Technical ‘55 Brass Radiator Technique
Discussion in 'The Hokey Ass Message Board' started by ol55, May 28, 2020.
  1. ol55
    ol55
    from Virginia
    12489498-3E8A-4448-B0FB-E216AE21DB51.jpeg DDE10397-A3E0-4DE8-B1A7-12BF1D6C6CDB.jpeg Looking to get a polished brass finish like the one shown (not mine) and take out the dents. Not looking for perfect, more quick and clean looking.
    bchctybob likes this.
  2. inthweedz
    inthweedz
    If the dents are really bad, you will have to get a radiator repair shop to remove the top tank, so you can straighten them out, then have it resoldered back on.
    On saying that, polished brass looks nice, but the black paint helps dissapate the heat better..
  3. squirrel
    That would be a great radiator to learn on. Looks like it hasn't been on a car for a while. And the white stains in the core make me think that it leaks, and is not repairable. But I could be wrong, maybe it's just fine.
    You could take it to a radiator shop and have it checked for leaks, and flow.
    If you have the radiator shop remove the tank for you, then you can work on the dents. Good luck!
    ol55, bchctybob and brigrat like this.
  4. ol55
    ol55
    from Virginia
    Yes and yes. Came with a frame and has set for who knows how long. Has a cut support bar with a reinforcement added. Hope to try and mount it on my hardtop with a one piece glass front end. Thanks.
    bchctybob and chevy57dude like this.
  5. Been there done that. Looks good for a while, but hard to keep it that way. I never did get the little radii and corners right and the areas around the cap and core.
    ol55 likes this.
  6. You have to periodically re-polish it with Brass polish or similar compound but I agree, it looks nice. It was popular to do back in the 50s-60s in my area. Here is mine needing polishing again:
    I first used paint remover then Mother's polishing compound. Mine was fairly easy since it was a new radiator.
  7. Rex_A_Lott
    Rex_A_Lott
    The Navy is big on polishing brass. Once you take the paint off it's a never ending job to keep it nice. We used Never Dull ,a cotton wadding with some solvent soaked into it. You can also use Brasso. Good Luck
    jimmy six, CGkidd, ol55 and 5 others like this.
  8. 51504bat
    51504bat
    Given all the Brasso I used in the Army, no more brass for me. JMO
    jimmy six, ol55, Atwater Mike and 5 others like this.
  9. patsurf
    patsurf
    might as well have the brkt's unsoldered too-you are going to want it v 8 styled later
    ol55 likes this.
  10. X2 everything @56don said.
    Here's my ol' 55 Chevy. Pay no attention to the ribbed chrome hoses. :rolleyes:
    Blues4U, ol55, bchctybob and 3 others like this.
  11. Truck64
    Truck64
    from Ioway
    My dad told me they took a lot of the brass wheels and brass gee gaws & stuff from the submarine he served on, said they got sick of polishing them and went somewhere and got them chromed. Everybody thought they looked slick, and it was easy to keep shiny. Then, they had an inspection, and they really blew a gasket over that.
    seb fontana, ol55 and Atwater Mike like this.
  12. Truck64
    Truck64
    from Ioway
    They "improved" Brasso anyway, it doesn't work like it used to.
    ol55 and loudbang like this.
  13. 4ty
    4ty
    In the service (Navy) when inspection came I just bought a new buckle.............
    Paul in CT
  14. Man Gary that is an amazing shine! Mine never looked that nice, and I never did like the area where the sides were soldered to the tank.
    loudbang, ol55 and Just Gary like this.
  15. brigrat
    brigrat
    from Wa.St.
    Yours looks to be a stock Cellucore (sp.) radiator and your example is a tube type with an original brass tank. The Cellucore rads are hard to fix, the leaks just keep leaking beyond the "fix". Most shops just plug the row from top to bottom, not worth using. The old brass tanks have expanded and contracted over the years and will stress crack over time, again not worth investing in unless very solid. JMO again!
    loudbang, ol55 and squirrel like this.
  16. squirrel
    sounds like bigrat has some experience with the old Harrison radiators, as well.
    CGkidd and ol55 like this.
  17. brigrat
    brigrat
    from Wa.St.
    14 Years in a Radiator shop just makes a guy gun shy of the older radiators that have lived a full life! There's always exceptions and I to have polished a few for my own tri fives...…………...
  18. bchctybob
    bchctybob
    Over the years a lot of my cars had that polished top tank and polishing it was just part of spiffing up everything under the hood. Back then it was Brasso or SimiChrome and plenty of elbow grease. My cars also had (and have) magnesium Halibrands so I’m not to proud to do some cleaning. These days there are better choices for polishing, I use Wax Depot liquid metal polish on previously polished surfaces.
    My current ‘56 Chevy has an aluminum radiator, if I wasn’t busy with other projects (and expenses) it would be gone and a shiny brass version bolted in there.
  19. ol55
    ol55
    from Virginia
    5850B31B-A779-4F00-9CD6-871215D935D6.jpeg 2C94F083-F354-48D6-A4E2-A2E2672FFE05.jpeg Most of the paint is off. Next step? Can i use a wire wheel or ? to remove the rest? Thanks.
  20. squirrel
    Don't use a wire brush if you plan to polish it.
    Sent from my Trimline
  21. You can buy a brass bristle brush, less aggressive than a steel wire brush. What about polishing the brass, then spraying a clear coat over it?
  22. lothiandon1940, ol55 and loudbang like this.
  23. Amen, brother. I musta worn a hole through my belt buckle keeping it polished
  24. Blues4U
    Blues4U
    from So Cal
    I was wondering about clear coating the polished tank too.
    ol55 likes this.
  25. ol55
    ol55
    from Virginia
    Rain today so cleaned the paint stripper off with 000 or 0000 steel wool and some ajax sprinkled on. Exposed previous repair. Some of the excess solder came off, assume I can use heat to get any other spots.
    Just Gary likes this.
  26. PhilA
    PhilA
    1. Hydro Tech
    Brasso in it's current guise is good for an almost completely polished finish but not much else.
    Grab a fluffy cotton cloth and a pot of Mothers Mag & Alloy polish from the auto parts store and get it buffed up with that, then finish off with Brasso. The Mothers stuff is a bit more aggressive.
    Phil
    ol55 likes this.
  27. ol55
    ol55
    from Virginia
    Last photo. Used a foam pad, chrome polish then Brasso. Nowhere near the others but thought this turned out ok. 63272E4D-BFFF-4559-A70D-9AE6AEB92EC7.jpeg I will use it at least for mock up. Have a ‘glass front so I removed the (already cut) braces. As always thanks gor all the comments.
    lothiandon1940 and Just Gary like this.
  28. CGkidd
    CGkidd
    ol55 and seb fontana like this.
  29. seb fontana
    seb fontana
    from ct
    ""never ending job to keep it nice""
    Remember the above.
    lothiandon1940, PhilA and ol55 like this.
  30. Dan Moberg
    Dan Moberg
    I realize this is an old thread but I have also polished my radiator and wondering if anyone has used something like the VHT Flame Proof clear to protect the brass?
