Hot Rods Adjustable Drag Link
Discussion in 'The Hokey Ass Message Board' started by earlymopar, Oct 6, 2020.
  1. earlymopar
    earlymopar
    I'm looking for a source that has custom drag link / tie-rod tubes in lengths under 20". I specifically need them tapped 11/16-18. I have found Speedway and others have them but only in longer lengths. Worse comes to worse, I'll by a left-hand tap (I already have the RH tap) and will make my own.
    Thanks guys.
  2. lostone
    lostone
    from kansas
    Buy 1, cut off the rh side to length, take your rh tap and re-tap threads...
    fauj likes this.
  3. Jmountainjr
    Jmountainjr
    Buy the tap and a couple of lengths of DOM and be done with it. And have a better product than most.
  4. earlymopar
    earlymopar
    I just ordered the rod ends and tubing as I thought I would end up having to do. I was ust checking for other sources before committing.
  5. Casual 6
    Casual 6
    from Great NW
    I thought Speedway would make custom lengths???
  6. Marty Strode
    Marty Strode
    There is a guy about 30 miles north of you that can help. He has a LH tap, and a massive lathe. Send me a PM.
  7. goldmountain
    goldmountain
    I have one in stainless that measures 17 1/2" long. Send me a PM if it will work for you.
  8. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    I've has Pete & Jake's make me custom lengths several times.
  9. earlymopar
    earlymopar
    Thanks Marty. I had already ordered when I saw your thread but appreciate your offer. I'll not react so quickly next time!
  10. earlymopar
    earlymopar
    Dang GM. That would have been nice. Thanks much for chiming in.
  11. DDDenny
    I had a massive lathe once!
    I've never done that.........right!
