Technical Would this be accepted on a traditional Hot Rod?
Discussion in 'The Hokey Ass Message Board' started by GraeffSS, Feb 18, 2021.
  1. hudson48
    hudson48
    Stogy and ekimneirbo like this.
  2. studebakerjoe
    studebakerjoe
    For some suspension ideas check out issues of Honk magazine. I think it was the July 1953 issue that showed how to build a torsion bar suspension using custom made bars and model A shock arms. It was used with straight axles. They also had a series of articles on building a swing axle rear from Ford parts. I always thought with a bit more work you could add a second outer u-joint and build a fully independent rear or a DeDion type setup.
    AHotRod and Stogy like this.
  3. Squablow
    Squablow
  4. Stogy
    Stogy
    Yes, way ahead of it's time...and it truly was a far more complex and innovative time than we could imagine...some of it did certainly influence Hotrod without question...one just has to be careful how its presented...
  5. The37Kid
    The37Kid
    DSCF0122.JPG DSCF0121.JPG There will always be room for an Allard here. Bob
    wicarnut, KevKo, alanp561 and 2 others like this.
  6. dumprat
    dumprat
    from b.c.
    All of the examples posted except the ford twin I beam have the same problem. The axles are too short. They need to extend to the opposite frame rail. The point where they crossover would be the roll center. Without the crossover point the front roll center may or may not end up somewhere between the axle pivot point and the load center of the spring. Couple that with a roll center too low on the rear and poor anti squat and you will end up with a car that packs the front wheels in corners.
    It's geometry folks.
    Stogy, X38 and 31Apickup like this.
  7. Heck yea.
    Doesn’t have to be cookie cutter to be trad.
    There is nothing more traditional than incorrect geometry.
    Plenty of examples of guys trying and experimenting.
    heck, Ive read stuff about split bones being bad.
    Seen plenty of incorrect math turn laps around tracks.
    VANDENPLAS and Stogy like this.
  8. Stogy
    Stogy
    :rolleyes:...a period suspension shared...
    :rolleyes:...Nates seemingly inspired modern offering shared by @hudson48...
    I have looked at vintage patents and many of them were beyond ingenious and went on in whatever fame they garnered...Many times those in the know can in fact recreate past Excellence and offer it up again with successes not realized back in the day...
    There are also other suspensions depicted here and this one by Nate's may have evolved in inspiration from several directions but it certainly is much more plausibly Hamb friendly noteably lacking that non accepted here billet look...
    I reference the Blair Roadster as it truly is a period Hotrod and it always disturbs me to see genius tossed out in the trash so to speak...AND it actually looks pretty sharp...I wonder how it performed...
    Anyone know?​
  9. Stogy
    Stogy
    Anthony I don't like to debate Traditional but I know a Bonified Vintage Hotrod worthy of Hamb presence when I see it...Again I like the Kooky face on Blairs Roadster because his genius certainly inspired the evolution...
    Hokey Ass is My playground because I enjoy the BIG Picture...;)
    The37Kid and anthony myrick like this.
  10. deucemac
    deucemac
    actually, because of the very long moment of the axle, very little change in camber occurs. But the guy doing the alignment has to know just how to bend them. The real problem with the twin I beam is shocks. The axle is so long and heavy, it over works the shocks and you see it in cupping and weird wear patterns. Properly aligned and good shocks matched to the vehicle weight and they are very easy on tires. The real problem was a mechanic that was in a hurry or didn't understand the geometry of the system and doing no favor to the owner. I did hundreds or even more of them and took the extra time to ensure everything was correct. Plus, I made sure that the vehicle was loaded to what it normally carried. Guys would bring in a 1 ton truck empty and you would inspect the bed or platform and could tell it was usually heavily loaded. Those trucks and vans need to be aligned basedon the weight they normally have loaded on them. If not there will be problems.
    Stogy and rod1 like this.
  11. F-ONE
    F-ONE
    from Alabama
    I'll say this...
    A lot of those designs remind me of the M151 Mutt Jeep. The M151 is why the government suspended surplus Jeep sales and started cutting them in two. The 151 had independent front and rear suspension.
    From what I understand it was OK off road. On pavement it was deadly especially for those used to how the old straight axle jeeps drove. It was unpredictable and prone to the axles rolling under it laterally causing it to flip.
    ^^^This image here is what reminded me of the Mutt.
    There may be a pretty good reason these designs are...uncommon. When it comes to designing front suspensions....You better have your A game.
    Kaiser/AMC had their A game when they designed the Mutt and...
  12. The cornerstone of Ralph Nader's famous destruction of a car.
  13. Just because it's not traditional doesn't mean it is not period correct.
    Duffy Livingstone's Eliminator had a 4 link in 50's
  14. The37Kid
    The37Kid
    Jimmy Frankland had a four bar on his Stagger Valve Fronty Sprint Car in the late 1930's.
    Didn't the LOTUS 11 use a split English Ford I beam along the same lines as the Allard?
    Stogy likes this.
  15. Stogy
    Stogy
    :rolleyes:...@GraeffSS thanks for bringing this alternative to the revered more commonly used front suspensions...I don't believe Blairs Suspension effort was a Hack job by any means...he utilized a similar duty/weighted front suspension out of a period vehicle available at that time and mounted it much like any of the numerous swaps to modify Hotrods at the time were performed...Remember not ALL were Hacks...
    He was known to be a modifier that wasn't brand conscious so to speak and he went on to become quite a successful Racer, Hotrodder and Businessman...
    I have witnessed and shared this Dry Lakes Roadster many times in the Homogenized Thread trying to Correctly Identify what he actually used...I can't remember off hand if we did have a match to date...
    Sorry long winded but again I don't believe hack was in Blairs repertoire...I'm making an assumption here but I defend his innovation...
  16. Stogy
    Stogy
    This what you speak of is kind of a case of if they knew then what we know now but it certainly doesn't mean it shouldn't be reproduced or experimented with in a period way to improve shortcomings...
    Secondly under most normal driving conditions it may have performed well and in many cases better than the more typical applications of the time...
  17. dumprat
    dumprat
    from b.c.
    @Stogy i agree completely! Sometimes old ideas revisited can become brilliant new ones!
    anthony myrick and Stogy like this.
  18. AccurateMike
    AccurateMike
    Leslie M. Ballamy started splitting axles and selling kits in 1933. https://en.wikipedia.org/wiki/Leslie_Ballamy. This car shows a swing axle. I'm just trying to wrap my head around the steering linkage. What goes on in the middle there? [​IMG]
    Mike
    ClarkH, Stogy and anthony myrick like this.
  19. gnichols
    gnichols
    from Tampa, FL
    So did the Kookie T, I just realized recently.
    Stogy likes this.
  20. gnichols
    gnichols
    from Tampa, FL
    Dominator Street Rods offered a "Twin Tube" front axle design for early Fords (the hot rodder's version of the Ford truck Twin I-beam design) for some time, but I couldn't find it listed on their site. I visited their shop a few years ago and saw their front frame sample, it was fantastic. Engineering wise, those guys know how to do stuff right. Perhaps they still make them?
    http://dominatorstreetrods.com/chassis-suspension
  21. oldiron 440
    oldiron 440
    From almost 70 years ago...
    Photo is from 1953, AC as in AC Cobra fame.
    GraeffSS, loudbang and Stogy like this.
