32 Ford amp gauge, wrap around type, early? Face faded needs restoration but needle bounces nice $45 SOLDamp gauge with black bezel and replacement needle, $20 SOLDamp gauge with bailing wire, one hold down tab on back broke, needle hangs up. For parts, restorable though $15 32 Ford fuel gauge with gasket worm-itis black background plastic cracked. Parts available to restore. bezel and mechanics good $50 Nice 32 fuel gauge, back reinforced with epoxy but the part you see looks minty $100 SOLD*""Early 1932 80 mph speedo, nice but needs 2.75" round glass replacement, fully functional ***SOLD 32 Ford 90 mph speedo, nice core. All parts move. Needs bezel and restoration but better than most internals $50 AC 32 Chevy 0-30 psig oil pressure, curved glass. Slight corrosion on front, a few pinholes on back but functional $5. 3 gauge under dash holder $2 0-100 oil pressure and 100-280 temp equus gauges. 2 5/8" mechanical like new. Perfect for race car or engine stand. $15 pair Bezel for Sun Tach with glass presentable chrome $25 6v SW electric Oil Pressure, brass case $35 nice SW mechanical oil 5-80 psig , mount trimmed for boat dash $25 Bristol's US gauge co NY 0-50 PSIG silver dial W crescent pointer brass era? 1/8" npt $10 T speedster? Backlit SW 60amp with black/white needle pointer, bracket shortened for boat dash $15 Hobbs / Stewart Warner 4-40 Volt hour meter (works on 6, 12, 24 volt systems) $10 great for engine stand break in time Brass case Stewart Warner 60-60 amp. Slightly yellowed lettering but nice in under dash mount $25 Backlit SW 100-280 deg f water temp black/ white pointer needle bracket cut for boat dash. $35 White faced "Hoyt" 100-100 Amp in under dash mount NOS $30 SW 100-325 OIL TEMP, 12 volt big little numbers. Studs shortened and has 2 extra small mounting holes but face and bezel are extra nice $20 Oil pressure sender and smaller one, vacuum maybe? off a Ford 59 AB flathead V8 $5 Make Offers! Thanks, Brian
