Projects 1929 into 1930 rear fenders
Discussion in 'The Hokey Ass Message Board' started by chris 30 sedan, Mar 16, 2021.
  1. chris 30 sedan
    chris 30 sedan
    Ok I've been looking for a long time for nice 1930 tudor sedan rear fenders and no luck. I found a really nice set of 1928 29 ones . It is stated the only difference is the cut out for the running boards splash apron? Is this actually the only difference? If so has anybody just cut that part out to fit and made them work ? Seems like an easy fix if that's the case.
  2. Tim
    Tim
    from KCMO
    @flatout51 may know. Pretty sure he’s putting 28/9 fenders on his 30/1 sedan
  3. alchemy
    alchemy
    The tail has a slightly different arch I think, but as long as you have a pair it shouldn’t matter to a hot rodder.
  4. chris 30 sedan
    chris 30 sedan
    How do I message him on here?
  5. Tim
    Tim
    from KCMO
    I tagged him he’ll
    Comment when he sees this
  6. You cannot contact a member here until you have 10 posts. Try over on the Vintage Ford Forums as they have very informed members on the Model A.
  7. flatout51
    flatout51
    I just put 28-29 fenders on my 30 tudor and they fit better on it than they did on my 28 tudor. I am running 28-29 splash aprons and front fenders. The only difference I see is like you said, if you run 30-31 splash aprons you'll need to modify the fender to fit but should be super simple! 20210325_141911.jpg 20210325_142046.jpg 20210325_141911.jpg 20210325_142046.jpg 20210325_141928.jpg
    hfh, tiredford, Tim and 2 others like this.
  8. tiredford
    tiredford
    from Mo.
    Hey David is the fender that flew off the roadster while I was following you in Joplin. LOL
    flatout51 likes this.
  9. I'm liking Flatout51's A a lot. Looks like it was a solid body to start with, flathead power, car looks like it could have been built in the late '40s/early '50s. Should be a fun car to drive.
  10. flatout51
    flatout51
    Ha! No that was fiberglass and it ended up in a few peices!
    Sent from my SM-G977U using The H.A.M.B. mobile app
  11. flatout51
    flatout51
    It was FAR from solid haha! Its pretty good now. But thank you! Should be a super fun car!!
  12. Tim
    Tim
    from KCMO
    Awefuly weird looking roadster if you ask me lol
  13. flatout51
    flatout51
    Far more useful roadster! Haha!
    Tim likes this.
  14. The37Kid
    The37Kid
    I know there are early and late fender brackets, do the 28-29 and 30-31 use the same hole location on the outer bead?
    Bob
  15. flatout51
    flatout51
    The rears might. The fronts are a different shape fender all together
