Technical 65 rambler American gasser
Discussion in 'Traditional Hot Rods' started by mrhp, Jun 6, 2020.
  1. mrhp
    mrhp
    from MICHIGAN
    My buddy just bought one and it is scary. Front steering and suspension needs to be redone. Straight axle job is horrible. Does anybody have one of these and can give me some pointers on how they did theirs. Will be a drag car, most likely not driven on the street. It has a 396 and a turbo 400. Any help would be appreciated to keep my buddy alive!
  2. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    Photos of what was done,can get you how it fix.
    squirrel and warhorseracing like this.
  3. mkubacak
    mkubacak
    A picture is worth a thousand words. Give us an idea what you are working with here.
  4. mrhp
    mrhp
    from MICHIGAN
    No pix, but is straight axle, spacers between springs and axle for more lift, steering box looks like it was mounted by Stevie Wonder, and welded by Ray Charles. I am looking for pictures and advice what people have used on these cars specifically. Will definitely save some trial and error on our part. We are most likely going to start over with all new components, just want a starting point.
    Had to see what one looks like, I think it could be cool.
    6inarow likes this.
  6. mrhp
    mrhp
    from MICHIGAN
    I will try to get some pix. It’s a street freak kinda thing now, but will be a gasser when it’s done.
  7. Jalopy Joker
    Jalopy Joker
    without close up pics of frontend only guessing - pic is example 20200606_163703.jpg of one
    6inarow likes this.
  8. JC Sparks
    JC Sparks
    from Ohio
    Look this guy up, he is on the hamb. Ted Chandler. He has a 62
  9. mrhp
    mrhp
    from MICHIGAN
  10. mrhp
    mrhp
    from MICHIGAN
    Best shot of it that I have.
  11. southcross2631
    southcross2631
    Look on the Southeast Gassers at the Rambler American that runs with that group. It goes straight down the track and wins races.
  12. squirrel
    Those blocks can't be helping anything....
  13. raven
    raven
    The offset of the front wheels aren’t helping either.
    t
  14. mrhp
    mrhp
    from MICHIGAN
    I told my buddy about the blocks and wheels already:D. He agrees. You should see how long the rear shackles are!
  15. wvenfield
    wvenfield
    That's like trying to walk on stilts let alone trying to run.
    There isn't a magic answer here. The axle should be OK set up properly.
    mrhp likes this.
  16. mrhp
    mrhp
    from MICHIGAN
    Once we get the car in the shop, we can take stock in what we have.
  17. southcross2631
    southcross2631
    High boy's used to be cool back in the 70's . they drove like shit . I had a 55 Belair that sat about like that Rambler .I drove it everyday and it was a handful. Thank goodness the 409 that was in it was a slug so I didn't kill myself.
    Straight axle cars do not have to give you a nose bleed when you get in them. Check out my avatar it was 11 inches from the pavement to the bottom of the body measured from right behind the front tire.
    You could drive it with one hand at 100 mph after I put a steering stabilizer on it.
    mrhp likes this.
  18. KandN Kustoms
    KandN Kustoms
    Man I really dig this car!
    It's exactly what I want to do to mine.
    You mentioned that you're taking it to more of a drag car than street?
    If so, are you going to use the original gas tank?
    If not, I sure would be interested in buying it from you. If it's in decent shape.
    By the way, if you ever need any extra parts, I have plenty!
    Practically a complete floor pan, and a extra gas tank too!
    Let me know if you're interested!
    Sent from my SM-G960U using The H.A.M.B. mobile app
