HD powered Reverse Trike
Discussion in 'The Antiquated' started by '52 F-3, Nov 19, 2019.
  1. '52 F-3
    '52 F-3
    I marked more stuff off todo list, exhaust done (except wrapping with "heat wrap")
    Deuces and Okie Pete like this.
  2. pumpman
    pumpman
    Man, there’s a lot happening in a small space! Will serving it be a challenge?
    ccain likes this.
  3. Nah, as long as he can get to the Primary, he's golden. Doesn't look more cramped than in a Road Glide or Softail. I am digging the hell outta this build! This thing is bitchin'. I'd love to tear around town in it.
    '52 F-3 likes this.
  4. pumpman
    pumpman
    Totally agree on the build! Glad to hear servicing will not be a task. I’m not a cycle guy so I have no clue.
    '52 F-3 likes this.
  5. '52 F-3
    '52 F-3
    20200613_164604.jpg Probably should have tied up a few more loose ends(and wires), but weather was great today.
    So, obligator maiden voyage video...(with alittle tire howl)
    Deuces, Lepus, 282doorUK and 5 others like this.
  6. 1-SHOT
    1-SHOT
    from Denton
    Why did you post a video and block it. I would like to see it. Frank
    '52 F-3 likes this.
  7. '52 F-3
    '52 F-3
    sorry about that, new Youtube account... how about now?
  8. 1-SHOT
    1-SHOT
    from Denton
    Got it thanks
  9. pumpman
    pumpman
    How did she handle?
    '52 F-3 likes this.
  10. Looks awesome!
    '52 F-3 likes this.
  11. Now see what you went and did?!?
    Now, I'm sitting here, salivating, and giving my Softail the hairy eyeball. Feverishly glancing back and forth between the cutting torch and the bike. Hmmm. :)
    I hate you! :D:D:D
    brEad and '52 F-3 like this.
  12. '52 F-3
    '52 F-3
    Pumpman: it handles pretty darn good, almost no body roll. but, rear suspension is too soft (and lower than I want)... got some wheel hope once. Turning radius seems too big, turns like a car....
    ccain…. LOL, very funny.
  13. '52 F-3
    '52 F-3
    The Good; Has plenty of power and handles good.
    The Bad; Shaking engine, more than I expected (exhaust hangers need to be softer). Master cylinder started leaking, lots of primary/tranny/chain noise (maybe interior will quite a little) fuel gauge quite working and had a few fuel starvation problems.
    The Also; Needs practice to drive, clutch on right hand shifter is very odd. Can't decide to 2 foot brake/accelerator, or right foot both.... (had a few issues of hold brake and letting out clutch :(
  14. pumpman
    pumpman
    Thanks for the reply. All things considered it sounds like not bad for the first run.
    '52 F-3 likes this.
  15. 38bill
    38bill
    from Minnesota
    Thanks for the video! As cool as those crazy tires look I bet they are not ever going to give you a smooth, quite ride. What are they off of anyway?
    '52 F-3 likes this.
  16. '52 F-3
    '52 F-3
    Front tires are "dual sport" motorcycle rear, designed for both street and off road use.
  17. '52 F-3
    '52 F-3
    Took to get weighed and a "Pre-Inspection" look at by PA certified "enhanced inspection mechanic" yesterday. Got few little things he wants changed, but now am ready to finish welding and painting chassis.
    It weighted 1320 lbs. including me...
    Deuces, brEad, Cliff Ramsdell and 4 others like this.
  18. pumpman
    pumpman
    And just how cool is that. I think it turned out great!
  19. 64 DODGE 440
    64 DODGE 440
    from so cal
    What did you end up with for wheelbase and track? Like the results so far. Looking forward to seeing it with some paint on the bodywork.
  20. Birdnose
    Birdnose
    I'm loving this. It's the best kind of mutant.
  21. '52 F-3
    '52 F-3
    Not super happy with center console yet. I made out of 14 gauge and it is tough to work with. (under pad is storage compartment, hinges forward)
    So anyone have idea? looks like something should be between driver seat and center padded arm rest. like a parking brake lever... I was thinking a vintage ash tray or ? shifter boot will cover alittle of it....
    Deuces, Cliff Ramsdell and Okie Pete like this.
  22. davidvillajr
    davidvillajr
    Make a padded armrest. Everybody needs at least one armrest, and you don't have ANY since there's no doors. :D
    '52 F-3 likes this.
  23. '52 F-3
    '52 F-3
    The grey pad (with cup holds) works as an arm rest ok'ish for driver, but perfect for passenger.
  24. davidvillajr
    davidvillajr
    If it were asymmetrical the opposite way you could put in a grab handle for the passenger.
    Wouldn't want one for the driver, though. Keep both hands on the wheel if your tooting along that quick.
    '52 F-3 likes this.
  25. '52 F-3
    '52 F-3
    I was sitting in passenger seat, and a grab handle on the drivers side of pad might work pretty good for the passenger... still thinking...
  26. '52 F-3
    '52 F-3
    little bit of updates....
    So the rear end suspension was very soft, and is kind of "wiggly" when hard on the throttle, (also the steering seems pretty quick). So I swapped out the rear coil over shocks springs for heavier ones.
    also finally got around to removing front suspension brackets to finish welding and paint. These brackets mount the front axle to the leaf springs, control arms, shocks, sway bar links and steering rack.
    also progress on center console if anyone is following....
  27. pumpman
    pumpman
    Looking good, ahhhh, there’s nothing like tweaking and the beat goes on.
  28. Greg Rogers
    Greg Rogers
  29. Deuces, Lepus, Okie Pete and 3 others like this.
  30. Deuces, rbrewer, Okie Pete and 4 others like this.
