Technical Powerflite question
Discussion in 'The Hokey Ass Message Board' started by Caprice89, Feb 6, 2021.
  1. Caprice89
    Caprice89
    Hi. This week I will be working on a Facel Vega, a French car from the fifties with a Mopar power train.
    https://en.wikipedia.org/wiki/Facel_Vega?wprov=sfla1
    There is an issue with the Powerflite transmission. When in reverse, at first, it will not react to any increase in engine revs and suddenly, it will take of. So I'm told.
    I have never worked on these types of transmission, so I thought I do some research. I cannot find a lot of documentation online.
    Any suggestions where I can find any troubleshooting information on them? Or some clever thoughts on the problem?
    Thanks in advance.
    Sent from my online shouting device
  2. 302GMC
    302GMC
    from Idaho
    oldcarmanualproject
    Caprice89 and Hnstray like this.
  3. Rusty O'Toole
    Rusty O'Toole
    Suggest you start by changing the fluid and filter if this has not been done. Symptom suggests a clogged filter especially if it is worse when cold.
    Inspect the bottom of the oil pan for debris. The less there is the better. There may be some soft dark matter worn off the clutch plates but a large amount of metal shavings is bad news.
    On the newer Torqueflite transmissions there is a seal on the reverse piston that sometimes fails, then the car will not go into reverse gear. It is not hard to replace or expensive when you have the pan off.
    This video shows changing the fluid and filter, and replacing the reverse gear piston seal on a later Torqueflite.
    Caprice89 and stillrunners like this.
  4. AndersF
    AndersF
    If it wireoperated as on Chryslers you could check the adjustment.
    In neutral the peg that activate starters safetyswitch is in the middle of the hole.
    When you remount the safetyswitch you need a Ohm meter or something similar.
    Screw it in slowly until it make contact on the peg. Then about 3/4 turn and it right adjusted.
    Caprice89, Hnstray and stillrunners like this.
  5. Caprice89
    Caprice89
    I have found this. Sweet!
  6. Caprice89
    Caprice89
    I will certainly check all the linkages
  7. 51 mercules
    51 mercules
    If it doesn't work out I have a rebuilt one I'm not using. [​IMG]
  8. d2_willys
    d2_willys
    from Kansas
    Reverse band is stuck or warn. Reverse band servo is not sealing. If the Powerflite has a reverse pressure port, use an oil pressure gauge and check for proper pressure when in reverse
    . Older Motors manuals have troubleshooting and pressure charts
  9. Caprice89
    Caprice89
    Thanks all. I'm going to work on it Thursday. I will see what I can find.
  10. Caprice89
    Caprice89
    The servo for the reverse brake band has very much free play. Other than that, it looks fine.
    I had to close it up; the owner wants it moved. Too bad. I guess he will be shipping the car to transmission expert.
    AndersF likes this.
