Technical ***August 2020 Banger Meet Thread - More of the Same***
Discussion in 'Traditional Hot Rods' started by Jiminy, Aug 1, 2020.
  1. V4F
    V4F
    from middle ca.
    ive tried that .... very loud ! if you move the exhaust behind driver , it will be better in the cab .
    these lil 4 bangers are loud un muffled
  2. Steves46
    Steves46
    from Florida
    Thanks. That sounds like to route to take.
  3. Steves46
    Steves46
    from Florida
    Thanks. Will either remove the baffles from my muffler or install a flow through resonator.
  4. hardtimesainit
    hardtimesainit
    Hey Steve,
    You dont have to cut your muffler apart.
    Many years ago i pondered same as you re muffler.
    My remedy .... put a looong 5/8” drill in drill motor. From both ends of muffler, drill as much as you like.
    Good results IMO. Guys looked at the stock muffler and ask.... how did you get it to sound like that !
    Choices are good, eh !
  5. wheeldog57
    wheeldog57
    "Remembered to install spring and plunger for the camshaft"
    I am in the process of putting my A motor back together. I took it apart last year and was careful to clean, label, and bag all the parts (my first banger) and I do not remember a spring or plunger behind the timing cover, am I missing something? 20200811_195049.jpg
    Note: I did not pull out cam or crank gears.
    Man, I hope I didn't mess up. . . .
  6. wheeldog57
    wheeldog57
  7. kb9jlo
    kb9jlo
    from Central IL
    1. H.A.M.B. Chapel
    I have a 30 Murray Body Fordor but mine has a whole lot more "patina" than yours does. LOL. Thanks for the inspiration. I'd love to build an engine just about like that. Very nice!
    Star 351 likes this.
  8. guitarguy
    guitarguy
    Boring pic, but a box of dreams.
    Crate contains 2 Model A cranks, 1 Model T block, Stipe "Laruel-Roof" Camshaft, a set of A rods, and some misc pieces. All on it's way to Tulsa Oklahoma to become one, and a spare crank for the shelf. Pistons aren't done yet, Ross Pistons is working on those, custom 7.5 : 1 compression. Shes gonna be runner!
    Outback, winduptoy, Binger and 3 others like this.
  9. Mikko_
    Mikko_
    from Sweden
    On the inside of that little round "bump" (center of timing cover) there should be a little spring and plunger.
    I bought a new spring and plunger from Snyder since mine were missing.
    winduptoy and wheeldog57 like this.
  10. 31jalopy
    31jalopy
    Hi guys, been doing some research on Banger builds and need some help. They say counter weights to crank stop vibration but does it add HP? higher RPM? Have heard milling A crank down to look like T crank? is this weight saving to spin quicker? next big question, lightened flywheel adds faster RPM but will this add HP? to tie in with first question counter weights on crank defeat loss of weight removed from flywheel? yes i know weight of flywheel on bearings no good from flex to crank so counter weighted crank evens the load across all bearings? cheers for the help guys. and yes im chasing HP and it cost $$$$$$
    winduptoy likes this.
  11. Counterweights don't add horsepower - they just help keep it inside for longer.
    Outback, kb9jlo, winduptoy and 3 others like this.
  12. Jet96
    Jet96
    from WY
    E94CDBAC-9F24-4BDA-AE8E-17849E2EDB08.jpeg The shadows make the holes look bigger- they were punched in maybe 1/8"...small end had six 1/4" holes. Loud as these things are with a straight pipe I was surprised it wasn't a lot louder. Rewarding little project for sure...
    barrnone50 and winduptoy like this.
  13. Star 351
    Star 351
    I do have a laycock overdrive for it, but its probably going to be a while before that makes its way in
    Thanks, my sedan used to be my grandfathers its un restored, i just wanted to make it a good driver,this engine doesn't have a whole lot of money into it mainly alot of time and elbow grease but well worth the effort
    kb9jlo, winduptoy and Jet96 like this.
  14. railcarmover
    railcarmover
    Adding fuel and compression raises horsepower on a stock engine.A stock model a crankshaft and flywheel will provide good service if properly maintained.Your questions pertain to torsional vibration,a flaw (if you want to call it that) in design,the harmonic imbalance of a four cylinder engine causes the crankshaft to vibrate like a tuning fork.If you plan on pumping the horsepower way up and driving it cross country at sustained freeway speeds it can be an issue..around town bar hopper not so much.
  15. wheeldog57
    wheeldog57
    I went over to see Ricky at Rayco Machine this morning. He said "yes, you definitely need that spring and plunger. If not your cam will move out and break stuff" of course he had these in stock. Ricky is straight out with work now because he does Babbitt work on anything you bring him. He took the time to answer my stupid questions and locate the parts I needed in his vast collection of goodies. Thanks Rayco
    waxhead, winduptoy and Jet96 like this.
  16. I would ask you intention of this build, do you plan to drive it daily or just weekends.
    What you are asking about, lightening the "A" crank was done back in the racing circles.
    The cranks were changed out regularly, like every week or two of racing. Honestly, it is the wrong direction to look for power.
    My buddy, Jim Brierley has a book out that goes over the "A"/"B" motor pretty thoroughly.
    Your questions will be answered and you will have an idea what the cost is.
    Start looking in swap meets for HC head, larger carburetor and manifold and a centrifugal advance distributor.
    All of these can be had fairly inexpensively, you will need to look at them closely, caveat emptor.
    There are reproduction parts available, some better than others, as your budget allows.
    Good luck, post back here, there are a bunch of good guys with knowledge, John
  17. Mikko_
    Mikko_
    from Sweden
    Valves and guides are in, and I followed Jim Brierley's advice and did a preliminary setting of valve clearance without the valve springs in place.
    All good I think so on to the springs and retainers next, and get that dirt out of my cylinders :eek:
    Old Dawg, Jet96, waxhead and 4 others like this.
  18. railcarmover
    railcarmover
    I threw that spring away.cut and fit a slug inside the plunger,then drill and tapped that 'tit' to make it a thrust button instead of a cam plunger
    brjnelson and guitarguy like this.
  19. The thrust button is so pase'
    How about a thrust pump?
  20. railcarmover
    railcarmover
    It renders wood sir...to an old ham and egger like me :)
    Old Dawg and Outback like this.
  21. 1932tub
    1932tub
    Does anyone here have any experience running con rod and main bearing nuts other than castellated nuts and split pins?
  22. V4F
    V4F
    from middle ca.
    my rods are self locking , but mains are still using castle / pins
  23. railcarmover
    railcarmover
    High temp high quality Nyloks on the rods,tall grade 8 phosphate coated nuts with locktite on the mains..
  24. joemac05
    joemac05
    GuyW, 1949*john, kb9jlo and 5 others like this.
  25. You still have the parts numbers, and source? I am at that point myself.
  26. railcarmover
    railcarmover
    http://www.usfastener.com/insertlocknut.html
    Had a good surplus fastener supply in Sacramento (had,he just retired) where I got both.The nylock's are mil spec high temp,to 350 degrees.The compound doesn't degrade slowly..I figure if my oil temp gets close to that high I'm in trouble anyway,aside from them being torqued.The main brg nuts are common..
  27. V4F
    V4F
    from middle ca.
    beautiful motor . john your a wizard
  28. Mikko_
    Mikko_
    from Sweden
    Valve springs are in, as is the drive mechanism for the distributor and oil pump.
    Looking more and more like an engine.
    The threaded hole that is seen in the center of the block (to the left of the fuel pump mount), what is it for?
    Oil pressure sender?
  29. V4F
    V4F
    from middle ca.
    i would think so ............
  30. GuyW
    GuyW
    Why does the 2nd spring from the left look like it is bent in a curve?
