Technical 1934 ford running board mounting
Discussion in 'The Hokey Ass Message Board' started by Dodgejodge, Mar 8, 2020.
  1. Does anyone have any pictures of how the '34 pick up running boards are hooked up? I'm working with a '34 5w coupe on a '34 pick up frame. 20200308_165402.jpg
  2. Or what the difference is between mounting truck running boards and coupe running boards in '34 was...
  3. '34 car boards bolt to the side of the frame and have two small braces on each side that bolt to the bottom of the frame. If the truck frame lacks the correct holes (can't see them very well in your picture); maybe fit the fenders to locate the boards and mark and drill holes as needed. I'll see if I can get a picture tomorrow.
  4. Pete Eastwood
    Pete Eastwood
    from california
    Truck boards bolt to the bottom of the frame.
    Car boards bolt to the side & bottom of the frame .
    Lots of different holes between the car frame & the truck frame .
  5. Weedburner 40
    Weedburner 40
    Pickup frames lack the running board holes. You can mount the rear fenders and bolt the running boards to them. Then clamp them to the frame, up against the bottom of the body and drill the necessary holes.
