Projects 1946 GMC Bonneville build
Discussion in 'The Hokey Ass Message Board' started by Marcia, Aug 26, 2020.
  1. Marcia
    Marcia
    I've started my truck project with Frank "gaspumper" and its taken us a while to get it this far. Hopefully I'll be able to post every week or so and show you some progress. We are in the middle of moving to PA and we'll be racing next week in Loring Maine.
    Ill be looking for parts along the way also.
    Ok, back to work! IMG_20200824_155203687_MP.jpeg IMG_20200825_132305_581.jpeg IMG_20200825_125200909_MP.jpeg
    Sent from my moto z4 using The H.A.M.B. mobile app
  2. MarcioD
    MarcioD
    That looks like a fun build! Subbed
    Stogy and Marcia like this.
  3. Some drag tires on the front of that mo-chine !
  4. Marcia
    Marcia
    Stogy, swade41 and lothiandon1940 like this.
  5. Marcia
    Marcia
    Put the cross member for the rear shocks in this morning. Next will be the front shocks or drive shaft hoop.
    But first we're taking a week of for racing. IMG_20200828_110132679_MP.jpeg IMG_20200828_110205921_MP.jpeg
    brEad, 41 GMC K-18, Stogy and 5 others like this.
  6. Marcia
    Marcia
    Thanks!
    Stogy and lothiandon1940 like this.
  7. Bearing Burner
    Bearing Burner
    from W. MA
    Building sled for bed extraction.
  8. Marcia
    Marcia
    We'll probably be there Sunday. Thank you.
    lothiandon1940 and chryslerfan55 like this.
  9. Marcia
    Marcia
    Just a side note. I got in my friends Factory Five Daytona and made a couple of passes. Ended up in the 2 club. IMG_20200905_170210_993.jpeg IMG_20200905_140739374_MP.jpeg
  10. norms30a
    norms30a
    Congratulations on 202.192.
  11. 41rodderz
    41rodderz
    from Oregon
    Big time CONGRATS :):cool::cool::cool::cool:
  12. Budget36
    Budget36
    I see the TA mount on the driver side of the rear, what did the rear end come out of?
  13. Marcia
    Marcia
    Stogy, Budget36 and lothiandon1940 like this.
  14. Marcia
    Marcia
    Thanks, got that checked iff the bucket list. Now back to work on the truck.
  15. Marcia
    Marcia
    Thank you very much!
  16. Marcia
    Marcia
    Drilled out the spot welds and removed the seat riser. Anyone need one? IMG_20200910_163053322_MP.jpeg
  17. Marcia
    Marcia
    Finally got the cab apart and set thw cowl on rhe frame. The master parts book really made the decision to do this easier. IMG_20200915_154849151_MP.jpeg IMG_20200915_154910846_MP.jpeg
    41 GMC K-18, LAROKE, Stogy and 4 others like this.
  18. Marcia
    Marcia
    Got the floor out of the cab and onto the frame. This will make it a lot easier to build the roll cage. The cab has wooden blocks for body mounts. IMG_20200918_133151_051.jpeg IMG_20200918_124244218_MP.jpeg
    41 GMC K-18, Stogy, swade41 and 2 others like this.
  19. Marcia
    Marcia
    Got te drive shaft loop installed. Has anyone else built a race truck? IMG_20200922_162834870_MP.jpeg
    Just Gary, Elcohaulic, Stogy and 3 others like this.
  20. Marcia
    Marcia
    KUNFEWZYUN, Stogy and lothiandon1940 like this.
  21. Marcia
    Marcia
  22. gas pumper
    gas pumper
    Used drag racing front runners are perfect for LSR racing. Cheap at the swap meets, low rolling resistance, they can handle high pressure, and come in lots of sizes from 23 t0 28 inches tall for ride height and gearing changes.
    Stogy, BabbitBeater and Marcia like this.
  23. Marcia
    Marcia
    Sat the cab back on the frame. We put the main hoop in to see how it will fit. Soon it will go to Bob Dauernheim's. He will build the roll cage. IMG_20201109_151450282_HDR.jpeg
  24. jimmy six
    jimmy six
    The side bellhousing/engine mounts look solid or rigid....gonna give you some nasty vibs and resonense unless I'm missing how the brackets are attached at the frame....Looks Great
    Stogy likes this.
  25. Marcia
    Marcia
    We had a similar set up in the 57 Chevy with no issues. This is the same bell housing. What do you suggest?
  26. Marcia
    Marcia
    The truck arrived at Bob Dauernheim's for the roll cage. Lots of discussion and planning going on here. IMG_20201111_134510306_HDR.jpeg IMG_20201111_104936252_HDR.jpeg IMG_20201111_102416487_HDR.jpeg
  27. Marcia
    Marcia
    Having the truck at Bob Dauernheim's shop is great. He's such an artist with the metal work. He replaced a header panel that was rusted out and now we have a windshield that opens. The cab is laying on its back. Got some work done on the roll cage, too. IMG_20201116_120058997_HDR.jpeg IMG_20201116_131722440_HDR.jpeg IMG_20201116_141218050_HDR.jpeg IMG_20201116_163216971_HDR.jpeg IMG_20201116_142742292_BURST001_COMP.jpeg
  28. Marcia
    Marcia
    More work on rhe roll cage. Looks like I can't use the original steering wheel. I was hoping I could. IMG_20201118_163405777_HDR.jpeg
  29. Marcia
    Marcia
    Got a lot done today since we're taking the rest if the week off. Seat brackets, window net, and seat belt tabs. Did I tell you that the guy that built Bill Elliot's 200 mph NASCAR is building my roll cage? IMG_20201125_125717520_HDR.jpeg View attachment 4887907 IMG_20201125_154941769_HDR.jpeg IMG_20201125_170941447_HDR.jpeg
  30. Stogy
    Stogy
    Go @Marcia Go...I'd say you have the go fast bug Bigtime...and experiencing 200+ already...that's a timewarp away from the Jalopy Racing you were doing a couple of years ago...congrats...;)
    41 GMC K-18 and chryslerfan55 like this.
