Technical Anyone still using Dial Calipers?
Discussion in 'The Hokey Ass Message Board' started by blowby, Jan 17, 2020.
  1. blowby
    blowby
    from Nicasio Ca
    Yeah, the ones with a dial.
  2. We did in class yesterday
    Checking drill bits for tap size.
    Chavezk21, Gray Ford and Boneyard51 like this.
  3. treb11
    treb11
  4. DIYGUY
    DIYGUY
    from West, TX
  5. Budget36
    Budget36
    Yes, batteries never go dead;)
  6. Snipe
    Snipe
    I've got a Brown & Sharpe that I bought in 1965.
  7. scrappybunch
    scrappybunch
    from nj
    Yes, all the time. The electronic one is in the drawer next to it with dead batteries.
  8. saltracer219
    saltracer219
    I use mine every day, however I must say that those Starretts pictured are the most dissapointing dial calipers that I have ever owned. I have 2 of them and they both went to hell after a short period of use. I have 4 Brown and Sharp's and they are pretty much bullet proof!
    Stogy, Desoto291Hemi and Boneyard51 like this.
  9. I do mine is about 40 years old . Digital stuff don't last long in this climate.
    Stogy and Boneyard51 like this.
  10. fourspd2quad
    fourspd2quad
    Every day either at work or home. :)
  11. blowby
    blowby
    from Nicasio Ca
    Well you guys read my mind. I use calipers infrequently and every time with the digitals I'm hunting for a battery. Thanks, glad I'm not alone.
    Stogy, VANDENPLAS and Boneyard51 like this.
  12. One of the most important tools I have. Dial type is the best.
    No digital for me
    Sent from my SM-F900U1 using The H.A.M.B. mobile app
  13. I don't use mine very often so I need a battery almost every time!
    blowby, Stogy, tractorguy and 2 others like this.
  14. 1-SHOT
    1-SHOT
    from Denton
    I use my dial caliper all the time, never needs battery's
    blowby, Stogy and Boneyard51 like this.
  15. I use mine a lot more often than the digital ones I have around. Unless I'm working on OT bikes... they're metric.
  16. error404
    error404
    from CA
    I use both dial and digital. Digital is nice when you need to also do metric
    I like using dial especially if I'm slowly cutting something (like on a lathe), for some reason seeing the dial makes it easier for me to know about how far off I am.
    Same thing with looking at a clock, I find it easier to just quickly glance at an analog clock rather than a digital clock where the numbers change. For some reason seeing 4:42 on a digital clock takes longer for my brain to register how long it is until 5:00, versus seeing it on an analog clock with hands.
    j-jock, blowby, ffr1222k and 7 others like this.
  17. eaglebeak
    eaglebeak
    Did you ever think to remove the battery when not in use?
    j-jock, blowby, Stogy and 2 others like this.
  18. Sporty45
    Sporty45
    Use them often. I have two dial and one digital. Hardly ever use the digital ones. Extremely handy tool to have :cool:
  19. Churchy
    Churchy
    Every dang day
  20. speedshifter
    speedshifter
    I read an article by an engineer. He compared the accuracy of the cheap Harbor Freight dial calipers & digital calipers with the accuracy of expensive calipers such as Starrett or Brown& Sharp. He said accuracy was equal but the action was smoother on the high dollar calipers. Greg
  21. lostone
    lostone
    from kansas
    All the time, I'd be lost without mine.
    You mean there are ones that take batteries ?? Lol
    Montana1 and Stogy like this.
  22. RichFox
    RichFox
    I use my dial calipers often. I hardly ever use my Vernier calipers anymore
  23. Boneyard51
    Boneyard51
    I don’t have any digital calipers, I use my dial calipers in the shop. But in my road bag I keep my Vernier calipers, they are a whole lot more durable. But are getting harder for me so see any more!
    Bones
    j-jock, blowby, LWEL9226 and 3 others like this.
  24. The37Kid
    The37Kid
    These will be 44 years old in March, magnifying glass in now an option. Bob
  25. blowby
    blowby
    from Nicasio Ca
    Do you think there is a battery drain when they are off?
    Atwater Mike and Stogy like this.
  26. jaw22w
    jaw22w
    from Indiana
    I use my 6" dial caliper a lot. It is the most used measuring tool right after a tape measure. It's great and works every time. I have a 12" digital caliper. I hate it. I never trust the measurements until I've checked it 5 or 6 times. I just have an innate distrust of digital gauges. Everything else, all my mics and bore gauges, etc. are analog. I'm a skeptical old bastard.
    GeezersP15, Montana1, blowby and 3 others like this.
  27. Marcosmadness
    Marcosmadness
    The dial calipers allow you to interpolate between the lines. With digital calipers all you know is what the display shows. You don't know if the measurement is exactly what it says or is barely what it says. Tool and Die makers, the top of the machinist food chain, use dial calipers. Digital calipers are considered accurate to plus/minus .001 (a .002 spread) Dial caliper are considered accurate to .001. With practice you can hold a tolerance to .0005 with a dial caliper.
    Montana1, Stogy, flatford39 and 2 others like this.
  28. G-son
    G-son
    from Sweden
    Don't have one of those, but if i did I'd use them. I have vernier & digital calipers and use both.
    As eaglebeak suggests, if you don't use the digital ones often, take the battery out, there's usually a spot for it (and/or spares) in the box. My first digital set went through batteries quickly, when they broke I got a new one of the same model, obviously improved as the battery lasts much longer.
    blowby and Stogy like this.
  29. Real Men use vernier calipers. :rolleyes: At least until their eye-bones start failing them. :confused:
    OLSKOOL57, Blues4U, squirrel and 5 others like this.
  30. Okie Pete
    Okie Pete
