Projects A new '32 project of my own.
Discussion in 'The Hokey Ass Message Board' started by hot rod pro, May 3, 2015.
  1. Andy K
    Andy K
    Man that’s such a great color. I considered doing my 27 roadster’s repaint in a color pretty close to it, Grigio Telesto which is from Lamborghini but decided on going with a garnet
  2. Too cool. Sounds fantastic!
    Nice to have something new added to the Bruce’s Rod Shop stable.
  3. 340HilbornDuster
    340HilbornDuster
    Flawless work on the car!...Nice Stance!!...You must be a Master Plumber...Above and Beyond!!!...Wowsers!
    What kind connectors are those?...
    32SEDAN, 26hotrod, alfin32 and 2 others like this.
  4. loudbang
    Good work paying off. :)
  5. rod1
    rod1
    Sounds so Good,I was looking at the rolling chassis,thinking I'd have a hard time covering up all that beauty.Then I saw the Video.All I could think of was Burnouts!Once again ,Great Job!
  6. hot rod pro
    hot rod pro
    from spring tx.
    It is ones I make.
    loudbang and kidcampbell71 like this.
  7. hot rod pro
    hot rod pro
    from spring tx.
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Made some progress on the headlights, grill and hood.
    32SEDAN, Tjompen, 26hotrod and 10 others like this.
  8. DDDenny
    Getting closer, some nice machine work Danny, are you doing the wire bezels on a CNC?
    The ends would look good black anodized also, I like the black braided wire covers too.
    26hotrod likes this.
  9. Tell me about the single finger hood latches. Thanks.
    Phil
  10. alchemy
    alchemy
    Single finger hood latches were an early 32 production item. Most original Ford ones had a flat side facing the hood. There are now repros available, but they don't have a flat side.
    26hotrod and loudbang like this.
  11. Tim
    Tim
    from KCMO
    Looks fantastic
  12. hot rod pro
    hot rod pro
    from spring tx.
    Yes, I do them on my CNC lathe.
  13. hot rod pro
    hot rod pro
    from spring tx.
    There were flat and round sided single pulls. The repos are round and have a non ‘32 base on them.
  14. hot rod pro
    hot rod pro
    from spring tx.
    UPDATE:
    Rear window is in. Interior support structure is in. Roll bar/seat belt mount is in. Checking things off the list. #brucesrodshop
  15. hot rod pro
    hot rod pro
    from spring tx.
    UPDATE:
    Doors on and latching. The light at the end of the tunnel is so beautiful! #brucesrodshop
  16. loudbang
    Now THAT is a HOT ROD. Fantastic job well done.
  17. deucendude
    deucendude
    from norcal
    This is a treat to see now. I have been looking occasionally. Hope to see it on the west coast this year.
    brady1929 and loudbang like this.
  18. hot rod pro
    hot rod pro
    from spring tx.
    UPDATE:
    A few small details, and interior, and you can call this thing DONE!
    I would like to personally thank my family and friends who have made this car even possible. Thank you to all who have made positive and negative comments during the build. I take every one as inspiration to do better. #brucesrodshop #the32mafia
    bowie, 26hotrod, 32SEDAN and 13 others like this.
  19. DDDenny
    From all angles this car is perfect!
    Danny, after some time on the road could you post your thoughts on the Coker Firestones.
    26hotrod and Just Gary like this.
  20. hot rod pro
    hot rod pro
    from spring tx.
    Based on dad’s roadster. They work great after a few warm up miles. Only drawback is the tire life. Could be better.
    26hotrod, Just Gary and loudbang like this.
  21. DDDenny
    Thanks
  22. 54reno
    54reno
    Awesome Hot Rod!!!
  23. 26hotrod
    26hotrod
    from landis n c
    Is the upholstery going in or are you taking a well deserved break? Thanks for all the posts so far. The photos have been great...……...
  24. hot rod pro
    hot rod pro
    from spring tx.
    top insert is in. I have an appointment for interior at the end of April.
  25. hot rod pro
    hot rod pro
    from spring tx.
    Car is finished for a month or so. It goes to Cato’s at the end of April for interior.
  26. loudbang
    One of, if not THE BEST, most detailed builds on the HAMB. :)
    1947knuck, Gotgas, bowie and 4 others like this.
  27. Your skills are amazing. If only y'all were closer to Arkansas. I'm betting you could even improve on perfection, given the chance!
    Sent from my Pixel 3a XL using The H.A.M.B. mobile app
    loudbang and 26hotrod like this.
  28. brady1929
    brady1929
    Where is your top insert from? Is it a kit? Love your 32.
  29. hot rod pro
    hot rod pro
    from spring tx.
    The tack strip is from United pacific, the material and rubber insert are from all ford parts.
