Features Feature your steering wheel
Discussion in 'Traditional Hot Rods' started by Doug G, Sep 17, 2019.
  1. PINEAPPLE
    PINEAPPLE
    Denver needs that wildcat on the loose this summer my friend.
    OG lil E and loudbang like this.
  2. Besty34
    Besty34
    Speed~On, waxhead, hfh and 1 other person like this.
  3. Gary Addcox
    Gary Addcox
    Don't have any shots of it so I guess it never happened, but my Deuce highboy roadster has a '46 Ford wheel like Walker Morrison's red roadster has. Not ashamed a bit for copying ole Walker !
  4. Sean Smith
    Sean Smith
    29A99B87-4C1B-47B8-B257-B14ABA59BD86.jpeg 39 banjo in my 3 window
    LowKat, Blues4U, Speed~On and 4 others like this.
  5. BirchRidge
    BirchRidge
    from sweden
    Fordson tractor in my model a
    waxhead and Speed~On like this.
  7. pnevells
    pnevells
    loudbang, chevy57dude and mad mikey like this.
    loudbang and chevy57dude like this.
  9. BJR
    BJR
    I just gotta say this was a great idea for a thread. There are some very cool steering wheels out there.
    loudbang and mad mikey like this.
  10. HarryT
    HarryT
  11. IMG_2095.JPG 15 inch Moon in my 47
    chevy57dude, Blues4U and loudbang like this.
  12. continentaljohn
    continentaljohn
  13. Rickybop
    Rickybop
    Yes... great thread.
    Not only eye candy, either.
    I can't think of any place else where we can flip through so many examples of vintage steering wheels that we might want to choose 'n' use on our own cars. Thanks, guys.
    That Zephyr wheel is a beauty.
    They're all cool.
    Sent from my VS835 using The H.A.M.B. mobile app
    loudbang, BJR and continentaljohn like this.
  14. Rickybop
    Rickybop
    I had a couple Buicks with huge steering wheels. Loved it. Like steering a bus or something LOL.
  15. JOHN H EDGE
    JOHN H EDGE
    ECBCE627-61E7-4BA7-9666-C53BBBCC2802.jpeg 4E24C6EA-2CF0-4D90-9F73-A81B0986D270.jpeg AED4F977-0D5E-4942-BA7B-A885527F74F1.jpeg 1950 Plymouth deluxe wheel on my 52 Plymouth suburban
    1957 Chevrolet passenger wheel on my 57 Chevy truck
    Barry Lobeck wheel on my 1932 ford coupe
  16. Wanted a stock looking steering column for my retro '53 Chevy King Cab pickup but wanted power steering, tilt wheel, 2004R shifter. Adapted the stock '53 wheel and 3-on-the-tree shift arm to the 80s GM tilt column. Came out pretty nice.
    The '53 wheel has a smaller column so I started buy sawing off the Bakelite on the back of the wheel. Luckily the shaft splines on the old wheel and modern column are the same. I had to grind down the steel a little so it would seat in the column. drilled the horn button thru-hole to fit the column.
    Now to adapt the shapes, I cut a sheet metal circle the size of the column. This was epoxied to the wheel and Bondo was used to complete the transition. P8010077 - Copy.JPG P8010078 - Copy.JPG P8010079 - Copy.JPG P8020080 - Copy.JPG P8020090 - Copy.JPG
    The shift arm was easy to do also. I just cut and ground the '80s shift arm 'til it slid loosely into the '53 shift arm tube. I then ground the boss on the column so it fit in the sheet metal end of the '53 arm and drilled all 3 components to fit the long '53 pivot rivet.
    FYI, here is how I adapted the column to the pickup structure. I used both the '53 under-dash column bracket and the late model GM column bracket. This allowed me to use modern power brakes too.
    I made a fiberglass column-to-dash shroud from fiberglass.
    chevy57dude, waxhead, Blues4U and 4 others like this.
  17. Inked Monkey
    Inked Monkey
    Here's a Sea King boat wheel in my RPU and a shoebox wheel that I just got done restoring during the covid19 lock down.
    Ned Ludd, waxhead, Blues4U and 2 others like this.
  18. Here's one shot for you Mercman. Don't want to take the thread off course. I really don't have many pictures of the car. Funny how that works..........E
    That would be nice! It's been sitting so long it's almost like I don't even have it anymore. I have a small group of people that are on me about getting it back on the road all the time.
    Always a pleasure to spend time behind the wheel in the awesome interior! ;) E
  19. PINEAPPLE
    PINEAPPLE
    I would love to go for a ride in that awesome interior again someday.. good times.
  20. That can be arranged pal. I have to get on the ball. Takes moola though which is lean these days (lol)! E
  21. vtx1800
    vtx1800
    Here are a few more wheels -- the first is about a 1940 Pontiac wheel (in a 38 Chevy), the second is the stock wheel in the chopped 49 Ford that I had, the third is a Studebaker Hawk wheel and the last is a 1936 Studebaker wheel. The Hawk wheel and dash are now in my 53 Studebaker coupe (after being cleaned, repaired and repainted). IMG_0217.JPG IMG_0107.JPG IMG_1619.JPG IMG_0527.JPG
    loudbang, waxhead and Blues4U like this.
  22. Chalkie
    Chalkie
    from England
    I'll be running a Red Model a wheel.. well this one comes with added TB.
  23. Blues4U
    Blues4U
    from So Cal
  24. 4speed411
    4speed411
  25. Everybody uses a 59 Impala wheel in their TriFive Chevy. I wanted a little different one so I went with a 61 Impala wheel. Scuze the bad photo please, I suck at photos. Bel Air DASH.JPG
  26. oldwood
    oldwood
    from arkansas
    I'm going to use the '60 Plymouth Aero wheel but would sell the '61 Wheel. The '61 wheel needs restoration.
      79.4 KB
      141 KB
  27. -Brent-
    -Brent-
    I have a few options. Here are two. Not close enough, yet, to make a decision.
    chevy57dude and loudbang like this.
  28. sloppy jalopies
    sloppy jalopies
    No more pix till I pull the coupe out of winter storage...
    down sized, but tried to keep the thin rim...
    I melted the rubber off a sporty '80s ford wheel, it was an x bent into a circle, I carefully cut down the spokes on a '37 banjo wheel, FORCED them into the grooves in the x...
    welded them there, wrapped the spoke to rim sections with electrical tape, then wrapped the rim with duct tape [gets sticky on both sides with a little time], finally a leatherette steering wheel wrap...
    sawed then sanded the under side of the '37 wheel's hub to increase the diameter so that it smoothly flowed from the wheel's size to the speedway quick release hub's diameter...
    I had the boys in the tool room turn down a '35 horn button/ light switch to the banjo's size...
    the horn wire tube was only about 4" long...
    the 2 little knubs were the '35s light switch
    been using it for about 20 years... now on its second hotrod...
