Technical Is this Flathead heavy duty oil pan worth saving?
Discussion in 'The Hokey Ass Message Board' started by Ziggster, Dec 23, 2018.
  1. Ziggster
    Ziggster
    That is why I love working on my Toyota truck. Three sockets will get most fasteners off. 17mm, 13 mm, and 10 mm. Jeep/Chrysler could learn a lesson from them.
  2. Desmodromic
    Desmodromic
    Those will come in handy when you have to replace the corroded chassis!
  3. Ziggster
    Ziggster
    Lol. Funny a few years back on my way to the dealer, I saw a forklift driving down the road in front of the dealer carrying a full frame into the workshop. They were replacing the Tundra frame under warranty. Crazy. No issues with my 97 LX450.
  4. Ziggster
    Ziggster
    Soaked the oil sump clean out bolts and drain plug for a week with some Seafoam. Nuts/studs came off with barely any force. Gasket appears to be a factory made piece and not homemade. Getting the drain plug out may be a bit more tricky. Will try to get some more dents straightened out. Waiting on a No. 2 tip from the welding supply store also so I can braze in some of the rust holes and to repair the forklift tear. Damn. The clean out plate is 1/8" thick!
    kidcampbell71 likes this.
  5. Ziggster
    Ziggster
    Damn. WTF? Looks like someone went at it with a torch or welder of some type.
  6. Ziggster
    Ziggster
    I can't believe it. If came off with a few taps of my 3 lb brass hammer and one of my large adjustable wrenches. That Seafoam works wonders. You can see someone just butchered the hell out of it at one point trying to get it out. Problem is that there are only two threads left in half the circumference. I'm not very comfortable with that.
    303racer and kidcampbell71 like this.
  7. adam401
    adam401
    That pan is a nice piece. Glad you decided to fix it, you'll be glad too. Good job.
  8. Beanscoot
    Beanscoot
    The drain plug threads look like they have been eroded from corrosion from sitting in water underneath the oil.
    The threads in the plate look good though. Perhaps the plug is available as a repro?
    egads likes this.
