Projects turning a sedan into a coupe 1930
Discussion in 'Traditional Hot Rods' started by sigfurniture, Dec 7, 2020.
  1. sigfurniture
    sigfurniture
    Evening!.. The grill cowl arrived from the states.. So time to properly position the motor.. I was worried about having the horrible "long nose" look.. But also don't want to hide too much of the engine inside the bodywork. One of the tricks has been to flip.. Widen and move back the second chassis crossmember.. Which has meant I can lower the gearbox a decent amount.. And thus the engine a bit.. I moved the engine about 5cm backinto the body and will have to entend the radiator support another 5cm (2 inches).forwards..the client wants to keep the original fan and water pump set up for the caddy v8.. Which is long.. Here's a couple of pix. I'll be working on reinforcing the wooden framework ready for floors etc tomorrow. What do people use for floorboarding over there?.. Pine or oak? IMG_20210220_230842.jpg IMG_20210220_122847.jpg
  2. roddering
    roddering
    from Arizona
    Great job and you have some impressive skills as a fabricator!
    Stogy, sigfurniture and loudbang like this.
  3. sloppy jalopies
    sloppy jalopies
    Oak, Ash, or Maple subrails... plywood floors... was the way...
    I would use steel rectangular tubing and weld / rivet the a+b pillars and braces to them...
    IMO... don't spare the steel channel shaped verticals, they help support the body to frame's rigidity...
    x braces under the rear window and maybe a shallow X just ahead of the lower panel...
    oh, and i like the way the body is looking.... and from a fordor at that...
  4. sigfurniture
    sigfurniture
    Sorry for my absence guys. I've been doing a 1974 mini.. But now I need to get paid so back on the rod.. Working on the interior this last week
    .. Fuel tank is in.. Fits tight.. Don't know what car it came from.. B pillars reinforced.. A pillars on the way. Tunnel mostly sorted.. Drip rails on.. Rumble seat sorted out.. Rear firewall panel sorted and recessed front wall.. I need the client to bring the seat in to locate the ideal position fit handbrake and pedals.. I've been enjoying it.. I like this part of the process.. It seems more creative. Here's the pix IMG_20210320_111722.jpg IMG_20210320_164331.jpg IMG_20210320_174445.jpg IMG_20210320_164413.jpg
    AHotRod, tb33anda3rd, Blues4U and 9 others like this.
  5. Bugguts
    Bugguts
    Great job so far. I initially doubted the outcome, but you have proved me wrong. The car really does look cool!
    Thanks for taking us on this ride with you.
    inaford30, sigfurniture and loudbang like this.
  6. sigfurniture
    sigfurniture
    Thanks mate.. I wasn't too sure myself still tons to do but enjoyable stuff
  7. perry parsons
    perry parsons
    been following your build, excellent workmanship. I built a pickup from a 29 Murray Fordor .
  8. sloppy jalopies
    sloppy jalopies
    truck looks to be of Canadian manufacture... go pp go !
  9. panhead_pete
    panhead_pete
    Odd kunji on the mini, Japanese owner that loves England?
    sigfurniture likes this.
  10. The37Kid
    The37Kid
    I like the chop, how tall are the window openings now? Bob
  11. sigfurniture
    sigfurniture
    I'm pleased it's readable.. Something I made up with a Japanese friend.. The overall aesthetic is based on the Japanese zero fighter planes
  12. sigfurniture
    sigfurniture
    I took 8cm out.. As I remember.. I'll measure it when I get back to the workshop
    The37Kid and loudbang like this.
  13. sigfurniture
    sigfurniture
    27cm inside the front window opening.. Nearly 11 inches in your money remember the frames are arched on this IMG_20210324_120434.jpg
    brEad and loudbang like this.
  14. sloppy jalopies
    sloppy jalopies
    Seeing your mock up i notice that your grill and lights will mount forward of the front crossmember by about 4".
    prop some wheels where they will be to see if you like it...
    around here some guys will run a cheaper S10 frame, but unless you move the engine back it forces the grill and light too far forward of the wheels...
    a local '29 Essex might be the prime example that we have seen around here....
    looked like a doeberman with its ears taped back...
    i am guilty of running a pinto front end, the rack bolts force the grill to be a few inches too far forward... pic...
    makes my coupe look a little nosy...
    i would change it "today" if it weren't so much work...
    if it bothers you, now is the time...
    Nailhead A-V8 likes this.
  15. sigfurniture
    sigfurniture
    Yep I know sloppy it my biggest worry actually.. I want the car to look squat and compact. Actually the 27 hood fits perfectly but as I remember my 27 had a narrower cowl which would explain why it fits.. The axle set up is ordered and should arrive in a month or so.. I can't push the engine any further back without it also looking dead weird.. It'll be a case of bending the rules but not breaking them I hope
  16. sloppy jalopies
    sloppy jalopies
    so those shrinker - stretchers won't stretch your frame ? ... damn!
  17. sigfurniture
    sigfurniture
    Mock up.. Pretty nosey.. But I reckon it still seems more or less trad!?? I think the grill needs to come down a smidge! IMG_20210324_170223.jpg IMG_20210324_170235.jpg IMG_20210324_170250.jpg
  18. The37Kid
    The37Kid
    You have the reverse of this car, you have a 28-29 Fordor cowl and normal hood, note the bead in the hood tops that mate to the cowl bead. Bob
  19. sloppy jalopies
    sloppy jalopies
    doesn't look nosey... the grill seems to sit over the crossmember, that's good !
    loudbang and sigfurniture like this.
  20. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    The cowl feels a little long, but not hating the car at all. Still putting fenders on it? Its really come a long ways, your're making great progress on it
    loudbang and kidcampbell71 like this.
  21. sigfurniture
    sigfurniture
    Yep the hood is one I have hanging around.. It won't be used as such but helps with the geometries it's the hood that tells me the grill needs to be lower
  22. sigfurniture
    sigfurniture
    Yep he still wants the full works.. Although it'll be takeoffable.. The fenders will open a whole new can of worms I'm sure
  23. sigfurniture
    sigfurniture
    Threw some primer on so I can see the mistakes easier.. My eyes aren't what they used to be
  24. The37Kid
    The37Kid
    The 1928 - 1929 Fordor/Cabriolet cowl is the longest cowl in all of the Model A's. Just checked one of my doors and if I cut 3 1/2 inches out the windows will look the same.
    Bob
  25. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    @sigfurniture fenders will be a pain for you, but they will really seal the deal on how the car looks.
  26. thewishartkid
    thewishartkid
    That cowl would look a lot better shortend
  27. sigfurniture
    sigfurniture
    The thing is if the cowl was shorter the hood would have to be longer.. So it would still look the same.. I'm at absolute minimums with the cadillac engine
  28. sloppy jalopies
    sloppy jalopies
    i say no, don't shorten anything... the quarter windows are a little longer , with a chop top the longer cowl goes with the rest...makes it a special model a ... i like it stretched...
  29. The37Kid
    The37Kid
    The "Long Cowl'' is a really unique feature, just think of the work Ford put into it to, same wheelbase on all A's and they shortened the doors to adjust things so the same length hood would fit.
    Bob
  30. sigfurniture
    sigfurniture
    OK I need some help from you guys please as I'm flying blind here.. The fender kit that was bought was not from this exact car also its quite bashed up.. So I'm trying to figure out how it should sit.. The rear seems straightforward.. But the front seems way too long. Bearing in mind its all set higher up towards the body.. Give me some clues please. What should line up with what...? IMG_20210326_094457.jpg IMG_20210326_094422.jpg IMG_20210326_094438.jpg IMG_20210326_094432.jpg
