Customs Wagon hunt may be OVER!!! 1952 DeSoto wagon is HOME!
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Jan 11, 2020.
  1. flynbrian48
    flynbrian48
    Haha! I like both versions, and not ‘graining it will be much less work! Having it finished to her liking will make things much easier for me when I bring home a roadster project to put that 276 Hemi in anyway.
  2. I understand completely on all accounts :D
    ... but leave a good copy of that picture of the woodie out where Mrs. Flynbrian can see it all the time and "get accustomed to the possibility of the idea";):D
    flynbrian48 likes this.
  3. Bandit Billy
    Bandit Billy
    Hey FB (not face book) I have a buddy that bought a nice little speed boat with rounded transom sides that he had wrapped in a faux mahogany, it looks like a high end wood boat for next to nil. Just sayin. Wrap the wagon tastefully and then get a matching boat!
  4. flynbrian48
    flynbrian48
    Oh, I'm definitely getting another boat to use while the Chris Craft gets a new bottom! I'd like a Malibu Skier or a MasterCraft, didn't give much thought to woodgrain wrap, I wonder how that'd hold up in the water?
  5. Bandit Billy
    Bandit Billy
    ^^^^If you clear coat over the top and stay off the sand bars, it ought too hold up.
  6. flynbrian48
    flynbrian48
    The Hemi went back in the DeSoto today with new mounts and early Ford flathead style insulators. Tomorrow, on the transmission crossmember. The new modern transmission is a foot shorter than the "GyroMatic" and Fluid Drive, I have to make a new crossmember, even though the trans is shorter, the original mount is pretty much in the middle, and the new one is at the back end. I'll have to have a new, much longer driveshaft made. I wonder if it should be two piece with a carrier bearing? 88433644_10222517362145444_490265010690326528_o.jpg 89194551_10222517361425426_7914413245102817280_o.jpg
    kiwijeff, Thor1, rockable and 7 others like this.
  7. Johnboy34
    Johnboy34
    from Seattle,Wa
    How long is too long, it matters the material, diameter, length, and critical speed (rpm) of shaft. New gm trucks are pretty long, call a driveshaft shop and have a chat.
    Sent from my SM-G973U using The H.A.M.B. mobile app
  8. flynbrian48
    flynbrian48
    Fender skirts? I think it's a yes. And, I like the stance with just 2" blocks in back. The front will come down a little with the sheet metal on... 90219297_10222655337994754_6809378383873441792_n.jpg
  9. Bandit Billy
    Bandit Billy
    I like short skirts, go for it. I know you already got ass ended in the tin indian (feather, not dots) but that rear bumper is due for a tuck buddy.
    jim snow and chryslerfan55 like this.
  10. I LIKE skirts.:p. On cars, too. Looks good to me.
    Ben
    scrap metal 48 likes this.
  11. flynbrian48
    flynbrian48
    I know, I hate the bumpers on it. A buddy of mine offered me a front bumper from a '55 Chrysler, which I think will work great, I need to come up with a rear bumper. My first thought was '49-'50 Chevy/Pontiac. Slim, tidy, and cheap.
  12. plym_46
    plym_46
    from central NY
    53 Plymouth suburban rear bumper might work.
    Fordor Ron and chryslerfan55 like this.
  13. flynbrian48
    flynbrian48
    Things I’ve been doing whilst sequestered: Got the steering done in the wagon. A couple of U-joints, some double D 3/4” shaft and a big Heim joint turned the trick. Bought a nice tool chest. Finally. Fixed my pellet stove so it's warm again. Fixed a rusted out fender on my cousin’s John Deere Model R. It’s a ‘48, so it IS traditional...
    Ford52PU, kiwijeff, v8flat44 and 9 others like this.
  14. flynbrian48
    flynbrian48
    Here's the '59 Imperial grill I'm going to use instead of the roached original grill teeth in the wagon. I never liked these Mercury grills... There's my extra dash too. I'm going to use some of the stuff on it, the trim, radio delete, and speaker grill cover. 91342295_10222801057797658_5542884719756050432_n.jpg 91301149_10222801058157667_4642239264719896576_n.jpg
  15. I love where this build is going! In regards to your Explorer 8.8 rear: I don't know if you need the pumpkin centered in your tunnel but if you do I've seen those you-tube videos where they grab an extra passenger (short)side axle at the junkyard. The long side axle tube is cut down to passenger side length, re-welded & short axle installed.
  16. flynbrian48
    flynbrian48
    I checked that out before I bought the thing, there's plenty of room, the driveshaft tunnel isn't an issue, and it's almost too narrow as is, so I'm running it. I had one problem initially, in that I thought it was an '03, and bought rotors, calipers, E-brake pads, and lines for an '03, and nothing was right. The rotors they gave me were vented (I didn't open the boxes to check), and turned out to be '03 front parts packed wrong. I got rear ones, which had the disk about 5/8" outward to far, and on investigating, found this axle is really an '01. Since I'm not going out and about, I ordered the correct parts, and will return the wrong ones when things get back to whatever the new normal is going to be...
    Meanwhile, I got the gas tank in today, and started making lines, but I misplaced the new in line filter from Tanks Inc., during my shop clean-up. I ordered a new one which should be here tomorrow, so I can get the lines finished up, and I'm one step closer to having the Hemi make smoke and noise.
    kiwijeff, Thor1, Nostrebor and 5 others like this.
  17. bgthegreat
    bgthegreat
    Do you have the tailgate hinges?
  18. flynbrian48
    flynbrian48
    ‘59 Imperial grill. How’s that grab ya?
    brEad, Hnstray, kiwijeff and 16 others like this.
  19. Dick Stevens
    Dick Stevens
  20. Bandit Billy
    Bandit Billy
    I'm digging what yer laying down FB
    Thor1 and loudbang like this.
  21. jetnow1
    jetnow1
    from CT
    1. A-D Truckers
    That grill works!
  22. flynbrian48
    flynbrian48
    Certainly better than this... 81459239_575128066493612_7636733473293598720_n.jpg
  23. Nostrebor
    Nostrebor
    More better!
  24. It works!... are you going to "lighten up" that front bumper as well?
  25. flynbrian48
    flynbrian48
    Lighten up, as in, I'm not going to use it. ;) A buddy of mine from Windsor has a '55 Dodge (I think) front that'll look much more better.
  26. flynbrian48
    flynbrian48
    You were SO right about that...;)
  27. flynbrian48
    flynbrian48
    93627142_10223071156909967_1769407194580647936_n.jpg 94133178_10223071157309977_1003216309221064704_n.jpg I'm painting stuff for the wagon. Here's one of inner fenders in "Kirker" single stage urethane, "Garnet Pearl". I bought 6 quarts of that, and 3 quarts of white for the roof, which will get "Arctic Frost" pearl over. Should be pretty. The front wheels looked about an inch too far forward in the wheel openings with the suspension dropped, so I moved the wheel opening forward. An inch in front, 2 1/2" at the rear, so it looks more balanced, and matches the way the rear wheels fit it the openings. Onward.
    hrm2k, dwollam, David Gersic and 17 others like this.
  28. flynbrian48
    flynbrian48
    My first attempt at an exhaust system. Well, I did straight pipes under the '34, but it was super-simple. This is stainless 2 1/4" from Summit, I'm waiting for the stainless mufflers to arrive. Waiting too on the aluminum radiator, turns out '47 Chevy trucks are the same dimensions, and have outlets in the right size and location, whereas the original does not... 94270787_10223149701993545_3764539809901576192_n.jpg 94376314_10223149702193550_9050885836714803200_n.jpg 94474115_10223149702753564_4515316598801694720_n.jpg
  29. Johnboy34
    Johnboy34
    from Seattle,Wa
    loudbang, j hansen and chryslerfan55 like this.
