H-Series 226 Flathead, all stock running gear. Removed a few leaves in the front and rear and have 2" lowering shackles installed. I have most of the side trim, window trim front and rear. There is new window glass for the vent, door and side windows. I have the trim for around the front window and the rear window, just missing a cover for the rear window. The brakes need some work. I put a Speedway disc kit on the front, the one that uses the F150 rotors to keep the 5X5.5" bolt pattern. I have a Mustang dual master cylinder, but it still needs to be installed. There are new slave cylinders in the rear. The emergency brake is not hooked up. I have newer gauges installed. They all work except my fuel gauge has been acting up. It has an aftermarket Motorola radio (aftermarket for 1941). I also bought a similar radio that looks better, but is missing the guts. It has most of the trim for the dash, missing the ashtray. I also have the metal dash trim, just needs to be chromed or painted. The front seat is missing the bottom seat spring. The previous owner did a hack job of making a wood base and memory foam for the seat. It works though. No headliner, but I do have the bows. I am asking $6,500. Car is located in Yorba Linda, CA 92807. Local pickup, cash only.
