Hot Rods Model T spring 1940 rear end
Discussion in 'The Hokey Ass Message Board' started by spencer boehm, Oct 21, 2020.
  1. spencer boehm
    spencer boehm
    I have a 1940 rear axle. What is needed to mount the model T spring?
  2. The37Kid
    The37Kid
    Shackles.
    X38 likes this.
  3. Happydaze
    Happydaze
    All of the parts you'll require are in the it depends isle, Sir.
    Chris
    X38 likes this.
  4. Tell us about the car. What frame,and rear cross member are you useing,what rear radius rods/wishbone? Spring on top of axle,or behind?
  5. spencer boehm
    spencer boehm
    Sorry Im young and new to the scene i have been building a frankenstein speedster. it is a model t frame. It has a 8ba in it and I have 1940 rear ended and wide five drums and wheels.
  6. goldmountain
    goldmountain
    Repeat irishsteve's question- spring on top or behind?
  7. spencer boehm
    spencer boehm
    its in the stock 40 location
  8. spencer boehm
    spencer boehm
  9. Crankhole
    Crankhole
    Some washers to make up the difference between spring width shackle width.
  10. spencer boehm
    spencer boehm
    I thought about that but what do i run through the bushing on the t spring
  11. alchemy
    alchemy
    Take the remains of the stock bushing out of the spring and use a new shackle pin/bushing. The real parts houses sell many different sizes. You can either find the proper size for a 40 Ford and add some collars to take up the slack of the narrower spring, or maybe get lucky and find pins that will fit the spring and then can narrow the rear's hangers a touch.
  12. The37Kid
    The37Kid
    The wheel base will look odd with the '40 axle housings moving things forward. Mice period way it the Isky Roadster setup with the housings swapped left to right, right to left this makes for a longer and much more pleasing look. Bob
  13. Corn Fed
    Corn Fed
    If you mount the spring behind the axle you may have a problem of the axle bottoming out on the frame. Do some rough setting up before you get too far into things.
  14. spencer boehm
    spencer boehm
    I will rough fit it may have to notch and reenforce frame. on the t spring what bushing do i need the stock bushing ?
