Projects Southeast Gasser 50 chevy wheel stander project
Discussion in 'The Hokey Ass Message Board' started by Quain Stott, Feb 12, 2020.
  1. Quain Stott
    Quain Stott
    We put the bed on to check a few things so I left this for the last pic tonight. Hope y'all are enjoying this fun build as much as we are. IMG_0798.jpg
  2. You bet we do! It's nice to see how you plan forward at the early stages and avoid unnecessary hassle later on. Professional approach all around.
    mad mikey, Thor1 and loudbang like this.
  3. Thanks for taking the time to post the build pics. We all can learn something from your pics and descriptions why you did it a specific way.
    Thor1, mad mikey, raven and 2 others like this.
  4. glrbird
    glrbird
    Is that going to be a early bird gasser? that would be very cool!
  5. AmishMike
    AmishMike
    Need a twin truck to run gasser class
  6. Quain Stott
    Quain Stott
    LOL I have been doing it a long time (since 1975). I think I have made every mistake there was to make over the years. That's what caused me to learn a few hours of planning is better than doing it twice or screwing up the job by adding unnecessary bars or brackets.
  7. Quain Stott
    Quain Stott
    What's an early bird gasser.
    Thor1, chryslerfan55 and loudbang like this.
  8. 41rodderz
    41rodderz
    from Oregon
    I for one appreciate your sharing the build. I love me some tech with explaining the why.:) Thanks for all that Ryan (here) and you do to keep the oldies alive . :cool:
    catdad49, Thor1 and loudbang like this.
  9. glrbird
    glrbird
    I was referring to the
    i was referring to the 1955 thunderbird in the background. Is it steel or glass reproduction ?
    Thor1, loudbang and chryslerfan55 like this.
  10. Quain Stott
    Quain Stott
    It's original steel, we are building it for SEGA B/Gas. I'm going to try and find time to do a build thread on it also.
    collector, Thor1, mad mikey and 3 others like this.
  11. glrbird
    glrbird
    Thanks, I’ll keep an eye out for it.
  12. AHotRod
    AHotRod
    I Love your old machines Quain, they are quality beyond their years.
    Glenn
  13. Johnboy34
    Johnboy34
    from Seattle,Wa
    One of the best threads going right now,
    Thanks for taking the time..
    Sent from my SM-G973U using The H.A.M.B. mobile app
    Thor1, mad mikey, Quain Stott and 3 others like this.
  14. bchctybob
    bchctybob
    I’ll add my voice to those saying thanks for bringing us along on this build. It’s great to see your approach to race car construction. Lots to admire and lots of good lessons. Thanks.
  15. enloe
    enloe
    from east , tn.
    Looking forward to seeing this run this year.
  16. Quain Stott
    Quain Stott
    Most every piece of equipment in my shop is at least 25 years old even my welder. Most of my machine equipment is over 70 years old. I'm 60 LOL.
  17. Junior Stock
    Junior Stock
    Are you going to make this a tailgate dragger like the early days or use some of them 10 foot long wheelie bars?
    Thor1, loudbang and Quain Stott like this.
  18. Quain Stott
    Quain Stott
    Tail gate dragger, I'm trying to build it as close to the mid 60's era as I can.
  19. DDDenny
    Magnesium sparklers would bring them back from the Coke shack real quick!
    Not sure if it would please the track owner though.
    Thor1, mad mikey, bchctybob and 2 others like this.
  20. saltflats
    saltflats
    from Missouri
    Thought that was a given. ;)
  21. Quain Stott
    Quain Stott
    Didn't get to do much in the last several days. I did get a little done on the lower part of the turn brake.
    Since I don't have a clue what the ratio needs to be on it I made it adjustable with three holes. The top hole will be 7.33 to 1, The middle hole is 5.5 to 1, The bottom hole will be 4.4 to 1. I have them one inch apart. I feel stupid not knowing this but it's a mystery because I'm using a cable system to operate the parking brake for a turn brake. Most wheel standers have double calipers but this one is on a budget and I think this set up will work fine no faster than it's going to run. IMG_0803.jpg IMG_0804.jpg IMG_0806.jpg
    Thor1, mad mikey, catdad49 and 2 others like this.
  22. Junior Stock
    Junior Stock
    Maybe in the 80’s but not in 67
  23. Quain Stott
    Quain Stott
    I Have it tacked together because I'm still not sure if I have the ratio in range. I don't want it to touchy or to hard to work. I left extra on the bottom to make another hole if needed. That's all for tonight. IMG_0807.jpg IMG_0809.jpg IMG_0810.jpg
  24. AmishMike
    AmishMike
    Trying to understand brake use. Push away from your knee tightens right cable & brake & turns right. Pull towards your knee & reverse go to left. This correct??? Be sure to leave room by knee for lever to go left.
  25. Quain Stott
    Quain Stott
    Yea I use to do a little airplane flying in old stick controlled ultralight planes so I set it up the same way the planes were. Right for right and left for left it just seems natural to me. I have it offset to the passenger side to make sure I have room.
  26. seb fontana
    seb fontana
    from ct
    If you use two master cylinders and the stock wheel cylinders/brakes I think you will get better feel when applying.
    Thor1, Quain Stott and loudbang like this.
  27. Quain Stott
    Quain Stott
    The stock calipers will be my primary brakes. The parking brake side of the system will be my turn brakes. This way no extra expense. I don't think it will take much brake pressure to turn it. I have mechanical turn brakes on my tractor and it will turn on a dime with a plow in the ground.
  28. How quick is that tractor? Enjoying your build.
  29. Quain Stott
    Quain Stott
    LOL my tractor might out run the wheel stander. I'm just planning a mild 454 for power. Maybe 450 HP.
  30. AmishMike
    AmishMike
    Moving that brake lever right & left does not seem like put much pressure on e-brake cable. I was expecting 2 levers , 1 for each side, pull back to tighten e-brake cable. Understand you flying experience & hope they work as you plan. Looking forward to those first test drives in large open place. Great build, thank you for taking us along.
    Thor1 and chryslerfan55 like this.
