Hot Rods 25/32 socket
Discussion in 'The Hokey Ass Message Board' started by RmK57, Oct 11, 2020.
  1. Must be a Prince.....its purple...
  2. Atwater Mike
    Atwater Mike
    25/32 is 20 mm. 15/32 is 15 mm. Just sayin'...
  3. I was told years ago that if you had a full set going up by 32nd sizes, you didn't need metric. Don't know if that's true, I've never checked.
    In my personal 1/2" Proto set I have 19, 21, 25, 27, 29, and 31/32 sockets, all 12 point. All of these are currently available. A 17/32 is available (no, I'm not going to buy one) but no listing for a 23/32 for some reason. I suspect these have aircraft applications, as 12 point bolts/nuts are common there. I've never seen a 32nd size in a 6 point except in a 1/4" drive, or a 32nd size between 3/8" and 1/2".
    I have used the 19 and 21/32nd sockets a few times over the years, usually on exhaust flange nuts that were brass.
  4. Jack E/NJ
    Jack E/NJ
    from NJ
    Anybody who can google 25/32 to mm and 15/32 to mm knows you lie. 8^) Jack E/NJ
  5. PhilA
    PhilA
    1. Hydro Tech
    Useful to hammer over a rounded-off 7/8" nut?
    Can't say I've ever used the one in my set.
    Phil
    racer-x and loudbang like this.
  6. Deuces
    Deuces
    How do you round off a 7/8" nut???... :confused:
    LAROKE and loudbang like this.
  7. 12 point socket and a impact wrench set on 'kill'?.... LOLOL....
  8. Put 'em in a sock and use 'em to beat anybody with billet, electronic fuel injection, or "patina".
  9. Beanscoot
    Beanscoot
    Whitworth sizes are not 32nds. They are completely irrational, based on some "ideal" calculation of hex size based on the thread size.
    Deuces and VANDENPLAS like this.
  10. TrailerTrashToo
    TrailerTrashToo
    20201012 19-32 socket.jpg 19/32" 12-point socket from my 1965 Craftsman socket set. These screws and nuts held the door hinges to a 1952 Bell Telephone System service bed. Note the wire on the bolt used as a locker - never saw anything like that before. I reassembled the hinges with new screws, lock washers and bolts from Ace Hardware.
    This is the service bed - camera positioned to "un-see" the off topic. The rear doors were left with "patina" (and no clear coat!!!!). I have driven this truck to 37 states, the map is pealing, only recently did we get a garage to park the truck in. A 4 cylinder turbo Cummins puts the "BANG" in banger.:)
    Russ
  11. partsdawg
    partsdawg
    from Minnesota
    Possibly tractor use?
  12. leon bee
    leon bee
    I have a long 17/32" open end I use on Whitworth sized carb attachment nuts on my Brit bikes.
  13. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Early Fords used that size on a few things. I can't remember what those things were however.
    loudbang and Truck64 like this.
  14. I actually found one place on my 52 Chevrolet Ute, the bolt that holds the pedals in the master cylinder. That bolt is little over 3/4, and I used a 20mm to get it since it was convenient. I didn't have a 25/32 handy.
    Sent from dumb operator on a smart phone
  15. All of the 32nd and 64th sizes were developed for the high intensity atmospheric derivative of the intensity measuring section of the United States Division of Weights, Measures, and Volumes. The reason they were developed was for the specific wonderment of the world today amidst all of our trials and tribulations and to totally destroy any chance that any of this made any sense.
  16. Budget36
    Budget36
    So what you're saying is, they made them just for the eff of it?;)
    VANDENPLAS and loudbang like this.
  17. jimmy six
    jimmy six
    For Amos or Andy....
    lothiandon1940, LAROKE and loudbang like this.
  18. gimpyshotrods
    gimpyshotrods
    Okay, what is 25/64ths for, and why do I happen to have three of them?
  19. Beanscoot
    Beanscoot
    25/64"? You've got to be kidding!
    There are tiny 64th sizes in some of those old ignition wrench sets, but they are usually under 1/4".
  20. gimpyshotrods
    gimpyshotrods
    Nope. Not kidding. They are in my "useless tool drawer", with the 31/32" combination wrench and sockets, and the 9/32" drive stuff.
    And for that matter, I cannot for the life of me remember how I ended up with a set of bronze sockets.
  21. Beanscoot
    Beanscoot
    Bronze tools are pretty neat, they were (are?) made for non-sparking work such as in explosives factories.
    Commonly they are Beryllium-Copper.
  22. LAROKE
    LAROKE
    11/32 was my nemesis.
    I have a "universal" harmonic balancer puller/installer tool that I've used on two engines so far. Both times, none of the eleven different puller bolts fit the damper I was trying to remove. Damnation! The puller holes on this damper were smaller than 3/8" and larger than 5/16" . None of the metric bolts I could find fit either. Why would anybody use a bastard thread like 11/32" fine for this purpose?
    After a two hour shop search, I went shadetree mechanic on it and drove a 3/8-24 tap thru the puller holes. It was a risk since there were only two but it worked. The damper was off in a matter of minutes after I got the puller set up.
    lothiandon1940 and Budget36 like this.
  23. jetnow1
    jetnow1
    from CT
    1. A-D Truckers
    My ex father in law was in charge of the remodeling and repairs at a major hospital. We were sitting down to dinner one Sunday when he got a frantic phone call, "the new guy" had fastened an oxygen line to a gas line, they have different fitting to make this impossible, except he went to their shop and made an adaptor. They had to make brass tools to take it apart, very carefully.
    37hotrod and Beanscoot like this.
  24. carbking
    carbking
    A hundred years ago, there were "standards", but many manufacturers ignored them. Thread size is even worse than the bolt/nut size.
    If the average mechanic didn't have a wrench to fit, then the customer had to go to the dealer for service. Or the customer had to go to the dealer for a new part, after the original was ruined by use of the wrong wrench.
    Jon.
    VANDENPLAS likes this.
  25. If that answer relieves your headache from reading that, then yes.:rolleyes:
  26. Deuces
    Deuces
    That usually does the trick....:D:mad::rolleyes::D
  27. gatz
    gatz
    IIRC, a 19/32 socket was used on a support block inside the right rail of an Allis Chalmers WD / WD45 .
    Only place I'd ever seen a need for that socket that came with the Craftsman set.
    Re the 21/32, a guy posted on local CL just recently looking for one.
    Don't know if he found it or what he needed it for.
    I contacted him about using a 17mm socket 6-pt which might have been close enough.
    As usual on CL, no reply.
  28. LAROKE
    LAROKE
    Glad this is a traditional site so we don't have to ponder the existence of a 5.5 metric socket. That's just nuts.
  29. saltracer219
    saltracer219
    I still have some of those wierd lock nuts around. I made a trailer to tow behind my Hot Rod years ago out of one of those boxes exactly like yours, I shortened mine 20". They are all aluminum and were manufactured by the Mercury Aircraft Company on the East Coast, super well built!
  30. Beanscoot
    Beanscoot
    11/32" is a common size for nuts on #10 or #12 screws, IIRC.
    I use my 11/32" nut driver often on non-Chinese appliances and electric motors.
    I've been pondering the 5.5 sockets a lot lately myself. It works out to 0.217" in real measurements, so a 7/32" socket, at 0.219" will work just fine.
    Thank goodness for 32nd sockets.
