Projects Aussie 32 frame / Model A coupe build.
Discussion in 'Traditional Hot Rods' started by Wardog, Feb 7, 2019.
  1. Wardog
    Wardog
    @Stogy thanks for the info. My column is a 1932 and the pin is a lot smaller so it sounds like it may be a bit trickier.
    I can hear the pins moving when I insert the uncut key and the cylinder rocks back and forth just a bit like it would rotate with the right key.
    @Beanscoot this might be the answer
  2. Stogy
    Stogy
    You don't need security clearances to buy those?...:rolleyes:...wow is nothing sacred anymore...and then go to YouTube for training...:eek:
    Joking aside I enjoy locks and keys...
    1947knuck and chryslerfan55 like this.
  3. Beanscoot
    Beanscoot
    Yeah, I wonder if customs would confiscate a lock pick set. They're cheap enough to risk it though.
    But I don't think low lifes are going to be picking even simple locks, they use cruder methods.
  4. Wardog
    Wardog
    Yesterday I stumbled upon this.
    New old stock 32 to 34 barrel with keys.
    Now I can drill the retaining pin out to remove the barrel with a bit less stress.
    41529CD9-E9CB-456F-A08D-AF578753CE57.jpeg 75D967B2-C0CC-4E25-A7A9-C330D6E9971A.jpeg 373700A7-664C-4504-AB12-6889236604B7.jpeg
    1947knuck, brEad and Stogy like this.
  5. Flathead Youngin'
    Flathead Youngin'
    oooooo even has the "Hurd" key.....
  6. Stogy
    Stogy
    @Wardog did you try that new key in the lock on your column...stranger things have happened...insert...work in and out in and wiggle it up and down turning gently, release and try again...nice find...
    1947knuck and brEad like this.
  7. Wardog
    Wardog
    @Stogy they are the sellers photos. I still have to wait for it to turn up. When it does that will be the first thing I try. If id doesn’t work then I’ll move on to removing the barrel the way it was done in the threads you posted links to.
    1947knuck, chryslerfan55 and Stogy like this.
  8. Wardog
    Wardog
    So the keys didn’t work in the old barrel. But I swapped the locks over and it all works E854CA7F-0602-4B5E-9AF7-D76F817E466A.jpeg 8F91720F-3BB5-4264-AC28-D99FAA5F2F68.jpeg
  9. Stogy
    Stogy
    :rolleyes:...gotta like it when a plan comes together...that's great @Wardog...
    1947knuck likes this.
  10. kool 52
    kool 52
    Great thread Wardey,really nice work
    Wardog likes this.
  11. sloppy jalopies
    sloppy jalopies
    Today, when they steal a car they use a rollback, with a guy standing there looking pithed pretending to be the owner... they load it and drive off with it... ouch !
    Atwater Mike likes this.
  12. Just keeps getting better, good one.
    Wardog likes this.
  13. Wardog
    Wardog
    Probably a distraction from what I should of been working on but a job done none the less. I have been obsessing over air cleaners for months. I got so confused over what I wanted and what would suit I decided to make my own. I’m pretty happy with the results.
    00A4870C-2DB3-4E11-9ADD-F9135CD27C0C.jpeg 6F6DCB46-D50C-4B44-B2A1-0DDAB9F416E0.jpeg 5E2FD32E-762D-4279-B084-E487487FF33E.jpeg D7CFE9C7-BB63-4C87-87A5-051963F10A23.jpeg
  14. solidaxle
    solidaxle
    from Upstate,NY
    Hey you are doing an outstanding job but, you have to wear a better mask when painting.The dust mask doesn't cut it. I have a 45 year old business card that I keep as a book marker from my old neighbor who painted cars for a living. He didn't wear a mask and never made it to 50 years old.
  15. Wardog
    Wardog
    Friday night I got the rest of the exhaust tacked up.
    D5C49B46-330B-4B44-97F9-756E033DD859.jpeg 484310E2-35D9-43C3-A955-8246ACB60752.jpeg 098F07D4-C1ED-44FD-83A0-9F04A0D7DA41.jpg
    1947knuck, Stogy, Aaron D. and 7 others like this.
  16. Drylake
    Drylake
  17. Nice work on the exhaust.
  18. Wardog
    Wardog
    Thanks guys.
    Stogy likes this.
  19. Hey mate,
    Had a great time going through your thread. Loving the trad build. You've got a really nice balance of detail going on! Going to stay watching your progress.
    Cheers
    Josh
    1947knuck and Wardog like this.
  20. Wardog
    Wardog
    Last week I lifted the rear of the mufflers 1” and welded everything out.
    I had a weekend away with the family visiting old friends.
    Today I finished polishing and installed everything. I ended up shortening the tailpipe sections 1” for clearance near the park brake cable.
    I’m a lot happier with how the mufflers sit now.
    DA4AE5D4-D352-4E0F-AE33-2327B6A4AB6A.jpeg 7B4A65E8-CF61-41C4-93F7-30ADC5313E28.jpeg 8D36E3EC-90FD-4780-A657-C2D305666469.jpeg
  21. Wardog
    Wardog
    Today I mounted a mechanical brake light switch directly to the pedal box that actuates off the pedal.
    6A39ADAE-C2FA-45F1-A1D6-103F07630C83.jpeg 91BD9060-EE57-49FB-BD46-F628F032A4D0.jpg
    For those that were concerned or advised me. I now have a decent respirator for painting.
    redzula, Just Gary, 1947knuck and 6 others like this.
  22. Stogy
    Stogy
    Might as well keep that mask Handy for going out as paint seems not the only airborne carcinogen these days...:eek:
    Chassis looking seriously wonderful @Wardog...keep out of harms way...;)
    1947knuck, brEad and Wardog like this.
  23. Need it for going down the shops now Wardy
    Wardog and Stogy like this.
  24. Looking mint! Nice and tidy way of incorporating the brake switch.
    Cheers,
    Josh
    1947knuck, Wardog and Stogy like this.
  25. Fantastic build! Really great build thread, the H.A.M.B. at its best! Chassis is perfect, looking forward to the rest of the adventure.
  26. Wardog
    Wardog
    Thanks for the reply’s guys.
    Josh the switch mount didn’t have to be anything more than what it is, it also doubles as a stopper until the floors are installed.
    Kev thanks for the compliment. I’ve read many of your threads over the years.
    1947knuck and Stogy like this.
  27. Wardog
    Wardog
    This weekend I started to pull the coupe apart.
    508651DF-2E3F-4E7B-9C17-A9B4DA62AA84.jpeg 159CA157-78A5-40BD-85BB-14E04E55347A.jpeg F5B65A17-E174-4333-9D76-B24146319D95.jpg
  28. Tim_with_a_T
    Tim_with_a_T
    Atwater Mike and chryslerfan55 like this.
  29. Wardog
    Wardog
    I’ll see if I can find some info for you.
  30. Benny28
    Benny28
    from Australia
