Technical Best Model A Patch Panels?
Discussion in 'Traditional Hot Rods' started by Gigantor, May 11, 2020.
  1. Gigantor
    Gigantor
    A search didn't turn anything up - so I figured I'd ask y'all anyway.
    I need to patch or replace several panels on my 31 coupe. I know not all repop parts are created equal and I know that there can be a lot of variance in body lines depending on which plant your car came out of.
    BUT, are there companies that stand out above the rest for the fit and finish of their panels? I need to patch or recreate nearly all of the rear half of my quarter panels and wheel wells. I'd prefer not to have to buy an entire Brookville quarter panel either.
    Thanks in advance.
  2. Never2low
    Never2low
    The Cowl, quarters, wheel wells and panel below the trunk, that I bought for my '30 Coupe, came from Mac's and were pretty decent, from my untrained eye.
    I know the rear corners are really difficult, and most, if not all the repops are not worth purchasing.
    A side from that, I'm just posting to say I like Powdered Toast Man, too!
    Gigantor and stillrunners like this.
  3. gimpyshotrods
    gimpyshotrods
    I have yet to find any that don't require some degree of tweaking to get them to fit properly.
    It is not all the aftermarket's fault, though. Over the 89-92 years since the originals have seen some serious history.
    Given the conditions of what passed for roads back then, and the flexibility of the chassis, the bodywork is often quite tweaked. Add in rust, previous "repairs", and all of the other ravages of time, and no two Model As likely still have matching dimensions, curves, etc., to each other, let alone factory spec.
    Never mind wear in stamping dies, over a model run.
    Try Mac's. They generally are close.
    jimgoetz, 5window, Gigantor and 3 others like this.
  4. badshifter
    badshifter
    The best ones are the ones you make. When I did my Model A a few years back I ordered from, Macs, Howells, Synders... and returned them all. Terrible fit, and most of them were 20 gauge and junk. They are simple cars, and with a bit of practice, hammer, dolly and a bead roller, you can make just about any panel your car needs. Add an English wheel, even a HF cheapie and a shrinker/stretcher and you can build the whole car. 18 gauge cold rolled sheet metal, and a little of your time.
  5. 31Apickup
    31Apickup
    I used the ones from Snyder’s, the profile on the cowl ones matched the original bead. The quarter patches were pretty good, but I had to devise a way to bend the bottom flange up correctly as the come with a 90 degree flange but need to fold straight up. I have photos in my thread 31apickup builds a coupe.
    Gigantor likes this.
  6. chev34ute
    chev34ute
    I agree with bad shifter. I have some repro panels, including a 30 Coupe seat frame, curved trunk panel and angled floor pan. They look ok but are too tinny to be used as anything but patterns. Likewise I borrowed a wheel well from a local rodder to make a pattern for my own and was surprised how thin it was. If the patch panels are anything like these, you are better off investing in some metal shaping equipment and doing your own.
    This is a 28 Roadster Quarter Panel I am repairing. It was missing the lower ten inches at the b pillar, the wheel well and the corner that sits over the rear cross member.
    E81BD57D-C527-47F4-A8D7-4623643CE894.jpeg E8FEA2D0-05E2-48EC-BE18-FCB296867DDB.jpeg
  7. woodiewagon46
    woodiewagon46
    from New York
    Because of the low volume of people restoring Model A's now a days ( and many V-8 Fords) it's getting harder and harder to find good sheetmetal parts. I just replaced the both quarters behind the doors on a 1929 Coupe. The panels I tried from three different vendors were just junk. All were about 1/4" oversized and the one I finally used, I needed to modify. The panel below the trunk lid from the factory is 9 and 1/4" tall. All the reproductions varied between 9 and 1/2" and 9 and 5/8". I finally just sheared 1/4" off and TIG welded the top seam. Every replacement sheet metal part will need some modification to make it fit correctly.
    Gigantor and anthony myrick like this.
  8. In the defense of the patch panel makers, the cars they are building parts for are inconsistent. I have made patterns and found differences from side to side and from car to car.
    Add that to human error in making the patch panels.
    Most use 20-22 gauge for cost savings and ease of bending.
    jimgoetz and Gigantor like this.
  9. 31Apickup
    31Apickup
    I bought a pair of the wheel well panels, the beads were not pressed as deeply as the originals. I only used the lower part of them and made a die up to press the beads deeper on those portions. I also bought an under deck lid rear panel from Brookville, the height was correct but the vertical curve of the panel was not right, I had to notch the flange and made up a form to get them right then rewelded the flange, then it matched the curve of the body and looks right. This same panel does not come with the mounting holes nor the reinforcing strips. Also shown in my build thread embattled I did to these.
  10. I bought Mac's lower 1/4s for my '30 and had to use the shrinker/stretcher to get them to "fit". I'll just say I am not happy with 'em...
  11. flatford39
    flatford39
    Just don't buy directly from Howells. They sell to all the vendors. Life will be much easier purchasing them from your favorite vendor.
  12. sloppy jalopies
    sloppy jalopies
    Tough spot,
    but if you pay the top dollar for beltline down patches, you will get compound curved skins,
    they fit well, [I cut the 90* strips off the ends, weld the outer skin, inner skin and the fold over strip all at once] then sand flat with a 3" belt sander...
    but the lower beads are just a curved radius where some are a tight 90*, a flat and another tight 90*..
    so I bought [4] total, one each door, the others split in two and used for cowl and bottom of the quarters... this was more money, but the tall patches let me remove a lot of pitting along the bottom 1/3 of the body …
    pix of a '30 coupe, note the hight of the patches... all the bottom beads matched... scoop__ last day here 004.JPG scoop__ last day here 006.JPG
    41rodderz likes this.
  13. Dino 64
    Dino 64
    from Virginia
    Try Brattons, the corners from Howell’s are the best ones, though they all need tweaking.
    Ben38 likes this.
  14. Where to get the best sheetmetal is the question. I just ordered new subrails from Bert's Model A Center in Colorado as well as lower patch panels for the cowl, doors, inner door bottoms, rear quarters and bottom corners for my '30 Coupe. I asked who they bought from and was told the subrails were from Brookville, the cowl patch panels came from Stipe Machine in Wisconsin, the lower door patch's from Howells, the rear quarters and rear corners as well as inner door bottoms came from Ahooga in Ohio. Pay your money and take your chances. I have been happy with everything else that came from Bert's over the years so I'm anxious to see what Brown drops off.
  15. Dino 64
    Dino 64
    from Virginia
    I ended up ordering from a few different distributors trying in vain to get better quality. Only a couple of places actually making them, Brookville doesn’t make their’s either. I have a few panels I never used, PM me, they’re yours, just pay shipping ;)
    Gigantor and sloppy jalopies like this.
  16. scrap metal 48
    scrap metal 48
    Brookville makes most of the patch panels and supplies most of the other vendors...
  17. Hotrodmyk
    Hotrodmyk
    1. Northwest HAMBers
    Check out @IronTrap and his YouTube channel. Matt is working on a roadster and had to replace several panels. Recently I watched him replacing a rear corner. It took far more than a tweak to make it right. I think this is pretty typical with with replacement panels today.
  18. Rehpotsirhcj
    Rehpotsirhcj
    I believe I saw him in an Eastwood demo too, bead rolling a scratch-made patch. Seemed to have good success with some standard dies.
  19. marshall Metal Shaping.com
    Sorry guys....a little self promotion....lol
    5window likes this.
  20. 5window
    5window
    Amen to that. But, how will we start another Howell's thread?
  21. IronTrap
    IronTrap
    NONE of the patch panels fit/match OE. If you're going to buy patch panels try and get them all from the same vendor so the bottom beads match. I've found they vary in width/shape from a lot of vendors. I made a die to bead roll a match to the 30-31 body line for my roadster as the factory bead has "shape" to it and in't just flat like the patch panels you get. Also the beads usually don't match up height wise. It's a crap shoot and really a matter of how much of a perfectionist you are.
    The rear corner I just put on a roadster in a video I didn't take as much time as needed to make it perfect as the owner of the vehicle is pushing to get it back and just wants a driver. The corner needed some shape/crown in between the beads put in it with a planishing hammer or sandbag and hammer and dolly. Once you know how to make it "right" it's hard to leave the patch panels alone and just use them "as-is".
    One thing I'll mention is that most of the lower patch panels you buy are just made with a break, bead roller and a shrinker stretcher like any normal hobbyist would have.. just takes a good pattern to go off of to make them yourself. obviously more complex stuff like dash rails and some other stuff is stamped but even those are welded on and sanded to finish off.. so a lot of this you can do yourself if you want to put the time in. Just my 2.5 cents.
  22. 31Apickup
    31Apickup
    The Lower beads are not uniform shape originally from each area of the car. The cowl bead is more squared off compared to the quarter panel beads. I had quite a bit of the original beads left on mine and partially spliced the quarter panel ones.
  23. sloppy jalopies
    sloppy jalopies
    I patched a fender with a piece from another...
    the thickness [hight] of the outer flat bead was different...
    I may leave it or weld the patch on end and grind and sand to fit...
    05snopro440 and OFT like this.
  24. -Brent-
    -Brent-
    We made the lower patches to match the factory bead. The rear piece below the decklid came from Mac's years back. The rear subrail connector came from Snyder's, as well as the sub rails and such. I've ordered from Bratton's and Bert's too. THE BEST customer service, not that you asked (but it could help you), has been from Snyder's.
    One thing I like when ordering from Snyder's, Bratton's and Bert's is that they'll sell you what fits best and if you're not sure, just ask. But... like it was mentioned, everything needs to be tweaked. That's metal work...
  25. sloppy jalopies
    sloppy jalopies
    Snyder's has been really good to me... they took a part out into the storage building and compared the beadwork to what they sold me...
    they were sorry they didn't believe me, gave me free shipping on that order and said they would look for a new vendor...
    I have gotten parts from them in less than 24 hrs... and not cause I asked for quick ship...
    just some model A parts... probably lower patch panels...
    Gigantor and -Brent- like this.
  26. bubba55
    bubba55
    X2 with Snyders - they been good to me 2
  27. Gigantor
    Gigantor
    I just stumbled across your channel a couple of days ago and you're my new best friend. Words can't express how helpful and empowering those videos are. So, thank you.
    Sent from my SM-G973U using The H.A.M.B. mobile app
    IronTrap likes this.
