Projects Shoestring Shoebox
Discussion in 'Traditional Customs' started by fordcoupeguy, Apr 30, 2020.
  1. manyolcars
    manyolcars
    I found out that the quickest way is to drill the hinge bolts out
  2. T&A Flathead
    T&A Flathead
    Using de-arched springs. There is probably some junk in the trunk too.
  3. fordcoupeguy
    fordcoupeguy
    Hi guys, well the T is done and gone so now Im back to my own stuff.Finishing up my 33 Chev PU then its back to the shoebox. Will have some more pics in a week or 2
  4. fordcoupeguy
    fordcoupeguy
    Got a new computer and had to re register but Im still old ford coupe guy. I will try to get it back but Im not sure how.
  5. brokedownbiker
    brokedownbiker
    Contact a moderator, you should be able to keep your old handle.
  6. fordcoupeguy
    fordcoupeguy
    Okie Pete and warhorseracing like this.
  7. fordcoupeguy
    fordcoupeguy
    Finally had time to work on the 51. Got the hinges off and yes, I had to drill them out. Ordered new ones. Next I have to take that crease out of the quarter. I thought the hinges were worn but it turns out some of the pins were broken. Cool pin striping on the glove box done many years ago.Found a whole bunch of lead on the front of the hood. Does that make it a lead sled?lol
  8. fordcoupeguy
    fordcoupeguy
    The car is in the shop and Im working full time on it . I chose to install an aftermaket front end kit so I am not sure if this build should be here now. Please advise.
  9. Do not mention it past here or show pictures of it and it will be fine.
  10. Hdonlybob
    Hdonlybob
    Very impressive,
    Here is a '49 I recently bought and am starting on...
    Love the shoe boxes...
    Okie Pete likes this.
  11. fordcoupeguy
    fordcoupeguy
    Progress is slow but I got some done. Got the rear corner back into shape and bolted the Tbird rear end in with 2in blocks. They already have 2in lowering perches , so its now 4in lower. 20200904_080945.jpg 20200829_121741.jpg 20200829_130137.jpg 20200829_130137.jpg 20200829_130612.jpg
  12. fordcoupeguy
    fordcoupeguy
    Its been a while but I am making slow progress .Collision damage is repaired and the rear bumper is on . Mocked up the skirts . 20210110_154001.jpg 20210110_154026.jpg 20210110_164332.jpg 20210110_154026.jpg 20210110_164332.jpg
  13. fordcoupeguy
    fordcoupeguy
    Okie Pete, 210superair and BORN 2L8 like this.
  14. fordcoupeguy
    fordcoupeguy
  15. fordcoupeguy
    fordcoupeguy
    Got it on the ground to have a look. Sits just were I want. Has 4in blocks and 2 leaves out of the springs.Its getting there!
    Tony Ray and warhorseracing like this.
  16. Did you put any quick disconnects in to facilitate removing the dash again? I did and that enabled me to wire the dash on the bench, install it then plug it in. I used 6 pin trailer connectors.
  17. Andy D
    Andy D
    I love the Gold flake/Pearl white interior, the dash is amazing! Very cool
  18. Jacksmith
    Jacksmith
    from Aridzona
    Sweeet! My '49 sedan, with 3" blocks, had clearance issues when the kids were in the back seat... (and coolers, sleeping bags, lawn chairs, suitcases in the trunk) How's yours? I raised the driveshaft tunnel up a couple inches and it was fine.
    I ran a 350/350 with the stock 6 cylinder rear end for years with no issues.
  19. fordcoupeguy
    fordcoupeguy
    I pre wired the dash before installation. Left the wires long enough to hook up. Good idea with the plugs though
    warhorseracing likes this.
  20. fordcoupeguy
    fordcoupeguy
    Thanks man-more pics to come.
  21. fordcoupeguy
    fordcoupeguy
    I will have to finetune the suspension when the weight is on.
  22. fordcoupeguy
    fordcoupeguy
    Did some more work last summer along with other projects. It runs,stops and steers . I bagged the rear to have height control. some pics 20211001_142048.jpg 20211001_142203.jpg 20211221_134914.jpg 20211221_134945.jpg On the road next year!
  23. fordcoupeguy
    fordcoupeguy
    Hello all, well its finally on the road! Took it for a drive last evening and made it home without a tow. Still bugs to iron out but its running! 20220602_180044.jpg 20220602_181913.jpg 20220602_181947.jpg
    Tony Ray, D type, v8flat44 and 4 others like this.
  24. Jacksmith
    Jacksmith
    from Aridzona
    Ahhh... sweet progress! The car takes on a whole new personality once you drive it!
  25. 210superair
    210superair
    from Michigan
    Nice! I love it when the measuring stick of success is 'made it home without a tow', lmao...
    fordcoupeguy likes this.
  26. fordcoupeguy
    fordcoupeguy
    Its got a personality all right. Just have to get used to it. They are all different.
    210superair and Okie Pete like this.
  27. Tony Ray
    Tony Ray
    Looks great!! Love the colors of your interior.. I’m looking to do white and gold in my 51 coupe. Nice to see that it’s on the road, can’t wait until I can do the same!
    210superair likes this.
