49 8BA in 1934 Ford
Discussion in 'The Hokey Ass Message Board' started by Airborne34, Jan 9, 2008.
  1. patmanta
    patmanta
    from Woburn, MA
    1. MASSACHUSETTS HAMB
  2. tubman
    tubman
    I looked at the Speedway spacers, and they appear to be just spacers; the ones I made had the mounting bolts slightly offset, like the ones pictured in post 28.
    Another Speedway product that's not quite right?o_O The price looks better though.
  3. rusty valley
    rusty valley
    yes, the bolts need to be offset. i have two 34's with 59 motors in them, and the U spacers i made ended up being different heights! different by about a half inch. why? i dont know, but the motor placement is not forgiving. you must have the front pulley crank bolt centered where the hand crank loop is. any higher, the breather tube is hitting the firewall. any lower, the lower radiator hoses wont clear the front cross member.
    hotrodA likes this.
  4. fordcpe
    fordcpe
    Don't do it way to much work and very tight. 100_7710.JPG 100_7711.JPG 100_7714.JPG 100_7713.JPG
    fartman likes this.
  5. adam401
    adam401
    I have a 34 5 window with and 8ba hooked to a 34 trans. I used a 35 truck firewall and the u brackets on the engine mounts. The one thing thats still a pain in the ass is the upper radiator hoses. Its a tough angle with a stock radiator. I replaced the upper necks with model A lower ones to help with routing the hoses. I'm still noodling it out.
    fartman likes this.
  6. flatheadphilo
    flatheadphilo
  7. flatheadphilo
    flatheadphilo
