Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Paul
    Paul
    Editor
    Started cowl/firewall support.
    Used stock firewall as a pattern and bent some 3/4" square tube to match.
    Trimmed the flange back to leave about 1/2" around the opening,
    clamped the tube in place and tacked and trimmed the legs.
    I'm thinking 1/4" polished aluminum firewall attached with chrome carriage bolts..
    PXL_20201012_215643524.jpg PXL_20201012_194833426.jpg PXL_20201012_202409495.jpg PXL_20201012_220030626.jpg PXL_20201012_221625613.jpg PXL_20201012_221632879.jpg
    chryslerfan55, Stogy, Jet96 and 8 others like this.
  2. Paul
    Paul
    Editor
    Lots of starts but all will come together..
    Started the bend for the channel.
    Body will be channeled over the frame 2-1/2".
    'tried to bend a 4' length of 18 gauge..
    The long brake might make a nice long bend in Christmas wrap but 18 gauge steel, not so much..
    Hard on both ends and soft in the middle..
    So I used the old Chicago and bent four 2' pieces.
    They need a bend mid length anyway to follow the frame rails.
    PXL_20201012_234848508.jpg PXL_20201013_001247854.jpg PXL_20201013_001225565.jpg PXL_20201013_183219765.jpg PXL_20201013_183207870.jpg
  3. Marty Strode
    Marty Strode
    Paul, it's hard to beat good old American tools !
    Stogy, loudbang, Paul and 2 others like this.
  4. Paul
    Paul
    Editor
    Upon closer examination the lower edge of the body driver side forward was deemed too rusty to suffice.
    So...
    Back to:
    Cut, roll, break, shrink, stretch and roll.
    Check shape by placing piece upside down on opposite side and match.
    Scribe, trim, clamp and tack.
    Skip weld 1/2" +/- until it's fully welded.
    Clean it up and bump it into shape..
    Not perfect but,
    remember it's just an old Model T, nothing special,
    they made millions of them
    Heck, you could buy a used one for the price of a new hat.
    Set the body back on the chassis,
    now there is something to weld to.
    PXL_20201013_200906987.jpg PXL_20201013_192041665.jpg PXL_20201013_193108639.jpg PXL_20201013_193541714.jpg PXL_20201013_203649621.jpg PXL_20201013_204239152.jpg PXL_20201013_211458340.jpg PXL_20201013_212301304.jpg PXL_20201013_221603170.jpg PXL_20201013_224422332.jpg PXL_20201014_000609725.jpg PXL_20201014_012230577.jpg PXL_20201014_012305782.jpg
  5. Outback
    Outback
    from NE Vic
    Looking good!
    Stogy, loudbang and Paul like this.
  6. Nice work, as always Paul.
  7. A Boner
    A Boner
    Sure a labor of love. With most people not having your skills or equipment, and the relatively low cost, it’s obvious why there are so many Tupperware T’s that have been built over the years. Keep up the fantastic rescue, and killer build!
  8. OFT
    OFT
    I have been impressed with your skills for years! Figured it was about time to post some of my admiration. Keep up the progress and pictures. Thank you for posting so I can follow along!
  9. Paul
    Paul
    Editor
    Thanks man, that's quite a compliment.
    chryslerfan55, Stogy and loudbang like this.
  10. Paul
    Paul
    Editor
    Trimmed two pieces of Z metal I bent up the other day,
    Drilled the bent flange at bottom body edge every 2" more or less,
    clamped them in place
    plug welded
    body back on to check fit..
    PXL_20201014_233124171.jpg PXL_20201015_001616510.jpg PXL_20201015_004200685.jpg PXL_20201015_011859658.jpg PXL_20201015_012017346.jpg PXL_20201015_012024475.jpg
  11. Paul
    Paul
    Editor
    same procedure for front Z metal
    PXL_20201016_200255904.jpg PXL_20201016_213112115.jpg PXL_20201016_231100939.jpg PXL_20201016_224728494.jpg PXL_20201016_230049978.jpg
  12. alchemy
    alchemy
    Paul, I'm going to send you my T roadster panels in a flat crate and you let me know when it's ready to pick up.
  13. Paul
    Paul
    Editor
    If I was paying myself the going hack shop rate I'd be rich... or broke..
    bct, chryslerfan55, Stogy and 6 others like this.
  14. Paul
    Paul
    Editor
    Filling the gaps at rear corners
    No patterns, just cut, bend, shrink
    and plug weld to the skin
    like the Z metal at the sides
    Times two..
    PXL_20201017_230649184.jpg PXL_20201017_232909246.jpg PXL_20201018_000127591.jpg PXL_20201018_002229945.jpg PXL_20201018_004458453.jpg PXL_20201018_005155503.jpg
  15. Marty Strode
    Marty Strode
    Paul, The Z-metal fillers are an excellent idea, great execution as well.
    Stogy, cactus1, The 39 guy and 2 others like this.
  16. Paul
    Paul
    Editor
    Thanks Marty.
  17. Jet96
    Jet96
    from WY
    Paul -I really appreciate you taking the time to take photos. I know how hard it is to stop and do that!
  18. Paul
    Paul
    Editor
    Short day in the shop today.
    Worked on the driver front corner of body,
    where it needs a notch to clear the steering box and pitman arm
    Trimmed the body back just enough to clear,
    bent up and tacked in some 1/4" round stock
    along the raw edge.
    Also bent a test piece of sheet metal
    but that will need to be revisited,
    'not too keen on fit or design.
    PXL_20201018_203740931.jpg PXL_20201018_203802442.jpg PXL_20201018_225720789.jpg PXL_20201018_233902674.jpg PXL_20201018_234655779.jpg PXL_20201018_234640710.jpg
  19. Paul
    Paul
    Editor
    Worked on the top rail a little
    Set up shrinker/stretcher close to work
    Cut a strip of 18 gauge steel
    Break
    Shrink and stretch
    Hand planish
    Touch it with a DA..
    I can see how this might work..
    PXL_20201020_233005016.jpg PXL_20201020_222531644.jpg PXL_20201020_222659707.jpg PXL_20201020_223028514.jpg PXL_20201021_014200995.jpg PXL_20201021_022058975.jpg
    chryslerfan55, Stogy, Tim and 16 others like this.
  20. Paul
    Paul
    Editor
    chryslerfan55, Stogy, Tim and 9 others like this.
  21. bchctybob
    bchctybob
    I've been thinking of doing that to my '28 roadster body. Lots of cracks and old repairs up along that edge. Seems like a vulnerable area. Great work! Keep those pictures coming Paul.
  22. Paul
    Paul
    Editor
    all three top pieces resting roughly in place
  23. Paul
    Paul
    Editor
  24. Paul
    Paul
    Editor
    TIG
    File
    Sand
    PXL_20201024_001520138.jpg PXL_20201024_005921941.jpg PXL_20201024_012802918.jpg PXL_20201024_012822476.jpg PXL_20201024_011047243.jpg
  25. flatheadgary
    flatheadgary
    from boron,ca
    and people complain about the structure one must make for fiberglass bodies. although the glass body gets pretty heavy afterwards.
  26. The 39 guy
    The 39 guy
    Great work ! Great thread!
  27. 64 DODGE 440
    64 DODGE 440
    from so cal
    Keeps getting prettier.
  28. Paul
    Paul
    Editor
    This is my third T build.
    First was cute
    Second was nice
    This one is is pretty
    Do I see a trend here?
  29. I bet that made a world of difference in how stiff it is. Looks great, too!
    Stogy, loudbang, Paul and 1 other person like this.
  30. lake_harley
    lake_harley
    I might have seen the answer to my question in post number 444, but do you use TIG on all of the sheet metal work you've done? Or, do you sometime tack with MIG and then do the finish welds with TIG? No matter what your process, and maybe it varies from panel to panel, the workmanship is always enviable.
    Lynn
