Technical Threaded fuel Filter
Discussion in 'The Hokey Ass Message Board' started by Voh, May 4, 2020.
  1. Voh
    Voh
    Is there a common threaded fuel filter similar to this with 9/16 IF fittings or are they all metric? Loosk like the common GM ones are all metric.
  2. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    I ended up using one with barbs and pushed the rubber hose on with a clamp. Needed some flex room anyways
  3. egads
    egads
    Be careful,That's not an inverted flare fitting on that filter.
  4. FOURTYDLX
    FOURTYDLX
    I think all metric
  5. Voh
    Voh
    I saw that. It looks like it needs an O-ring to make it work.
  6. FOURTYDLX
    FOURTYDLX
    It’s a GM filter n metro, check with any after market F I dealer, Irun on my cars
  7. moparboy440
    moparboy440
    from Finland
  8. egads
    egads
    @Voh This is the style that goes in the filter in your post. These are GM fuel injection fitting's. You can make them with the correct flaring tool.[​IMG]
    ted kovacs likes this.
  9. FOURTYDLX
    FOURTYDLX
    Perfect
  10. OLDSMAN
    OLDSMAN
    The vehicles it fits are new enough so it has to be metric
  11. Gus68
    Gus68
    from Minnesota
    Yes, THAT one is metric. But he wants one with standard inverted flare. I have been looking for one myself.
  13. How about repop for the earlier corvettes.
    uncle buck and Just Gary like this.
  14. uncle buck and lothiandon1940 like this.
  15. Voh
    Voh
    thank you
  16. Beanscoot
    Beanscoot
    egads likes this.
