Technical how to remove one-shot from painted car?
Discussion in 'The Hokey Ass Message Board' started by cederholm, Jul 28, 2020.
  1. cederholm
    cederholm
    Hey guys,
    I'm considering buying a car that was nicely hand pin-striped. The only problem is, words were also pin-striped onto it. Small words, but still.
    What's the best way to remove without disturbing the paint?
    Thanks,
    Carl
  2. Slopok
    Slopok
    Easy Off oven cleaner. Sounds strange but trust me, it works!
    drdave, Hot Rod Nut and lurker mick like this.
  3. Jack E/NJ
    Jack E/NJ
    from NJ
    >>>Small words,>>>
    What kind of small words? Good words? Bad words? How about a closeup? Jack E/NJ
    427 sleeper likes this.
  4. RatRoy
    RatRoy
    Easy Off works be pay close attention......
  5. Depending on what paint was used, old vs. new one shot and how long it has been on the car, I have seen some you can take off with a fingernail. I would not make it a deal breaker.
  6. I had my Mysterion fully striped by a pro but the color of blue was too dark and the line was too wide. Didn't want to ruin the catalyzed urethane candy lime gold paint job so I sanded all the striping off with 400 wet paper. Went really fast and a cinch to quickly re-color sand w/ 600/1500 and polish before restriping.
  7. seb fontana
    seb fontana
    from ct
  8. Had some removed from mine. I think they sanded it off and polished the clear. Can't tell it was ever done.
    Phil
  9. cederholm
    cederholm
  10. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    non hardener will come with easy off. If it has hardener easy off wont touch it.
    Yellow smelly can, dont bother with the blue can
    i like to spray some in a cup, then dab it on with a qtip so i can keep it on the stripes and not the paint. ive had it slightly discolor light colored paint a couple of times. In those cases a quick buff of the paint has worked.
    dab it on, let it sit for 2 to 3 minutes then scrub, repeat as needed
    ClayMart, 427 sleeper and lurker mick like this.
  11. MEK is what some of the better pin stripers use to clean the paint before striping and to remove old pinstripes.
  12. 427 sleeper
    427 sleeper
    No. 7 rubbing compound out of a tin can... It's traditional... :rolleyes::D;)
    warhorseracing likes this.
  13. Roadking89
    Roadking89
    Another one that sounds crazy is the mr clean eraser. I took names off the back of a bike one with one and kept water on it the entire time
    warhorseracing and 427 sleeper like this.
  14. Marty Strode
    Marty Strode
    They make plastic ones that work too.
  15. jimmy six
    jimmy six
    EasyOff with a 1/2” cheap paint brush with bristles cut dow to 3/8” with some dykes. Sanding or rubbing will remove your base paint and you don’t want to do that if possible. Just remember if the main paint is faded you may still see it unless it is clear coated before the stopping.
