Hot Rods Use of zip ties
Discussion in 'The Hokey Ass Message Board' started by Almostdone, Jan 31, 2020.
  1. H380
    H380
    from Louisiana
    Yep. That is the pair order. The bundle order is :
    Will / White
    Rodgers / Red
    Balls / Black
    Young / Yellow
    Virgins / Violet
    So you have White/Blue and Blue/White as first tip/ring pair. Violet is usually only used in 25 pair cable for the last 5 pair. 60 and 100 pair cable indoor cable use White, Red, Black and Yellow tape around the internal bundles in addition to the wire colors.
  2. Ebbsspeed
    Ebbsspeed
    And the phrase to remember the color code for resistors? Bad Boys Rape Our Young Girls But Violet Gives Willingly. Get Some Now.
    bobss396 likes this.
  3. Almostdone
    Almostdone
    Used to work with some electronics engineers. They often reverted to using the resistor colors for color coding damn near everything. I could never get the hang of it.
  4. squirrel
    I never did get far with the fun sayings, I just remember the names of the colors. And when I'm actually building something that requires several resistors, I again remember what number each color is.
    I guess if you learn this stuff young enough (10 years old) it sticks with you.
  5. Fortunateson
    Fortunateson
    Regarding the sharp cut off ends simply take a lighter and smooth them out.
    da34guy likes this.
  6. squirrel
    Flush cutters work great for cutting the end off flush and safe. Or get one of the tools they make for the job.
  7. stanlow69
    stanlow69
    I use zip ties to bundle wire together. Different colors for different items. Then use a different color and size to bundle those bundles together. It makes it easier to find and locate the problem areas. Use em with a tag to label parts as well. I have found the multi packs in a container are the cheapest ones made.
  8. deathrowdave
    deathrowdave
    from NKy
    I worked on top of a 8.5 million gallon liquid propane everyday for 30 years before transferring out to another dept . I knew some real “ sharp “ guys , that I wanted to put a ty wrap around their nuts so they could not infect the rest of the free world with stupid !
    seb fontana likes this.
  9. Silverplate
    Silverplate
    where do you purchase these?
  10. jimmy six
    jimmy six
    McMaster Carr has aluminum bundle ties...
  11. oldolds
    oldolds
    Quite a few different kinds on that auction site
  12. birdman1
    birdman1
    Baling wire is my first choice!!
  13. Like military connector contacts, they all had color bands on them. The widest one is where the code starts. like a "351", orange, green and brown. Orange would be the widest band.
  14. LOL never played baseball.
    I actually learned the trick from an old roundy round racer.
