Hi All I have a 51 AD with the bottom door hinge rusted out. I cant find this part where the hinge screws in to the bottom door pillar. any help would be great 44-283_LI by Rusty51AD posted Nov 13, 2020 at 10:55 AM
www.classicparts.com part # 44-253 or 44-254 looks like what you need. Door pillars, found under patch panels.
no that's not it im looking for the bracket the door hinges bolt to behind the door pillar 44-283_LI by Rusty51AD posted Nov 13, 2020 at 10:55 AM
I dont think the pocket is reproduced (if thats the part your looking for.) might have to find a donor or like suggested above make your own .
If your a member of stovebolt.com you can put a request in a “parts wanted” section. they have a few guys who part out AD trucks. Ive purchased some dash patch panels from there Might be worth a shot This is a tricky repair
Thanks, I have not made that repair so cannot help. But I would imagine you would make sure you hang and fit door, check gaps before you final weld the pocket and close up the outer cowl. Good luck .
I was waiting for my son so I had to go looking. This may be the parts you are looking for if they are available. https://raybuck.com/product/1947-55-gm-pickup-front-lower-door-pillar-driver-side/ https://raybuck.com/product/1947-55...ing_wp_cron=1605294615.0499060153961181640625
I've got a pair of door posts that might have good ones on them. I'll look in a bit. You might check with Premier street rods and see if they have them for their cab builds. They don't show them in the catalog but do show 55--- 59 hinge pockets. Their catalog is the most disorganized mess on the net as far as car parts goes though https://www.premierstreetrod.com/
still no luck but I appreciate the help!! I think ill just have to make something. thanks again guys!!
