History Belly Burner exhaust, let's discuss
Discussion in 'Traditional Customs' started by Roothawg, Nov 8, 2017.
  1. A Boner
    A Boner
    Probably just not your style.
  2. Blue One
    Blue One
    from Alberta
    Pretty much true.
    This is my style.
    D484F4A3-5745-4EA9-BB08-04A896500707.jpeg FC66128B-2AC5-40E9-852A-E878D77E01F7.jpeg 9EFE6154-B3AF-4778-B565-900D8A31D115.jpeg
  3. Bull
    Bull
    Been a long time since I was on the H.A.M.B. but wanted to add to this thread as I stumbled on it today. This 35 was built by a couple guys in MN (Nutz & Gefre) in the 60’s. My uncle owned it for a time as well. I was told the belly burners were made from 57 Ford driveshafts.
    I located the truck a few years ago - still intact!
  4. Roothawg
    Roothawg
  5. Baumi
    Baumi
    Way cool thread! Now I need a truck with belly burners. Thank you
  6. Roothawg
    Roothawg
    You need one....
  7. rust&patina
    rust&patina
  8. Roothawg
    Roothawg
    TrailerTrashToo and Moriarity like this.
  9. Budget36
    Budget36
    Well, I wasn’t there in the day, but my Dad bought the ‘57 Chevy PU new. He told me he was glad he never -turn away now, not politically correct- didn’t put Portegy stacks on it. Now this would have been run the exhaust pipes up through the steps. Ala poor mans deisel.
    So before you slam me for the bad PC thing, put this in to perspective please. My dad grew up in a 100% Sicilian family with grape vineyards, Portuguese fellows in the area had dairy farms. They had deisel trucks with stacks coming up behind the cab
    Hence the reference.
    But, I have to say I do understand why it’s referred to as a belly burner, but might just be me I think it looks ugly as all get out. I know this was done “way back when”. But looks like the early start of rat rod to me.
    I read some replies about “exhaust limits” or similar, like maybe too low to run full exhaust
    well, why not just dump them out the side then?
  10. bchctybob
    bchctybob
    We just called them "Bed Pipes" never heard the term, belly burners.
    1 3/4" or 2" pipe?, you need to build some mock up pipes and see which size works with the size of the bed, bed length, etc. It's the old; stand back and look at it from all angles thing. 2" will probably look fine with the '36 bed. If you can find a place to do custom mandrel bending in your area that's the best way to go. I took my mock ups to H&L Metals in Long Beach, Ca. and had them make me two sets in 2" stainless. It was a little cheaper to have two sets done at once. I have the second set in the rafters waiting to be used on my '33 pu.
    My '29 had a 327 with a small solid lifter cam through Smithy mufflers, I loved the way that truck sounded. Also watching the vapor puffing out of the pipes on a cold morning was cool.
    Oh yeah, and the comments about them cooling off pretty fast are accurate. First of all they are out there in the wind when they are getting the most heat and when you're idling around they don't get as hot as when under power. Kids do have a natural tendency to want to touch 'em but I just stood by for a few minutes at shows to tell folks to stay away.
    jimmy six and Roothawg like this.
  11. Roothawg
    Roothawg
    I like the kickstand pipes as well. They might be easier to use, if you wanted them functional.
  12. Bull
    Bull
    I assume the term "belly burners" because if you leaned over the bed side you'd burn your belly on a hot pipe.
    loudbang and Tim like this.
  13. Roothawg
    Roothawg
    Correct.
  14. My GMC is getting them. I have had the stainless tubing stashed away for years. Only difference is for now I am keeping the flatbed. The pipes will run just under the side rail since visually there is so much area to fill there. Of course some 10" reversed 56 Chevy wheels will help as well.
    Sancho, loudbang and Roothawg like this.
  15. Jet96
    Jet96
    from WY
  16. WiredSpider
    WiredSpider
  17. loudbang
    Tiny looking pipes
  18. Need to be bigger diameter and closer to the bed rail.
    loudbang and 1 KooL "MoFo" like this.
  19. Jet96
    Jet96
    from WY
  20. Jet96
    Jet96
    from WY
  21. Dave Paras's 32 pick up about 2000 leaving the Rockabilly Rumble East Hartford Conn
    Tman, Tim, Jim Bouchard and 4 others like this.
  22. Roothawg
    Roothawg
    Bringing this back up. Love me some belly burners.
    Sancho likes this.
  23. nochop
    nochop
    from norcal
    This truck has been in the Bay Area as long as I can remember 05CCC65B-6047-4440-B53C-B276394469AC.jpeg Pete Paulsens House of Wheels
  24. Roothawg
    Roothawg
  25. Found this while strolling the interweb...while not belly burners, I don't think they'd do your shins any good if you rubbed against them. Neat idea.
    504640, Jet96, 37hotrod and 5 others like this.
  26. Roothawg
    Roothawg
    Funny this should come up. I was calculating the smallest pipe I could get away with on a 301.
    Tman likes this.
  27. J. A. Miller
    J. A. Miller
    from Central NY
    I think their cheating if they have fenders.:rolleyes:
  28. That is cool!
  29. Jet96
    Jet96
    from WY
