Projects Clark Coupe Build
Discussion in 'Traditional Hot Rods' started by etboy97, Dec 21, 2016.
  1. etboy97
    etboy97
    Seat installed along with roll up rear window and rear quarter glass.
    Finished restoring the 48 Ford steering wheel and added a modified Olds horn button. Got it installed along with the steering column, turn signal switch, and tach.
    I wanted a one off shift knob and took a try at making one. Started with a F1 shift knob and turned a recess in the top and glued in a 1938 Fisk Tire token. (I collect Fisk Tire stuff as it's my last name).
    Sent from my Pixel 3a using The H.A.M.B. mobile app
  2. The37Kid
    The37Kid
    Years ago I sold some FISK stuff on eBay to a guy named FISK. Had to ask, and it turned out his Grandfather was the little kid in the PJ's. Car is looking great. Bob
  3. Well done there Mr. Fisk:)
  4. loudbang
    Knob looks "store bought" good work :)
    brady1929 likes this.
  5. MMM1693
    MMM1693
    WELL DONE!
  6. etboy97
    etboy97
  7. Very nice build! We'll help you out with some power. ;)
    119576930_10224395124972721_4655654943933009457_o.jpg 119590169_10224395125492734_6141642831336696350_o.jpg IMG_0692 (2).jpg
  8. Love this!
    nor6304 and loudbang like this.
  9. etboy97
    etboy97
    loudbang and mctim64 like this.
  10. etboy97
    etboy97
    Got the headlights converted to run 1157 short bulbs and painted.
    The wheels are blasted and freshly painted.
    Other then a few small odds and ends I am now just waiting for the engine to get back. I did just replace my front wheel cylinders which even though new kept leaking even after I took them apart and rebuilt them. The second pair of new ones seem okay so far.
  11. neilswheels
    neilswheels
    from England
    Just found this build, great work, a lot to take in and use, including that in tank electric fuel pump. I spent ages trying to find something that would work with carbs, but there just didnt seem to be any info out there, so I purchased an external carter, but now, I think I may go this route. Do you need a pressure regulator to run carbs with this setup, and what filter did you use? Thanks
    Stogy and loudbang like this.
  12. etboy97
    etboy97
    This is a low pressure fuel pump. Only 4psi Max so no regulator should be needed. I have still not run this setup. 51box has been using this pump with multiple carbs with good results. I have a Wix screw on fuel filter mounted on the inside of the frame rail.
    Stogy, pprather and loudbang like this.
  13.
  14. etboy97
    etboy97
  15. Aaron D.
    Aaron D.
    Very nice!!
  16. I agree.
  17. Nicely done! Top came out beautifully.
  18. Part Timer
    Part Timer
    Really enjoyed your build thread. Your work is tight and right. Hope you get your Olds motor back soon.
  19. etboy97
    etboy97
    Took a stab at polishing my vintage Weiand valve covers.
    They had a lot of nicks and scratches. I started with 180 grit and worked my way up to 800 grit them polished them with my converted bench grinder. They are not perfect and some nicks are just too deep to get out but I am happy with the way they turned out.
    I was thinking that I would paint between the fins but am not sure if I want to do it as I like how they look now. The area between the fins is glass beaded.
  20. The37Kid
    The37Kid
    Rocker covers look great. The whole project looks great, really like the steering wheel. Sold some FISK stuff on eBay years ago to the son or grandson of the kid in company logo. Bob
  21. 51box
    51box
    from MA
    Car looks awesome @etboy97 all the details coming together
  22. general gow
    general gow
    MODERATOR
    man, this is a beautiful car. holy smoke.
  23. etboy97
    etboy97
    Its been a long time since I posted an update. The project has been waiting for the engine to get done. Lesson learned is that if I want a popular engine guy to do my engine then I need to get in line way earlier. Good news is that the engine has been started. The block has been bored 40 over. The heads have new guides, exhaust seats, and 1.94/1.6 stainless valves. PXL_20210709_015205688.jpg PXL_20210709_015251326.jpg
  24. nor6304
    nor6304
    from Indiana
    Car looks really good Valve covers & dash panel look awesome !
  25. sloppy jalopies
    sloppy jalopies
    sharp, well done.
  26. camcrusher
    camcrusher
    from Candor, NY
  27. etboy97
    etboy97
    Drove up to central California on Friday and picked up my engine from Tim at Hanford Auto. I am looking forward to going back to work on this project.
  28. so what did Jim do to the engine? Can you share some specs on the rebuild?
  29. etboy97
    etboy97
    The motor was bored 40 over (it was previously 30 over). The heads have new guides, hardened exhaust seats, and 1.94/1.6 stainless valves. Cam was reground with a 270 duration profile. Rocker arm assemblies were rebuilt plus the other usual new parts.
  30. etboy97
    etboy97
    Just finished painting the motor.
    The water pump got sent out last week to be rebuilt. I have the distributor torn apart and the bushings look real good so will clean it up, paint it and get it back together. The vacuum advance leaked but I was able to find a NOS one on ebay that works fine.
    oliver westlund and loudbang like this.
