Hot Rods Is there a market for 7 pistons
Discussion in 'The Hokey Ass Message Board' started by loc8tor, Feb 6, 2021.
  1. I picked up a few pistons n rods recently. Look to be Jahns, for a 283 chevy. Unfortunately only have 7. Would it be better to try and market them individually? Or ? 20210205_120006.jpeg 20210205_120019.jpeg 20210205_120024.jpeg 20210205_120012.jpeg
    Sent from my SM-G970U using The H.A.M.B. mobile app
  2. GordonC
    GordonC
    I think I would spend a little time to clean them up so folks can see if they really are in useable shape or not. It will help your sale. Price will dictate if they will sell as a group or not.
    Hnstray and loc8tor like this.
  3. BJR
    BJR
    Why not sell them buy one for..$ or 7 for...$. Then you have both covered.
  4. Recently got them, thats next on the list
    GordonC likes this.
  5. Rickybop
    Rickybop
    Am I wrong in thinking that no one is going to want to put used pistons in their engine?
    Maybe just the rods.
    kidcampbell71 likes this.
  6. There is a market for used pistons like those. Maybe not worth a fortune, but I wouldn’t be scared at all of throwing them in a 283 if I could get the last one.
  7. 34Phil
    34Phil
    not a streetable compression
  8. partsdawg
    partsdawg
    from Minnesota
    There are those out there who would buy 7. I have done that in the past.
  9. Budget36
    Budget36
    So did the OP;)
    Someone may need one, and buy them all if it’s a tough piston to find.
  10. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I think the 6-cylinder 230 / 250 Chevies have the same bore. Maybe useful in a HAMB dragster w/ a six. Plus a spare.
    That is an old looking ring size package. Modern pistons use lower tension (skinny) rings.
    The pin clips are missing too. I wonder if the rods are pressed in or floating?
    Hnstray, dogwalkin and lake_harley like this.
  11. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Clean them up and sell them ( give them ) to a Trophy - Awards business so they can make car show trophies.
    clem and egads like this.
  12. 51504bat
    51504bat
    If you can't find someone who wants them for what they are.take them to a swap meet and sell them to some artsy type to make whatever.
  13. partsdawg
    partsdawg
    from Minnesota
    We used to build grenade motors way back when. Buy a bunch of cheap stuff at swapmeets and asssemble a engine to see if it would run. 7 pistons like these and another that looked close. Some old cam with no specs from one swapper,lifters from another guy, heads from another. Screw it together and see how long it would hold up under flogging on the dirt roads back home. Inexpensive fun.
    302GMC and Budget36 like this.
  14. Great idea!
  15. Yea, they would definitely be cool trophy material.
  16. wvenfield
    wvenfield
    Many? Some? My buddy threw used pistons in his 350 to get his car on the road. It's just a casual driver. I don't know, that was like 18 months ago. Still running great. I should note though, they were gave to him for nothing.
    So I would argue, yeah someone could use them. Probably get a few bucks out of them. It depends if you know 7 people who need one or one person that needs 7.
    Us retired guys will use what we can get.
    guthriesmith likes this.
  17. bangngears
    bangngears
    from ofallon mo
    Grenades. Good for trophys
  18. jimmy six
    jimmy six
    Sure 6 + 1 extra.... it’s the way I always buy them..
    J. A. Miller likes this.
  19. Jethro
    Jethro
    The 283 pin height is the same as the 230 , 307 pistons will work in a 250.....I think you need to build a hot 230 , six slugs and a spare!
    302GMC likes this.
  20. 56sedandelivery
    56sedandelivery
    Grenade motors? I used to call them welfare motors. The connotation is pretty obvious there. I have bought used pistons many times, and even built a few engines with them. As long as the skirts are't ate/beat up, and the ring lands are good, they're good to go. No special balancing either; they ran and lasted just fine. I'd be more concerned that those are an older, cast piston, and not as well machined as more modern cast pistons. Some of the rod caps are reversed, and it's difficult to see if they're 1rst or 2nd design small journal with the dirt and rust; I'm guessing 1rst, and that would go along with the pistons "age". First, second, third, fourth, fifth, sixth, and seventh place; everybody wins something! What the heck did I hit to wind up with this font?
    I am Butch/56sedandelivery.
  21. 34Phil
    34Phil
    Even though same compression height 230 has 1/4" more stroke so high comp is now very high compression.
  22. If they fit my BUICK, I would buy just to get two! Replacing the two scored is EXPENSIVE.
    Ben
  23. moparboy440
    moparboy440
    from Finland
    There is for airplane guys :p
  24. Joe H
    Joe H
    283 pistons are drop in for a 230 inline six, 307 fit the 250 inline, both without any modifications to piston, rod, or crank.
  25. If they were .040 over 307s I could use them in my 250. Mitch
