Projects The Warbaby sport coupe build
Discussion in 'Traditional Hot Rods' started by Joe Rosales, Feb 17, 2018.
  1. Joe Rosales
    Joe Rosales
    One more piece to the puzzle. We got a little crazy and cut up the transmission tunnel cover. Got to try something new with Chris and put the dimple dies to use. Cover turned out great, and of course we had to add our signature rivets. Couple more side braces to add and the xmember is officially done.
    152E3F26-D343-40D7-A697-F8A5FD3B9B34.jpeg 1648470D-41F2-43B6-97E2-D558F1AC7FCE.jpeg 63FAA960-E284-451E-83CD-5406AD85E9DC.jpeg 1715F500-0735-448A-B0A0-6CF0235D61B9.jpeg 81977630-694D-4251-8D4C-1315A1768050.jpeg A32F6714-48D0-4F9A-93F9-0402761FEAEA.jpeg
  2. rust&patina
    rust&patina
    . . . Awsome Build . . . :cool: . . .
    Stogy likes this.
  3. Stogy
    Stogy
    @Joe Rosales Nice Period Correct Custom Fab...Like a Vintage Drawing in a Google Patent search for Vintage Hotrod Upgrades...I was thinking a Lexan/Plexi window in the floor with riveted aluminum sealed retainer allowing a small glimpse into the finer details...truly many times this art is unfortunately hidden to the masses...
  4. Joe Rosales
    Joe Rosales
    Stogy ,
    That is something to think about. Sounds like a great idea.
  5. sloppy jalopies
    sloppy jalopies
    super work... wish I would have tried to learn that stuff when learning was easy...
    Stogy likes this.
  6. Joe Rosales
    Joe Rosales
    It’s never too late!
    chryslerfan55, bct and Stogy like this.
  7. Joe Rosales
    Joe Rosales
    Rolled out the frame to see some daylight for the first time along with the Twilight Zone.
    B7168BFF-1616-49F2-B2F8-1E59A81D1113.jpeg 21851D19-E716-4325-9419-8334105273AE.jpeg
  8. Stogy
    Stogy
    :rolleyes:...the meeting of the periods...a wonderful adventure to follow this year...great stuff @Joe Rosales
  9. 18n57
    18n57
    Stogy likes this.
  10. Joe Rosales
    Joe Rosales
    If you have Instagram you can see all the photos @bexarbonesgarage
  11. panhead_pete
    panhead_pete
    Cheers.
    Stogy and chryslerfan55 like this.
  12. Thanks, i’ll check it out.
  13. Creative project! I appreciate that you share the process in the pics.
    Stogy likes this.
  14. Joe Rosales
    Joe Rosales
    Glad to share my journey with everyone.
    Stogy likes this.
  15. Blues4U
    Blues4U
    from So Cal
    Just found this thread, awesome work! Very impressive. If I may suggest something, you might want to consider running a torque rod to take the stress off those old bones. Or braces on the bones. The 35-36 bones are the good ones, but still, a nice 327 mill is going to put a lot of stress on them.
  16. dirty old man
    dirty old man
    I agree with Blues4U. Those bones were meant to hold a rear end square and the torque tube handle the task of keeping the rear axle from twisting.
    I bought a partially completed Brookville Roadster on a rolling chassis that had some Speedway wishbones that now are sold with the admonition that they are not for rear axle. After I finished the car enough to drive it and took it out and kicked on it they bent like spaghetti. Since the car was all but finished and was painted etc., I got another set just like them and welded in a web of 1/8" steel between the 2 tubes and they have held up fine.
    Since you have the bones, a single torque arm with the pivot aligned with the pivots on the bones should suffice.
    chryslerfan55 and Joe Rosales like this.
  17. Joe Rosales
    Joe Rosales
    Finally got the shocks to fit the dog bones. Some heat from the torch and some bending did the trick.
  18. saltflats
    saltflats
    from Missouri
    Nice, that had to be a fun project.
    glorydime likes this.
  19. Joe Rosales
    Joe Rosales
    It was a little tricky, but definitely worth it.
    glorydime, Stogy and saltflats like this.
  20. The37Kid
    The37Kid
    Just rereading some of this fantastic build, and have to ask about this photo. If that is a stock wheelbase '32 chassis, and the body is sitting with the rear wheels in the wheel wells, how does the stock 30-31 hood fit? I've always thought the cowl to grille shell was longer? Bob
  21. Joe Rosales
    Joe Rosales
    Hello Bob
    Yes, this is a stock 32 wheelbase. I actually took 6 inches out the rear because it was actually too long. As far as the hood goes I had to take 2 inches from the grille to sit proper. I removed the 32 grille and went with a 34 truck grille instead which fits almost perfect.
    kidcampbell71 and chryslerfan55 like this.
  22. Joe Rosales
    Joe Rosales
    I think the 34 grille looks better.
    Tim, phelan9251, A Boner and 11 others like this.
  23. kidcampbell71 and Runnin shine like this.
  24. Runnin shine
    Runnin shine
  25. Joe Rosales
    Joe Rosales
    Would like some feedback on these headlight mounts.
  26. Stogy, kidcampbell71 and Joe Rosales like this.
  27. Although the headlight risers are rather common, they're common for a reason...THEY WORK!!!!
    I like the look, especially on the Warbaby! ;)
  28. The37Kid
    The37Kid
    [​IMG]Everything you have done so far is real old time stuff, rivets, extended frame flanges, lots of original forged pieces. The cast aluminum headlight brackets are too streamlined, hidden hardware, too eye catching and look out of place IMO. Hand fabed brackets using airplane wing strut oval material would be more in place with exposed carriage bolt heads. :)Bob
  29. saltflats
    saltflats
    from Missouri
    Kinda plays off the V8 logo.
    Stogy likes this.
