Hot Rods Pete and Jakes front rotors
Discussion in 'The Hokey Ass Message Board' started by Binkman, May 2, 2020.
  1. Binkman
    Binkman
    Does anyone know what vehicle Pete and Jakes Ford bolt pattern rotors are from ?
    I need one in a hurry and it would be nice to know what they were off of.
    Thank you for any input. 5 x 4.5 bolt pattern, 11 inch rotor.
  2. Mr48chev
    It helps a lot if you give us a part number and application. That is about as vague a question as one can come up with.
  3. Binkman
    Binkman
    If I had the part number or application I could cross it over myself. This is one of their complete front end kits. Someone from out of town needs to get back on the road and I was hoping they just used an off the shelf part for their front end kits. I know the calipers are GM intermediate 78-85.
  4. Fordors
    Fordors
    Is a one piece hub and rotor or does the rotor bolt to the hub?
  5. Binkman
    Binkman
    This a one piece rotor. It looks like it might be a custom rotor like Heidt's had for their Mustang II setup.
  6. Fordors
    Fordors
    Assuming you have the rotor off is there an adapter pressed on the spindle for a different inner wheel bearing? If so you might try matching the rotor up to a ‘70’s Dodge Aspen.
  7. jhexide
    jhexide
    id call Pete and Jakes
  8. jhexide
    jhexide
    or look on their website...
  9. Tim
    Tim
    from KCMO
    Call them. They are there sitting by the phone for exactly this reason
  10. Tim
    Tim
    from KCMO
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    "Yes I'd like to buy one of your rotors but from someone else". That'll fly :rolleyes:
  12. lostone
    lostone
    from kansas
    And this is the exact reason I use as much stock/oem parts as possible on customers cars and my own builds.
    Sure the caliper doesn't say heidt's on it or any others name but neither does the cost or its availability.
    I don't do names on my builds it I don't have too.. Don't do designer shirts or pants either !! Lol
  13. lake_harley
    lake_harley
    You didn't mention if this is a relatively recent disc brake setup, or if it's older. The reason I question that is years ago it seemed that some used Plymouth Volare or maybe Volvo hubs/rotors. Sorry I don't have any specifics and it might be that my memory is failing me all together.
    Lynn
  14. Binkman
    Binkman
    He says the build is about 5 years old. I remember using Volvo 122s rotors back in the 70's, and Volare rotors in the 90's. This could be a Volare rotor that they sell. Thank you for the tip.
  15. hemihotrod66
    hemihotrod66
    I have the same setup on my 34 Ford and their Mopar Rotors off of Diplomats in the 80's...Lot of Mopars used this rotor from 1973 to 85
  16. 40Vert
    40Vert
    Here is the tech sheet for the basic brake kit which is on their website under tech:
    Tim and X38 like this.
  17. Binkman
    Binkman
    Thanks everyone. NAPA had one and he is back on the road to Oregon.
    Stay safe.
  18. Fordors
    Fordors
    See, that wasn’t so hard.
    uncle buck and lake_harley like this.
