151.jpeg I’m at it again! Rustoleum oil based. Unfortunately I started with a Home Depot 4” roller, the lint started to pull off into the paint, swapped out for a Purdy 4”. It’s a 50 footer! But considering how rough the roof was anyway, it’s not bad.
  22. wheeldog57
    wheeldog57
    The Chevy was painted with Rustoleum through a gun 11 years ago. Still ok but I think it's time to do it over.
    The roadster is brushed on with tractor paint. Two coats with a good brush 24 hours apart. Had a couple of runs but they sanded out then re-brush.
    NoSurf, Rusty Heaps, adam401 and 4 others like this.
