Projects ONE PIECE AT A TIME ('47 FORD COUPE)
Discussion in 'The Hokey Ass Message Board' started by topher5150, Mar 1, 2017.
  1. topher5150
    topher5150
    Thor1 likes this.
  2. Dick Stevens
    Dick Stevens
    I can see it is an oval head, but other than that, I'm not familiar with that type of screw!
  3. That's a 'special' and I've heard those referred to as 'captured' or 'captive' fasteners. They have to be threaded into whatever they secure and the reduced-diameter shank retains them in the piece. Usually used on lids and covers that may be removed on a regular basis. I've also seen them with washers, pal nuts or c-clips on the shank to retain them. You can buy them (McMaster-Carr shows them) but finding an exact duplicate may be tough.
    Most you'll find have a machine thread on them, this one appears to be a sheet-metal type thread, which may make it hard to find.
    1Nimrod and Thor1 like this.
  4. topher5150
    topher5150
    I'll try those names see what i come up with. This screw goes on the headlight bezel that i got from that Buick.
  5. Worse case, buy a standard oval-head sheetmetal screw and turn/grind the shank down to the minor diameter of the screw thread.
    1Nimrod, Thor1 and topher5150 like this.
  6. These are generally found on industrial equipment and on some types of gear are OSHA required.
  7. topher5150
    topher5150
    Is it ok to trim the front cross member? My panhard bar is way too close IMG_20200707_111856290.jpeg
    Sent from my moto z4 using The H.A.M.B. mobile app
  8. topher5150
    topher5150
    Is this a thing? I figured since neither one of us smoke and my wife will be on her phone the entire time she's in my car, why not make these into chargers. IMG_20200718_164001923.jpeg
  9. Last edited: Jul 18, 2020
    1Nimrod, topher5150 and Thor1 like this.
  10. topher5150
    topher5150
    I know I'm no where near paint, but I've been seeing this on other cars... definitely thinking about doing this to the rest of the car. If course the stud holding the gauges in place popped off. IMG_20200728_145828615.jpeg
    1Nimrod, brEad and Thor1 like this.
  11. topher5150
    topher5150
    Something followed me home not sure how that happened ... Oh well IMG_20200802_185024034.jpeg
    1Nimrod, hotrodharry2, brEad and 2 others like this.
  12. topher5150
    topher5150
    Did some welding on the A pillars. My hinge pins came in today so I got one door hung. I think that's enough annoying the neighbors for today. IMG_20200808_173654309.jpeg
    1Nimrod, slv63, brEad and 2 others like this.
  13. topher5150
    topher5150
    Are there any write ups on replacing the vent window regulator gears for the I cars?
    Thor1 likes this.
  14. topher5150
    topher5150
    Messing with the steering column today. Do you measure the drop from the center or the top of the column? Found a wooden crate that puts me about 10" off the floor. Needless to say I might need seats that sit a little lower 2921.jpeg
    1Nimrod, slv63, Thor1 and 1 other person like this.
  15. razoo lew
    razoo lew
    from Calgary
    Lots of assembly information in this one, maybe not all....
  16. topher5150
    topher5150
    that might be what i'm looking for thanks. when i got the car there wasn't a whole of the little parts and i don't want to start a million threads about how this and that goes together.
  17. topher5150
    topher5150
    Found these cougar cores. Might have to raise them up so the wife doesn't look like miss Daisy.
    IMG_20200818_140633731.jpeg IMG_20200818_151415724.jpeg IMG_20200818_150905200.jpeg
    1Nimrod, RICH B, Thor1 and 1 other person like this.
  18. phat rat
    phat rat
    Much better. IMHO the seat back should be window level or below. No high back buckets
  19. topher5150
    topher5150
    I couldn't do the giant conversion van street rod seats. What's a good rule of thumb on where to mount these kind of seats?
    Thor1 likes this.
  20. phat rat
    phat rat
    Are they on tracks? If so mount so that you are comfortable and have some adjustment forward and back
  21. topher5150
    topher5150
    See I'm not such a terrible welder
    I used that 1.5" square tubing that was originally for the engine. I figured it would hold my fat ass better than a SBF. A couple of plastic washers to level it out. Now I'm going to spend the rest of the afternoon I'm my car spinning the steering wheel making car noises IMG_20200820_101656871.jpeg IMG_20200820_141900693.jpeg IMG_20200820_141919182.jpeg
  22. topher5150
    topher5150
    Went to C-Tech today and got a junk connecting rod for a column drop... Saved me $100, but I'm not liking how that tubing makes it sit to low.... Easy fix IMG_20200825_152055437.jpeg
    1Nimrod and chryslerfan55 like this.
  23. topher5150
    topher5150
    Got a little ambitious today. Next step find someone with a torch to adjust the pedal
  24. phat rat
    phat rat
    I'm curious. Why the booster/master was installed so far inboard?
    1Nimrod likes this.
  25. BamaMav
    BamaMav
    from Berry, AL
    Me too. I put mine on the Lincoln so that the pedal was on the left side of the steering column. That pedal is right where the gas pedal should lay.....
    I would have mounted the booster closer to the hood spring. That firewall will flex, did you put a brace from the booster to the dash? I used the Speedway hanging pedal kit, it comes with a brace, mine fits right under the steering column on mine. Mine still has a tiny amount of flex with the brace, but nothing like it would have without it.
  26. topher5150
    topher5150
    Most setups I saw had them right about there and with the way the pedal curves it puts it pretty close to the original brake pedal location.
    I have not reinforced the firewall yet but that's on the list
  27. topher5150
    topher5150
  28. Because if using a junkyard pedal assembly, they're almost always braced off the steering column and are setup to attach there.
    1Nimrod and topher5150 like this.
  29. topher5150
    topher5150
    I've been wrestling with what to the bumpers. Initially I was thinking about sliding the stock bumper back a couple inches but it still leaves a big gap and I don't wat to deal with the stone guard. I found the nerf bar thread on the hamb and I'm starting to warm up to using VW nerf bars. They're a little beefier looking and cost a lot less Screenshot_20200913-100123.jpeg IMG_20200912_164210195.jpeg
    1Nimrod, Thor1, brEad and 1 other person like this.
  30. topher5150
    topher5150
    1.jpeg IMG_20200918_171656285_HDR.jpeg A little before and after...
