Projects Old School 48 coupe
Discussion in 'Traditional Hot Rods' started by xxxl, Dec 12, 2020.
  1. xxxl
    xxxl
    Stock wishbones, dropped cross leaf springs, stock transmission and driveline, 1958 283 with an adapter. Other than the wheels and radials it's right out of 1960 20201211_141525~2.jpeg
    Sent from my SM-G975U using The H.A.M.B. mobile app
  2. harpo1313
    harpo1313
    from wareham,ma
    Nice ride , didnt I see another thread on it?
  3. xxxl
    xxxl
    Yeah, I'm not used to posting stuff here... I need to spend some time and learn the format 20201211_145446.jpeg 20201128_224937.jpeg
  4. 50 Merc Man
    50 Merc Man
    Old school hot rodding, I love it!!!
  5. Tickety Boo
    Tickety Boo
    from Wisconsin
    Neat Car :cool:
    Got a similar project, my plans are to drive it with original driveline behind a 350 until some thing breaks.
    Just pulled out a 3x2 400 sbc :eek: and changed to a mild 350 to help it live :rolleyes:
    Is that an aluminum 2 barrel intake ?
    alanp561 and Truckdoctor Andy like this.
  6. xxxl
    xxxl
  7. Tickety Boo
    Tickety Boo
    from Wisconsin
    Yup, was only running on the center carb so the drivetrain wouldn't go boom. 20170414_135022 (1).jpg
  8. brady1929
    brady1929
  9. Tickety Boo
    Tickety Boo
    from Wisconsin
    Where I am at now
    Cleaned the engine up and put new gaskets, bearings, seals in a 1980 350 along with a mild Howards cam.
    Didn't like the old electric fuel pump so cut part of the cross member to make room for the mechanical fuel pump.
    Cleaned and painted the frame and headers as long as the front clip was off. curing header paint.jpg
  10. xxxl
    xxxl
  11. xxxl
    xxxl
  12. Tickety Boo
    Tickety Boo
    from Wisconsin
    Do you have the knee action shocks or is it got Tube shocks on it ?
    I have an extra set of original Ford stamped front tube shock frame towers, if you need them P.M. Me.
  13. Johnnee D.
    Johnnee D.
  14. 41rodderz
    41rodderz
    from Oregon
  15. xxxl
    xxxl
    Getting ready to remove the flathead and install the Chebby.... probably going to pull the front axle and take it to Muskegon to get squashed! Hopefully it will make noise on it's own by Christmas. Maybe even a test drive yet this year. 20201219_173429.jpeg 20201217_170341.jpeg 20201213_122148.jpeg 20201212_195625.jpeg
  16. xxxl
    xxxl
    Static drop, stock wishbones and banjo rear.... I ordered a dropped axle for up front... 20201227_212509.jpeg 20201227_212501.jpeg 20201227_212536.jpeg 20201227_212552.jpeg 20201227_212524.jpeg 20201227_212523.jpeg
    48fordnut, quick85, Blue One and 9 others like this.
  17. xxxl
    xxxl
  18. Like it! A lot!
  19. xxxl
    xxxl
  20. xxxl
    xxxl
  21. Tickety Boo
    Tickety Boo
    from Wisconsin
    cut cross member .jpg On my 48, used spacers between the block and front mount for fuel pump clearance, also had to notch the cross member for it..
    xxxl likes this.
  22. 1940 coupe
    1940 coupe
    from nj
    cool coupe .
    xxxl likes this.
  23. joew513
    joew513
    from Boston
    Wow, that’s sharp.
  24. xxxl
    xxxl
  25. xxxl
    xxxl
  26. Nostrebor
    Nostrebor
    guthriesmith likes this.
  27. xxxl
    xxxl
    The beginning of the engine mount, hopefully I'll have it finished and get the exhaust done this week. Maybe even hear it make noise this week 20210109_160532.jpeg 20210109_160603.jpeg
  28. xxxl
    xxxl
  29. roddering
    roddering
    from Arizona
    I built several of these. You are off to a great start! Going to be fun
    xxxl likes this.
