Technical MR. GASKET GAS PEDAL - JUNK??
Discussion in 'The Hokey Ass Message Board' started by Clik, Sep 24, 2020.
  1. Clik
    Clik
  2. Torana68
    Torana68
    from Australia
    Moon make good stuff , there are lots around even boat racing ones , just depends on what you want.
  3. pnevells
    pnevells
    We used a Speedway pedal ( $55) in our Altered, it has worked fine, 6 years of being mashed to the floor no issues...
    Desoto291Hemi, leon bee and Clik like this.
  4. dreracecar
    dreracecar
    from so-cal
    Those (made by many companies) are junk, action is cheap and rough. If there was a way to machine the slot and put a bearing on the slide, it would work better , also an industrial push-pull cable instead of the cheap wire type.
    Clik likes this.
  5. Clik
    Clik
    THANKS for taking the time to take pics :)
  6. Go to a big truck salvage place and do some looking, there are some cast aluminum pedals used in big truck applications that might suit your purpose.
    firstinsteele and Clik like this.
  7. pnevells
    pnevells
    I used an old B&M shifter cable ,and it has worked great
    Clik and Just Gary like this.
