Projects ‘34 Ford Sedan Eldonius Build
Discussion in 'Traditional Hot Rods' started by Eldonius, Apr 24, 2020.
Tags:
  1. dirty old man
    dirty old man
    Lots of difference between 32 & 34 rails. And a lot more vendors for the Deuces.
  2. Tomastudor
    Tomastudor
  3. Tom Bay from Arkansas City , Ks has frame rails, and all the Patch panels you need to fix your car,
    He makes all the 33-34 parts that Howels sell, Give him a call 620 441 7432
  4. Dirk35
    Dirk35
    You frame rails look really bad. Youll be ahead to go aftermarket frame or frame rails than to try to repair those.
    I don't know if JW Garage has 34 Rails, but I can see that Speedway has them for $774 plus shipping. IF Tom Bay from Arkansas City , Ks has them and I see someone else recommended them, try that route. I'm assuming that like most of the repo parts out there, there is only 1 or 2 companies that actually stamp the parts and they sell them to different vendors, which sell them as their own. So Id go whichever you find that look decent and can ship reasonably priced.
    https://www.speedwaymotors.com/Speedway-1933-34-Ford-Reproduction-Frame-Rails,22074.html
    chryslerfan55, loudbang and Eldonius like this.
  5. Eldonius
    Eldonius
    from Louisiana
    Ya, you are right. The outer rail isn’t even worth considering for repair. Where the running board gap was to the body created the perfect haven for a rust fest. Figure I’ll get the outer rails off, blast the X and cross-members, and assess the path forward. I think everything else is fine....but sometimes blasting creates unpleasant revelation. Thanks for following this build and providing perspective. I appreciate it.
  6. 343w
    343w
    Sent a PM for a frame on Parts Classified to you, good luck!
  7. Eldonius
    Eldonius
    from Louisiana
    Question. Actually two questions. First, why is there a key lock on the passenger door, but not on the driver door? Second, it appears that most rodders just removed or removed/filled the lights on the cowl. Is this indeed the case?
  8. Deuce Lover
    Deuce Lover
    Ford USA and LHD countries only did the door lock on the pass side as it was so people would exit on the safe side.The Ford's in RHD countries had the lock on the drivers side. The cowl lights as well as the right side tail light were included on the Deluxe models.Deluxe's also had an in dash ashtray and cigarette lighter.I have a '33 std tudor and no cowl lights,single horn,no ash tray or lighter.I did add the second sunvisor as it only came with a single.
  9. dumprat
    dumprat
    from b.c.
    There was only a lock on the passenger side. Most guys don't run cowl lights unless is an 80's style resto rod.
    chryslerfan55, 33Doll and loudbang like this.
  10. Eldonius
    Eldonius
    from Louisiana
    Thanks for the history! How was exiting on the passenger side considered unsafe? Wouldn’t this be the curb side and the driver side would be opening next to passing traffic? I’m missing something here. I’m guessing most hot rodders just left the door lock intact. Were deluxe model cowl lights filled, or were deluded just not common to be turned into hot rods?
  11. Eldonius
    Eldonius
    from Louisiana
    Was scratching my head about the one sided door lock...at first wondering if it wasn’t an original door or something . Thinking I’ll just fill the cowl light hole as it would have been on a standard and nothing about keeping it seems consistent with a hot rod as I look through reams of old pictures and learn the history. I wasn’t born until ‘74 so this all occurred well before my time, so I appreciate the history lessons from the HAMB
  12. goldmountain
    goldmountain
    Eldonius and loudbang like this.
  13. Deuce Lover
    Deuce Lover
    The pass side was the safe or curb side.So when all exited the door was then locked if so desired.On the left side you lift the handle up on the inside to lock the drivers door.Kind of a pain in today's world as I would always ask my wife to pull the handle up inside ,then I walk around to lock the door after she got out. Roadsters and Phaeton's do not have the door lock so they never locked. Since you were born in 1974,here is a pic of the '34 roadster I built in '74.I was 30 then.
  14. Eldonius
    Eldonius
    from Louisiana
    Wow! That’s a great looking car! Congratulations on making the cover...and thanks for teaching me as I’m just a young pup!
  15. Yes, that is correct.
  16. Eldonius
    Eldonius
    from Louisiana
    Got the fuel tank pulled. Got a pretty good dent in the bottom. I’m planning on an aftermarket stainless tank. Would there be any value in this tank for someone else do you think? Or, should I just scrap it? What about the rear shocks...would someone want them do you think? [​IMG][​IMG]
  17. 33Doll
    33Doll
    Hey! Wait a minute there Pal!...
    Oh. Yeah... mine was an 80’s Resto-Rod! Well... a modified original, in the 80’s! Although I’m gonna keep the cow light so I have front turn signals.
    Plus they look cool at night as Park lamps!
  18. dumprat
    dumprat
    from b.c.
    As long as you don't paint it two tone brown and brown you will probably be ok. Lol.
  19. dumprat
    dumprat
    from b.c.
    If that tank isn't rusted through it still has value. I have a very nice original but am running an aftermarket steel tank because I didn't want to cut up the old one.
    Eldonius likes this.
  20. Dirk35
    Dirk35
    I think you can get the aftermarket tanks that have a little deeper bottom and hold a couple of extra gallons of fuel. Ive ran out of gas a few times cause neither have a working fuel gauge.
    Both my 34 and my Model A (with 1932 tank on it) have Vintique tanks.
  21. 34Larry
    34Larry
    Yes that is the case.
    They were removed, holes filled on mine when I got it in '95 but Drake has great reproductions, I like them and wanted my 34 hi boy to be different. Rod and Custom's Brain B. said in his column one time, "Hi-boys NEVER should have cowl lights". I just love braking the rules and in addition to being my turn signals they look great IMO, and since I'm the only one who counts on that matter they look even greater. :cool:
  22. 33Doll
    33Doll
    Like this? I think ill do that, and put dual cowl lamps, each side just for
    Shits, and grins!
  23. dumprat
    dumprat
    from b.c.
    I just puked in my moth a bit! Lol
    33Doll and chryslerfan55 like this.
  24. 33Doll
    33Doll
    Bwwahhhaaaa!
  25. Eldonius
    Eldonius
    from Louisiana
    We’ve got the engine out now. Front crossmember is in bad shape around the motor mounts. Restorable I suppose, though I’m going to post a want ad here on the HAMB and see if someone has one for a reasonable price. Outer rails will be replaced. Inner rails will need some restoration in a few places, but I think can be saved.[​IMG][​IMG][​IMG][​IMG]
    kidcampbell71 likes this.
  26. dumprat
    dumprat
    from b.c.
    I have a really nice front crossmember but shipping might be expensive
  27. Eldonius
    Eldonius
    from Louisiana
    Ya, bummer. BC is a hecka long ways from here.
  28. 34 5W Paul
    34 5W Paul
    from Fresno CA
    A guy would figure that with the whole Covid shutdown and tons of free labor (how many kids?) Eldo would be making huge progress. I just hate to check in on a build thread and not see any progress. Hope all is well, post soon.
  29. clem
    clem
    Interesting, that Europe was like that, something I hadn’t noticed, as in New Zealand, always been right hand drive, the door locks are on the passenger (left) door. (Thought Argentina was the same).
  30. Eldonius
    Eldonius
    from Louisiana
    I know, right? Well...a couple of issues. First, it’s July in South Louisiana and absolutely stifling to be in the garage without A/C. Also progress pending with some potential work changes that may require relocation. So, right now looking to resume progress in October. Thanks for checking in though!
