Hot Rods Kohler Kustom shop projects photo dump
Discussion in 'The Hokey Ass Message Board' started by thunderbirdesq, Jan 12, 2020.
  1. thunderbirdesq
    thunderbirdesq
    Yes, he's very good, to get black to look like that even on a pretty straight car is lots of work!
    loudbang and louisb like this.
  2. thunderbirdesq
    thunderbirdesq
    Wow... time flies when you’re working your beans off!
    C2C4D134-8299-4316-9AF1-4DDD5370A920.jpeg 018F68E8-9DA8-4B58-B068-99CF24E2415C.jpeg 024DDD09-E70A-44A1-AD12-F19FC1EC97FD.jpeg FF9763DE-3B56-4204-A696-A036A778C757.jpeg 2F5D59C1-E639-44D2-9C77-CAE60DCEDFFA.jpeg 4835A360-0A89-4F6F-A5BE-20A512F198FB.jpeg 271C93C9-E796-43E4-9ACA-24BD14BA134D.jpeg 99CFD627-6725-4B7D-9A6C-8FFC1A612915.jpeg CC8AB932-7B44-4A37-8E24-F7EC862CC435.jpeg 4046567E-4666-4DA2-A2AE-8D7478577946.jpeg C095E5D2-266E-46E5-B79D-3A26BE04D7CF.jpeg B4333BFD-826D-4FC6-8270-ABD46522BD62.jpeg F57B351E-9D0E-4B7E-AF01-CF52A2B41FF0.jpeg 634358A9-C4E7-459E-B927-9767EBA96A03.jpeg 051E1A85-6DF2-4EC5-A16B-887A129AE527.jpeg
  3. thunderbirdesq
    thunderbirdesq
    A couple Of Henry’s finest roadsters for my friends Peter and Sergio.
    6139453B-F27A-464F-91DB-E99DD82F4842.jpeg D4916064-43D2-4BE2-B090-C17949D3B57C.jpeg 1C294283-F934-43D9-8AB2-18285A5A1B8A.jpeg 3B043C35-A5B0-4329-9349-46B9879581F1.jpeg 5EDEE46E-8947-4506-AFFF-7E60EB1B6541.jpeg 11FDA613-514B-4C87-AB7D-C4842E9B52EF.jpeg AC22EEE7-43AF-465C-A750-F87EEE059F05.jpeg 523E40A4-1E03-4143-BBC6-011F97CC7D43.jpeg A8FAC77C-4989-448A-94DE-97022D3C5AD9.jpeg
  4. thunderbirdesq
    thunderbirdesq
    Original 32 chassis rehab...
    70E84970-90ED-4617-8A57-4789FB5F3CB4.jpeg D9C9E0B9-BC1B-44B8-932B-E0C89926C0D9.jpeg 83AEB15D-61F4-45B0-9616-E3D2D11EDD2B.jpeg 885FFDCB-CA0A-45B3-8915-05D7B1F3B964.jpeg E5A31ECE-94F2-4485-99F8-C45C3837063B.jpeg F66E1271-A7B0-4934-A65D-F1D6E3631337.jpeg 22F78A51-0C6A-4917-9671-F8F4100CBDBF.jpeg 248F5D62-19E5-40F7-81D1-C0F27D6A4735.jpeg 093F2B5E-20E0-44B8-BC06-2FCEBD04F6C0.jpeg 439D9C5B-3C41-4BA3-AAF0-7F46DAE0A221.jpeg 77678D92-1242-4745-A04C-5542D7EB3DB9.jpeg 7B08BB83-3051-49D4-9D33-A27FEE8958F3.jpeg FC1172BE-B1EE-4FDD-87AB-BFC07C35DB82.jpeg 9274B03A-0B4A-4AF5-B89E-FCE77DFDDD30.jpeg 3D17D2E2-B56D-4081-B0B6-5A7BD9E0FC62.jpeg
  5. thunderbirdesq
    thunderbirdesq
  6. thunderbirdesq
    thunderbirdesq
  7. I just love your work .....
  8. louisb
    louisb
    I like that dash in the special.
    —louis
    Stogy, thunderbirdesq and loudbang like this.
  9. chopo
    chopo
  10. redoxide
    redoxide
    awesome pic dump, great project workload, exceptional results .
  11. fonti
    fonti
    can't wait to open up this container with the 2 buggies on the other side of the pond!!
  12. thunderbirdesq
    thunderbirdesq
    I bet! Thank you my friend for all your support and the opportunity to make these crazy ideas come to life!
  13. vilanar
    vilanar
    from Finland
    You and your photo dumps ! Love them !
  14. Is this your T.R.O.G. car?
    Stogy, chryslerfan55 and loudbang like this.
  15. thunderbirdesq
    thunderbirdesq
    thats @fonti ’s t roadster the block n yellow one pictured above.
  16. thunderbirdesq
    thunderbirdesq
    massive dumps hahaha
  17. BrerHair
    BrerHair
    Oh my, this tracknosed T is a grand slam homerun. Perfect!
  18. redoxide
    redoxide
    These are all great builds, and loads of great shots and ideas but the 27 T roadster has peaked my interest. Like the other builds it looks like there has been a lot of clever ideas tucked away and hidden in that package . I would love to see a few more pics of details in that build. From the pics already there I can see the obvious stuff like the hood and sides, cowl steering, track style nose and louvred lid among other external details . Under the hood I picked up the position of the flatty, and the modified firewall and the brake master, perhaps indicating firewall mounted pedal assembly , also overall stance indicating chassis mods .. looks really interesting.
  19. -Brent-
    -Brent-
    Andy dropped and "squished" this 32 for me.
    Here it is compared to a stock 32.
  20. thunderbirdesq
    thunderbirdesq
    Thanks, there are some pics of the build up earlier in this thread, pedal assembly is a reworked f1 set up as swing operation and it’s mounted to the cowl hoop that also supports the f1 steering box converted to cowl steer. Clutch actuation is moved to the passenger side via a cross shaft also mounted to the hoop, this saves critical foot room in a channeled t with a set back engine, engine is also offset to the passenger side 1” to give the driver some space. Nose, hood, firewall, deck, dash and full belly pan are all aluminum. Chassis is mostly 0.180” wall 1.5” x 4” tubing with model a rear and front crossmembers, a smaller tubing framework under the passenger compartment with 18ga floors attached to the frame rather than the body. Rear suspension is a home brewed triangulated 4 link using old ford parts. It’s also set up to run either a t5 or open drive 39 box with minimal swap effort (R&r thru the floor with two sets of mounts. Front shocks are cantilevered tube units tucked inside the front rails under the water pumps. It is a light, snotty little rocket ship !
    brEad, chryslerfan55, KiWinUS and 7 others like this.
  21. thunderbirdesq
    thunderbirdesq
    Stogy, chryslerfan55, -Brent- and 2 others like this.
  22. thunderbirdesq
    thunderbirdesq
  23. redoxide
    redoxide
    Thanks for taking the time to record this , went back through the entire post and pulled all the relevant pics and info. Im wondering if the new European owner of the car will bring it to the UK for VHRA events, Pendine and GOW.. Its would be cool to see it in the flesh.
  24. thunderbirdesq
    thunderbirdesq
    I know he is planning to bring it to pendine so you should be able to lay eyes on it there, assuming the event happens this year.
    chryslerfan55, redoxide, TomT and 2 others like this.
  25. A Boner
    A Boner
    Wow...fantastic work!
  26. fonti
    fonti
    You should be able to see it in person at some beaches in Europe...
    I got a ticket for "Race the waves" this may and hope to make it to Pendine next year. This september I apply for a racing space in Romo / Denmark...
  27. chopo
    chopo
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    Andy Kohler of Kohler Kustoms did this for me today as a side project ... this guy walks the walk and talks the talk. Great fab skills and very respectful to the traditional ways of hot rodding . Thank you Andy for a good day I’m just hanging and punchin louvers
  28. thunderbirdesq
    thunderbirdesq
    anytime buddy, so stoked to see you getting this coupe going after working your ass off on it the way you have, it’s inspiring!
    Stogy, brEad, LOST ANGEL and 4 others like this.
  29. brading
    brading
    Just been right through it and it is a interesting thread.
    Stogy and loudbang like this.
  30. thunderbirdesq
    thunderbirdesq
