Technical 354 Hemi Timing gear drive
Discussion in 'The Hokey Ass Message Board' started by ratamahata, Jul 9, 2020.
  1. Hey Guys...I'm rebuilding a 57' 354 Cid Hemi Truck engine...I'm looking for opinions on the timing gear drive... It's reliable?
    My project 32 PU, toploader fourth gear tranny and Dana 44 rear end.
    I'm in Argentina, So parts are very rare here... I'll need to buy pistons and rings, main bearings and camshaft bearings and others parts too. Screenshot_20200709-201158.jpeg Screenshot_20200709-201154.jpeg Screenshot_20200709-201132~2.jpeg
    Sent from my Mi A1 using The H.A.M.B. mobile app
    Desoto291Hemi likes this.
  2. Pete Eastwood
    Pete Eastwood
    from california
    google , hothemiheads.com , for all your answers .
    ratamahata and Desoto291Hemi like this.
  3. RichFox
    RichFox
    Is the truck direct gear drive cam? Or chain like the cars? Are you talking about a stock cam drive or aftermarket? The stock cam drive lasted 50 years or so. That would make me think it's reliable.
  4. George
    George
    Put "Hemi Tech Index" in search, lots of info there. If normal timing chain the 318 LA will work with a spacer to keep the gear from locking on the cam plate. "73RR" here on the Board is Quality Engineered Components, a great guy!
    ratamahata likes this.
  5. Yes... direct gear drive...
  6. 73RR
    73RR
    Thanks George.
    ratamahata
    If the large truck front cover is not an issue then use what you have. Inspect the gear teeth for damage, if they look good then they should last a very long time.
    Remember that the truck engine were designed for long hours and hard work.
    Gary
    loudbang and Desoto291Hemi like this.
  7. Many thanks for the reply Gary... I always looked for info about the Hemi and I found your avatar in various forums... Awesome!
    I have some questions regarding using a 318 bellhousing with an adapter...can I use the truck oil pan? Or am I saying a stupid thing. I have the big truck bellhousing with the flywheel... Maybe would machined the flywheel to fit a 318 ring gear...
  8. Casting numbers on the heads... I found listed as 392 heads...
    Block numbers 354 56' to 59'
    IMG_20200710_164331.jpeg IMG_20200710_145757.jpeg IMG_20200710_145305.jpeg Screenshot_20200710-225535~2.jpeg Screenshot_20200710-225519~2.jpeg
  9. 73RR
    73RR
    Although your listing shows a '392 truck' application, I have never found any definitive information saying that a 392 was ever used in a truck......however, never say 'never' with 1950's MaMopar....
    As to the flywheel/bellhousing question, a 146 tooth flywheel can be used with the larger (143 tooth) LA bellhousing and block adapter. There is a slight difference in ring gear OD that can be 'fixed' at the starter.
  10. George
    George
    That head # isn't on my list. unless 1730348 in my refs is a typo...
  11. deucemac
    deucemac
    I built a 1958 354 2 1/2 ton truck block for my roadster. I ditched the front cover and cam. I had Schneider grind me a cam from a 1956 New Yorker, used a 360 timing chain and gears and a HOT HEADS timing cover. I also used passenger car heads instead of the truck heads. The truck timing cover weighs a ton and the cam turns backwards due to the gear drive. Been driving the snot out of it for 10 years now and very satisfied.
  12. George
    George
    Backward if 2 gears, 3 turns normal.
    ratamahata and Andy like this.
  13. sunbeam
    sunbeam
    I doubt anybody makes a 2 gear cam blank
  14. Andy
    Andy
    I would loose all the big heavy truck parts if the engine is for a 32. Engine length is always critical. I have a very nice tin cover if interested.
  15. deucemac
    deucemac
    I don't think Chrysler put a idler gear in their truck motors in the fifties .
  16. oldwood
    oldwood
    from arkansas
    I just listed spark plug wire covers for a 392 if your interested.
  17. George
    George
    According to the Tex Smith book they can come either way.
  18. George
    George
    Don't know if still in it or if available, but I've seen reverse rotation 354 dizzys in the NAPA catalog.
  19. sunbeam
    sunbeam
    George isn't' that just the drive gear that is different
  20. I have two ring gears... One, the original truck ring gear have 156 tooth.
    The other belong to a Dodge GTX... A Mopar coupe that was offered only in my country, equiped with a 318 V8.
    1594668969759.jpeg dodge-polara-gtx-v8-744360.jpeg 960b9709381ca983db96eca335f221f3.jpeg
  21. Pictures 1 and 2 are the 318 bellhousing for Dodge A230 trans... (Picture 3)
    I don't like de A230 trans, so my options are Dodge A830 and the 4 toploader...
    I have a toploader right now. Picture 4 1594669141259.jpeg 1594669166528.jpeg Screenshot_20200713-164106.jpeg 1594669601634.jpeg
  22. George
    George
    I'm thinking mirror image, but that was way back. Either the B or RB shaft is perfect length for a 331/354 using a LA dizzy & stock O/P set up, but turns the wrong way for using the actual B/RB dizzy. I'm thinking which ever is the right length would work on the 2 gear set up.
  23. sunbeam
    sunbeam
    I was just thinking if cam and distirbutor gears were cut so the distributor turns the same as a chain you get to use the same distributor and oil pump.
  24. TRENDZ
    TRENDZ
    Truck/ industrial had gear to gear timing. It will last forever, but....
    Because it is gear to gear, you would need a custom cam core to start with if you want anything but a stock cam. The core would need all the lobes in a different location from standard rotation. The cam core would also need the distributor drive portion of the cam cut in the opposite direction (Slant of gear teeth will be opposite)
    Much easier to ditch the stock gear drive, get a standard rotation cam& intermediate shaft, and enjoy the freedom of getting any camshaft spec you desire without spending $1000+ on a custom core.
    loudbang and ratamahata like this.
  25. 73RR
    73RR
    ...156 tooth ring gear ??????
    The top loader input shaft is too short for use with the 318 bell. It would need an aftermarket piece.
  26. Beanscoot
    Beanscoot
    The timing gear setup will have a few thousandths of an inch backlash, so give very consistent timing.
    I'd run the gear setup you have, if you are then unhappy with it, you can start looking for all the car parts to change it over to a timing chain at leisure.
