Projects Another New England build. . . From pieces
Discussion in 'Traditional Hot Rods' started by wheeldog57, Dec 9, 2017.
  1. jimvette59
    jimvette59
    Thanks for answering my question. I was thinking of thinning rust encapsulation paint and let it soak in all crevices. Jim T.
    chryslerfan55 and Thor1 like this.
  2. wheeldog57
    wheeldog57
    Thanks Smitty, we wont be around if, or when, these parts rot through again!
    I have some weld through primer too but don't use it very often.
  3. Make yourself a scrap book to leave on your cowl when at a show / cruise night. Some one did that at York / NSRA several years ago. That way when some restorer piss's and moan's that you ruined a good body, show him the scrap book and ask him if he could accomplish what you have done. More likely than not, he will appreciate what you have done.
  4. wheeldog57
    wheeldog57
    Thanks Nick!
  5. wheeldog57
    wheeldog57
    After a sun porch remodel I am back on the coupe project. I really want to put the body together and weld stuff but. . . I need to focus on the drivetrain and chassis first. I need to focus
    That is sometimes a problem.
    Anyway, I got some stuff done last night. Front cross member swapped out and crank pulley installed. 20200811_180424.jpg 20200811_182623.jpg 20200811_182943.jpg 20200811_195119.jpg
  6. Baron
    Baron
  7. [​IMG]
    Thanks for running up north and getting sedan doors, it helped me a lot.
  8. The37Kid
    The37Kid
    I can relate to that three steps back to make one step forward deal, need a chassis for my Roadster to fit the body pieces to. Bob
  9. wheeldog57
    wheeldog57
  10. wheeldog57
    wheeldog57
    Got some more done today, errrrmmm, I mean tonight after work.
    Installed timing cover and front motor mount.
    I don't know if mount is installed correctly
    I briefly looked it up but couldn't find anything helpful online so this is what I came up with on the third attempt. I would appreciate a knowledgeable person to direct me if this is wrong, thanking 20200812_195356.jpg 20200812_195350.jpg 20200812_195344.jpg
  11. wheeldog57
    wheeldog57
    I also cleaned up the oil pan. It wasn't too bad to begin with so I pulled the baffle out and cleaned it up. I need the front seal before installing 20200812_170707.jpg
  12. The37Kid
    The37Kid
    Are those gears good enough to use, or was the front cover installed just to test things? Bob ?
    TFoch, biggeorge and Thor1 like this.
  13. wheeldog57
    wheeldog57
    Yes, the gears are fine. I brushed on a little grease so they look messed up in the picture. I got to see them again yesterday because I neglected to install spring and plunger the first time. Was dreading the job but it only took 30 minutes or so.
    Nailhead A-V8 and Thor1 like this.
  14. wheeldog57
    wheeldog57
    I planned on installing the oil pump and oil pan yesterday but the pump holder screw was NOT playing nice. Brass screw in cast iron would not budge. After breaking the end off I drilled it out and threaded in a 1/4-20 bolt in there. It's a little ugly but it does the job. 20200822_173853.jpg
  15. wheeldog57
    wheeldog57
    I have a question. . .
    Does the oil pump/distributor drive need to be clocked? I pulled it out to inspect and clean and I did not Mark it before I removed it.
    Thanks in advance
    Thor1 likes this.
  16. The37Kid
    The37Kid
    You'll correct that when to set up the distributor timing. Bob
    Thor1 likes this.
  17. wheeldog57
    wheeldog57
    Ok Bob, so when I put dizzy in I have to line up #1? I would like to install valve cover and NOT have to go back in there.
    Thor1 likes this.
  18. put it together. the cam in the distributor is what gets adjusted. the funky pin sticking out of the timing cover gets removed and re-inserted backwards into the hole. rotate the engine slowly till the pin drops into the digit in the cam gear. that is top dead center #1. loosen screw holding cam and rotate it till rotor pants to number on on the cap. 20200812_195350.jpg
    Moondog13, pitman, patmanta and 7 others like this.
  19. wheeldog57
    wheeldog57
    @tb33anda3rd thank you sir, sounds simple enough. Now I can put valve cover back on. . . . Progress!
    TFoch and Thor1 like this.
  20. JRN1967
    JRN1967
    from Monson MA
    To expand on what tb33 said.
    Loosen cam locking screw on top of cam & turn cam until cam rotor slot is pointing towards distributor body No. 1 cylinder firing position. Next turn cam counter-clockwise until points are fully open; then turn cam clockwise until the points just close. Stabilize cam with cam wrench & tighten cam locking screw. Re-install timing pin.
  21. Nailhead A-V8
    Nailhead A-V8
    great work good to see you still pickin away at it...looks like new crossmember is low mount and old is high... no biggie better than the other way around
    Thor1 likes this.
  22. wheeldog57
    wheeldog57
    After 3 years of looking for decent doors, finding
    "most of doors", cutting and welding on said doors. . . . @sloppy jalopies PMd me about these.
    A pair of workable doors, finally! Like everything else on this build, they need work but they are WAY better than the others I have.
  23. The37Kid
    The37Kid
    Nice New England doors! Those Montana / Nebraska doors are just overrated and would look out of place. :rolleyes:
    Bob
  24. Your going soft Ron, next you'll be pulling a Foose or Coddington and cutting up a fully resorted car so you don't have to deal with rust.:D
  25. adam401
    adam401
    If you have early Ford parts in New England that dont need the bottom 6 inches welded back on your way ahead of the game. Good score.
  26. I always say: in New England if the rust hasn't reached the door handle it's "rust free"
  27. Baron
    Baron
    Compared to the doors you had, these look like "new old stock". :)
    wheeldog57 and Thor1 like this.
  28. 32 hudson
    32 hudson
    Nice decent doors. You are a lot further ahead with these.
  29. general gow
    general gow
    MODERATOR
    i thought the torched out hinge pockets were stock. these must have been modified at some point? ha.
  30. Nailhead A-V8
    Nailhead A-V8
    "The crank has been sweaty for a long while. It still will NOT spin!
    Broke the crank handle trying."
    Paging Dr. "Patch" Adams.... upload_2021-8-29_20-58-10.jpeg well? did you do trans fluid/diesel mix? hot wax? pop the caps off? what is going on with that anemic 4 with all the power of a fart in a windstorm? it looks hooped to me ;)...I think a V-8 is the only way to unstick that 4 banger:rolleyes:
