Projects '34 Coupe Survivor (ish)
Discussion in 'Traditional Hot Rods' started by nutrocker, Jan 31, 2021.
  1. Jacksmith
    Jacksmith
    from Aridzona
    loudbang, Thor1 and Stogy like this.
  2. 34Larry
    34Larry
    No bad criticism intended here at all, I really, (to use a term from my generation)' DIG this coupe a lot,
    if this were mine I'd move that roll bar inside, (mine is), and patch that hole in the roof.:):):):):):):):)
    Besty34, Outback, B Bay Barn and 4 others like this.
  3. Mike Colemire
    Mike Colemire
    Love the car but agree with 34 Larry on the roll bar. Your work is out standing!
  4. Cymro
    Cymro
    Very interesting roll bar set up, How do you propose if at all to make it weatherproof? Wales is wet and windy.
    Love the look of this car and the fabulous workmanship.
    chryslerfan55, loudbang and Thor1 like this.
  5. Stogy
    Stogy
    Do like I do, if it rains don't go out, there are slicks too...maybe no wipers either...that's what Daily's are for, the shit days...I have faced these questions by numerous individuals and do explain it's a fairweather Hotrod...
    The other thing is a boot of some form metal or Fabric/leather fitted around the bars and covering the open area...@nutrocker and @KFC have surely considered the practicality of a mixed race/street Hotrod...
    6sally6, Outback, Jet96 and 6 others like this.
  6. KFC
    KFC
    from UK
    Unfortunately a sanctioning body got involved in pendine and roll bars are mandatory over 100mph and they have to meet certain requirements, x distance above and behind the drivers head, that’s where the roll bar lands.
    Personally I like it it’s appropriate to the build, to many modern 34’s end up all smoothed out and manicured. Plus it might get chromed!
    It’s also all removable and will have a fill in for the roof when not in use.
    there is a scoop under development for when I don’t want the water down the back of my neck!
    Inspiration ;)
  7. nutrocker
    nutrocker
    Like Rik (KFC) has said, it’s down to the rules. If we want to run the car at Pendine Sands, and who wouldn’t want to do that?, then it has to have a roll bar that fits within the rules. Those rules state that a roll bar has to be a minimum of 3” above the drivers head with a crash helmet on. The car has a heavy channel, heavy chop and a large motor set back in the frame. Add to that a driver of 6’, the options are very limited to build something that’s fits the style of the car.
    Hotrods are all about individual taste and making something work better than it was. Form and function. I think this car has both, and keeping the essence of the original build. It’s been a tough ask over the build, and some compromises have been made, but never for an unnecessary reason.
    It takes balls to do something like this and I think it looks tough as fuck.
  8. Stogy
    Stogy
    Grrrrrrr!!!! just Grrrrreat Stuff...Stunner of a Hotrod indeed...Start it up and drown out the noise!! I like those patches around the bar on that Chevy Coupe...looks like an aircraft mechanic had at it... @nutrocker that cover is Pretty unique as well...does it double as a vent and also allow the upper bar to remain attached?
  9. sweet!
    loudbang and Stogy like this.
  10. Stogy
    Stogy
    @nutrocker, what's the latest on the MMF...Yes MMF is crass but fitting cause it's TAF...:D
    chryslerfan55, loudbang and brady1929 like this.
  11. nutrocker
    nutrocker
    I have no idea what MMF means, must be lost in translation.
    As you know Rik has the car back and is getting on with it.
    The motor has gone off to be properly cleaned after being in the metal dust environment of my workshop.
    The guy who Rik was hoping to do the small bits of bodywork isn’t available so the body has gone to another Hotrod shop to get that sorted.
    Meanwhile Rik is moving on with some of the other bits.
    I’m sure he will update the thread when there’s more to see.
    Pete.
    Outback, chryslerfan55, rod1 and 5 others like this.
  12. Stogy
    Stogy
    Mean Mother F...and Tuff as F...I'll let you fill in the rest...the Tuff one was your description...;)
    Thanks for the good news...It's coming together...thanks Nutrocker...
  13. nutrocker
    nutrocker
    I knew the TAF one, just couldn’t work out the MMF.
    Now I know.
    chryslerfan55, loudbang and Stogy like this.
  14. Tim
    Tim
    from KCMO
    Saw it pop back up on Instagram glad to see it’s moving forward :)
    loudbang, Stogy and nutrocker like this.
  15. KFC
    KFC
    from UK
    Not a great deal of progress, the car is now stripped and off for body work at buckland automotive before the body comes off the chassis. The block is away being cleaned but covid has made that a long job.
    I had a play and fitted up a few of the parts I’ve been saving for this car. Belts seats gauges switches etc.
    got some mercury 15*5 with 5.70 tyres to try on the front had 15”*6 with 6.00 before
    Oh and the roll bar got chromed. Should see some progress soon 9126A8CB-C7AF-4E3E-8405-4CDFE4734CBC.jpeg 144F1B5A-335B-45BE-B753-64122DED94B7.jpeg 83B66368-F040-434B-96DD-6EC0A3C35FF4.jpeg 8853F6CC-887E-43B8-B2EF-60CA9E1AA27E.jpeg 63EB93C8-9CD8-45DA-8338-DE34DC505484.jpeg Things are progressing slowly
  16. KFC
    KFC
    from UK
    Well things are progressing slowly, but there’s no rush
    Chassis powder coated
    I decided to polish my springs, they will be oiled and left bare
    Bake plates chromed and painted, ladder bars plated
    Front spring shape, new main leaf made and various chrominance
    Column and steering gear chromed
    Picked up some dimple valve covers
    5.60 15” for the front and body getting filled
  17. nunattax
    nunattax
    from IRELAND
    all very nice who makes the pedal bracket??.i did a similar drilling job on my brake pedal but counter sunk the holes giving the effect of bigger holes without removing too much metal
    chryslerfan55, KFC and Stogy like this.
  18. aussie57wag
    aussie57wag
    from australia
    That is way cool. Perfect running gear.
  19. j hansen
    j hansen
  20. Stogy
    Stogy
    What a work of Hotrod Art...truly across the pond excellence...what a joy to be witness too...you have a great eye @KFC...you must be pretty excited...I sure a heck am...;)
    brady1929 and KFC like this.
  21. rod1
    rod1
    Looking Great! Very Nice detail throughout..
  22. Jacksmith
    Jacksmith
    from Aridzona
    A rolling jewel...
  23. Nailhead A-V8
    Nailhead A-V8
    Beautiful workmanship! Gorgeous car...I personally find the whole roof thing unsettling it would drive me nuts!... I probably would have made the entire body independent from the chassis w a plate to hold the column for a tilt then raised the body on some blocks when I wanted to sand race...couple hours and a cherry picker away you go... stock grille for sand, chopped for street
  24. Tim
    Tim
    from KCMO
    Far out
    Stogy and KFC like this.
  25. KFC
    KFC
    from UK
    fat lucky or something like that, don’t think they do them any more
    Stogy likes this.
  26. KFC
    KFC
    from UK
    things like that are a nice idea but I’d never do it in reality.
    chryslerfan55 and Nailhead A-V8 like this.
  27. goldmountain
    goldmountain
    That hole in the roof problem could be easily solved; get a short guy like me in the car.
  28. CrazyDaddy
    CrazyDaddy
    from Austin TX
    Traditional engineering at it's finest !
    Stogy likes this.
  29. Nailhead A-V8
    Nailhead A-V8
    You did the right thing...it was a race car and you're going to race it again that's the main thing ...I was actually thinking more of wind, noise, sun, rain etc. than aesthetics ...it looks killer
    Stogy and chryslerfan55 like this.
  30. SS327
    SS327
    At least paint that front spring. No sense it dripping rust all over that nice chrome and powder coat.
