Projects Dynamat alternative
Discussion in 'Traditional Hot Rods' started by TBonez, Apr 1, 2021.
  1. TBonez
    TBonez
    Gettin ready to put some sound deadening material in the ‘29 and the only one I’ve heard about is Dynamat. Pricey but willing to spend the coin unless there is a product out there that works just as well at a lesser cost. I was also thinking of glueing jute padding on top of it for an extra layer of sound barrier.
    Stogy likes this.
  2. saltflats
    saltflats
    from Missouri
    I have used the Peel & Seal, seems to work good.
    hidez57, 31hotrodguy, reagen and 6 others like this.
  3. 55blacktie
    55blacktie
    Big-box store.
    hidez57 likes this.
  4. Gammz
    Gammz
    from Lincoln Ne
  5. ^^^^^^^^^like he said. The Killmat works great and costs way less.
    Stogy, lothiandon1940 and SlamIam like this.
  6. Bigdavid
    Bigdavid
    from Tennessee
    I don’t know about the jute padding though,they say it wicks up moisture and holds it.
    Stogy likes this.
  7. BJR
    BJR
    I used Killmat in my 49 also.
    Stogy and SlamIam like this.
  8. sloppy jalopies
    sloppy jalopies
    IMO... use the jute, but don't glue it down, it holds moisture...
    Stogy likes this.
  9. Mimilan
    Mimilan
    And Jute stinks when damp for a few days.
    The OP should try Acoustic foam, or closed cell foam (used for holding heat in swimming pools)
    Stogy likes this.
  10. oriewall
    oriewall
    I used killmat in the 57 Chevy, good price easy to work with.
  11. TBonez
    TBonez
    I’m nixing the jute padding idea. Checked out the killmat n also found Noico on Amazon. Both look like they’ll do the job
    Stogy likes this.
  12. Sum54ford
    Sum54ford
    from St. Louis
    8C7FD9C4-6C85-4A48-A07C-F11589D3C1E3.jpeg F4436FD2-144C-4E81-ABF1-16C6E7AC2928.jpeg I used the Kilmat in my 51 Merc. I would definitely recommend it.
  13. SlamIam
    SlamIam
    Used Kilmat here with Noico insulation over it
    Stogy likes this.
  14. rusty rocket
    rusty rocket
    Go to a Lowe’s and get the sealing tape for around windows, I believe it’s about 10” wide. I used it in my deuce sedan but it’s been a number of years ago.
    reagen and Stogy like this.
  15. 47chevycoupe
    47chevycoupe
    from Finland
    EDIT:
    I was living in Missouri at the time I had installed the window seal tape. The truck was black and it always sat outside.
    A few years ago I used this on an OT truck door. It worked but after a couple years it started to melt and it ran down the inside of the door and out the weep holes and down the side of the rocker panels.
    Stogy likes this.
  16. Blues4U
    Blues4U
    from So Cal
    I've used it as well in a couple of cars, with very good results.
    Beware of the Eastwood stuff, someone here posted a thread where the asphalt ran out and made a mess when it got hot.
    Stogy, lothiandon1940 and saltflats like this.
  17. Almostdone
    Almostdone
    I spent quite a bit of time last year asking myself which sound deadened to use in my Model A. Finally decided that every thing else is compared to Dynamat (which yes is more expensive than others), so I just bit the bullet and went with Dynamat. I used the Extreme everywhere I could attach it, the Dynapad in the roof and inside of the firewall, and finally added Dynadeck over the floor.
    Super nice.
    John
    Stogy, nunattax and 61SuperMonza like this.
  18. rusty rocket
    rusty rocket
    Haven’t had a problem with mine and the car has been on the road for five years.
    Stogy and Blues4U like this.
  19. Another vote for Kilmat
    Used it in my 30 and my buddies 32
    Chappy
    lothiandon1940 and Stogy like this.
  20. Never2low
    Never2low
  21. modagger
    modagger
    After reading as many posts as I could here about this topic, I went with Peel and Seal from Lowe’s. Prepped everything really well and it went on and stayed where I put it.
    Never any odor, even from the firewall area which gets a bit toasty during warm summer days. The hotrod bumps and bangs are still there, just not as sharp sounding.
    I’m satisfied with the product, and with the money I saved over the cost of the more expensive, “made for” products out there.
    It did cut down on the amount of heat radiating through the firewall too.
    BigChief, reagen, Blues4U and 3 others like this.
  22. V8Vic
    V8Vic
    from norcal
    I used Noico in my ‘30 Victoria. Did everything I could get to and as I remember it took less than 2boxes. Each box was 36 square feet and cost about $68 a box. I used the black color as I figured I wouldn’t complete the interior for a while and didn’t want to look at all that silver. Reasonably priced. REALLY deadened the sound. Very happy with it so far.
    DC0D6192-B2FB-429C-9305-8726A30C3E0E.jpeg ECAD56E9-59D9-4938-84F0-7DBC1CF88B81.jpeg 487D93A0-D8FC-4794-B2C0-7161F56882AC.jpeg
    Stogy likes this.
  23. I used the stuff which is fitted under corrugated steel roof sheeting, about 1/4" thick, with reflective stuff on each side. It's called Kingspan here, probably something similar available in the U.S. The best bit was that it was free offcuts from a commercial roofing job.
    Stogy likes this.
  24. gene-koning
    gene-koning
    Noico black on 3 vehicles now. Cuts down on heat transfer and does a great job at sound deadening. Doesn't have their name plastered all over it. Gene
    V8Vic and Stogy like this.
  25. 61SuperMonza
    61SuperMonza
    There are many different products for sound and heat suppression. I used Dynamat and am very pleased with it. I used it because it was stocked in town and with shipping other products would have cost almost as much.
    Bottom line is these products really work well. The difference in my car was crazy.
    Stogy likes this.
  26. 97
    97
  27. Stogy
    Stogy
    I suspect these anomalies could be related to Climate and storage of the vehicle...ie outside versus inside...he's in Finland which I don't necessarily associate with hot high temps but as we know in enclosed vehicles when all the windows are up on a sunny summer day temps over 100f are not unusual...assumption on my part but these are my first impressions...
  28. indyjps
    indyjps
    kilmat in my daily, works great.
    Lobucrod - bought some for my project - havent driven the car yet. Site seems dead, I cant find a source for it now.
  29. ydopen
    ydopen
    I used Rattletrap by Fatmat in my roadster. No problems. If I remember they had free shipping.
    Cheaper than Dynamat.
    John
    bobss396 likes this.
  30. flynbrian48
    flynbrian48
    Me too. $16 for a 25’ roll, 5 rolls did the flirt and riff of my ‘52 DeSoto wagon. Great stuff.
    saltflats and Blues4U like this.
