Hot Rods Does a 671 GMC Blower use the same gaskets as a Weiand 671
Discussion in 'The Hokey Ass Message Board' started by Bonehead II, Aug 6, 2020.
  1. Bonehead II
    Bonehead II
    As the thread ask ?
    Thank You
  2. Tim
    Tim
    from KCMO
    Which gasket
    squirrel likes this.
  3. squirrel
    Same base gasket.
  4. Bonehead II
    Bonehead II
    both ends and front hub, carb plate
  5. squirrel
  6. GMC 671 was there first and is the unit they All copied.
    weiand uses gmc gaskets
    Deuces likes this.
  7. One and the same. The base pattern is the same for all through the 14/71. The opening is what's different. The front cover and rear plates are all the same dimensions. The top opening is different on the Danekas and there are some hybrids that have been developed.
  8. Bonehead II
    Bonehead II
    Thank You
    Deuces likes this.
