Hot Rods Model A subrails/ subframe dimensions
Discussion in 'The Hokey Ass Message Board' started by fivefour, Jul 4, 2020.
  1. fivefour
    fivefour
    Does anyone have dimensions or know where to find them for a 30/31 roadster subrame/ subrails?? Seems easier and cheaper to buy the floor from brookville unassembled but I don’t have access to a model a for measurements. Or is it best to just pay extra for brookville to assemble it??
  2. lostone
    lostone
    from kansas
    Just use the search above. This has been asked several times and answered several times.....
    Pist-n-Broke likes this.
  3. Mr48chev
    Here is one thread that I had saved. Dimensions are metric though. https://www.jalopyjournal.com/forum/threads/model-a-subrail-fab.1082598/
    It's a pretty good discussion on the subject.
    As for buy or fab, that might entirely depend on your fab skills or depth of wallet.
    Some of us can swing a few pieces of tubing at a time and work a bit and then buy more and work a bit more and others are able to go all in and buy the complete setup and install it. Neither is wrong it's just the difference in how you go about it.
    The 31 Vic I have has almost all wood subframes in the floor that have have to be replaced but the actual metal floor boards are in pretty decent shape.
    5window likes this.
  4. fivefour
    fivefour
    Thank you, I seen this diagram on a couple threads but I believe it’s for a 28/29. I’m pretty sure the later ones are a bit different. I called brookeville but the fella wasn’t helpful at all and told me to call Snyder’s who told me to call brookeville
  5. fivefour
    fivefour
    I’ve searched multiple times, maybe I’m using the wrong search words but can’t find anything specific to what I’m looking for
  6. GordonC
    GordonC
    Here. All you need to do is convert it!
  7. sdluck
    sdluck
  8. fivefour
    fivefour
    I see they have frame dimensions which is great, but I don’t see subframe dimensions
  9. Travis latour
    Travis latour
    from Putnam CT
    I’m looking for the same info. Everyone keeps posting the same picture but that’s for a 28-29.... anyone have a 30-31 subframe they would kindly take some measurements from?
  10. Dino 64
    Dino 64
    from Virginia
    Have a 31 coupe, don’t know if the dimensions are the same, if they are I’ll measure them
    lothiandon1940 likes this.
  11. sdluck
    sdluck
  12. sdluck
    sdluck
  13. bct
    bct
    if you buy them you will be cutting them up anyhow. front and back . id say build them .
  14. Travis latour
    Travis latour
    from Putnam CT
    If you could that would be awesome, measure from outside to outside of the subrails at the front edge of the three subrail supports like this.
    *******FUTURE HAMBERS, PLEASE DO NOT GO BY THESE MEASUREMENTS!!! JUST AN EXAMPLE OF HOW I WANT IT TO BE MEASURED!! ********
    As you can see my subrails are not finished haha
    Thanks in advance!!
    lothiandon1940 and Dino 64 like this.
  15. Dino 64
    Dino 64
    from Virginia
    No problem, I’ll post after I measure o_O
    lothiandon1940 and Travis latour like this.
  16. Dino 64
    Dino 64
    from Virginia
    Ok, going from front to back. The first one is 40 1/4”
    Second 43 1/4”. The rear is just shy of 43”. Mine is on a 32 chassis so the rear measurement is just ahead of the wheel well. Further back the sub rail was modified for the 32 kick up.
    Hope that helps :):)
    Just Gary and lothiandon1940 like this.
  17. Travis latour
    Travis latour
    from Putnam CT
    You are the best my dude!!!!!!!
  18. Dino 64
    Dino 64
    from Virginia
    Good luck with it o_O
  19. 5window
    5window
  20. Travis latour
    Travis latour
    from Putnam CT
